Old 03-23-2005, 12:42 PM   #1
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Question cylinders layout and compression results
I just did a compression test on my 1.8 ( EJ18 )
I do not know what cylinder is what .... (can someone please reply back with the corresponding cylinders)
I let the engine warm up and then pulled the fuel injector power plugs off each cylinder. It took awhile to take the plugs out (esp that one in the rear by the battery)so I noticed my first check was lower by a little bit between the 1st and 2nd reading on the cylinders
My 2nd readings were
**At the front of the car looking towards the engine is my coordinates when I say left and right
Back right = 164
Front right = 170
Back left = 172
Front right = 175
How are these compression numbers for engine that is almost 146K?
The engine feels ok when I drive it.
jkjersey is offline   Reply With Quote
Old 03-23-2005, 12:49 PM   #2
Aphex28
Member#: 11506
2015 WRX
I'm no expert nor do I know anything about the EJ18, but I think that as long as they're within 10 of each other you're golden.
EDIT: Oh! And to tell which cylinder is which, it should say on your coil by where the wire plugs into it. Cylinder 4 is the one closest to the passenger I believe. But this is for the EJ25 and yours may be different if it has the same type of ignition system
Aphex28 is offline   Reply With Quote
cylinder compression results minnk1 Service & Maintenance 2 03-02-2010 09:14 PM
cylinder compression results minnk1 Newbies & FAQs 4 03-02-2010 08:59 PM
Leakdown and Compression Test Results Hah72215 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-24-2008 01:35 PM
Cylinder layout Wrxtuner251 Newbies & FAQs 2 03-31-2008 04:39 PM
99 2.5RS - EGR valve? cylinder layout? falnfenix Normally Aspirated Powertrain 0 05-05-2007 02:20 PM
