Old 07-21-2001, 10:25 PM   #1
fastwrx
Member#: 7398
2004 2004 WRX-STi
Post Custom installation of Valentine One Radar Detector
Using some hints on the procedure I learned here, I was able to hardwire my new Valentine One radar detector in my WRX. It came out very nice and neat, and it required nothing more than a pair of pliers, a phillips screwdriver, and a wire brush. The procedure could apply to any brand of radar detector.
Rather than clutter up the forum with 13 pictures and captions, I put it all in an online album. Click on the link below to see it.
Valentine One Installation Album
Mike
fastwrx is offline   Reply With Quote
Old 07-21-2001, 11:39 PM   #2
Snowman
Member#: 3070
2009 Outback XT
Post Good instructions
Nice install directions. Now all i need is the valentine one radar detector and a WRX J/K
Good enough for some attention from the subaru mod god "North"
Does North already have this documented? Oh well, nice job!
Snowman
Bad spellers of the world, UNTIE!!!
Snowman is offline   Reply With Quote
Old 07-22-2001, 05:06 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Not bad. Not quite as hidden as mine, but unless you know about mine, there is no way you'll find it without searching around the cabin for a bit.
Old 07-22-2001, 12:00 PM   #4
fastwrx
Member#: 7398
2004 2004 WRX-STi
Thanks, guys. It's my first mod! Not bad for a newbie, eh?
Maybe more to come... I'm hoping Cobb gets an "authorized" installer down this way!
Mike
Old 07-22-2001, 12:37 PM   #5
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Here is how I did mine.
http://www.scoobymods.com/mods/impreza/v1.php
People never see where it is. I put the remote display inset in the dash bezel by dremeling a spot to fit it. (I got a used bezel from Teagues for when I want to sell the car)
And the main unit is under the passanger headrest. It can see front and rear just fine. I've had it this way for a long time and it works well. If I have a passanger I can move it to the window but it actually still works well with someone sitting there. It just throws off the direction arrows. I mostly drive alone though. With tinted windows it's very hard to see the main unit. This is nice because I don't get people leaching off me when I drive down the road and theives can't see it either
Peaty
Peaty is offline   Reply With Quote
Old 08-16-2001, 07:32 PM   #6
bongo
Member#: 6911
86 Samurai
Default You rock
I am in the process of hooking up my V1 as i type this and found this thread after searching a bit. A big fat THANK YOU to you Mike Barr - excellent well illustrated instructions.
I don't have the remote so i'm just doing a real stealthy install w/ the flat power cord through the top, and using the wire brush from my grill to ruff up the ground connect maybe i'll get the remote sometime in the future and run it down there. in the meantime, this works just fine.
Helpful keywords to help other wrx'ers find this thread faster than I did:
Valentine 1 Valentine1 install wrx mirror rearview
optional electrochromic mirror / compass wiring harness conspiracy cointelpro osama bin laden mkultra someone set up us the wrx hahaha
bongo is offline   Reply With Quote
Old 08-16-2001, 09:23 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
I'm baffled. Since you used the Compass Mirror connector's Yellow w/ Red stripe wire for power, why didn't you also use that connector's Black wire for ground and avoid all that business with the wire brush?
Jon [in CT] is offline   Reply With Quote
Old 08-16-2001, 11:08 PM   #8
iemonslice
Member#: 8882
02 impreza wrx
srp
iemonslice is offline   Reply With Quote
Old 08-17-2001, 12:26 AM   #9
BradWRX
Member#: 5500
2002 WRX Aspen White
2004 Corvette Z06
Thank you, I think you did a superb job with the pics and explanation. I did this but would like to relate my changes to your option:
I agree with Jon, I tapped into the ground (blk) wire, so much easier. Go to Radio Shack and get those tap in clips. I would not want the plug in gizmo velcroed to my windshield, I stuck it inside and under the roof liner near the light fixture, plenty of room. I used the "phone" type cord to the detector, still plenty of room for the excess. No coiled cord mess around this way, so much better! Very neat and clean. The detector can be stuck where ever you want after that, plenty of cord left. If you add the remote, just run the wire thru the roof liner as you suggested. This provides a much more neat and clean install.
BradWRX is offline   Reply With Quote
Old 08-17-2001, 01:42 AM   #10
2.0 guy
Member#: 5670
I notice that Mike looks like he has the standard mirror...
anyone done this that has the auto-dimming mirror and any ill effects by doing so?
I'm planning this project on the weekend, but want to be sure I'm not gonna mess up the auto-dimming/compass mirror by tapping into its power source...
Thanks!
2.0 guy is offline   Reply With Quote
Old 08-17-2001, 02:02 PM   #11
BradWRX
Member#: 5500
2004 Corvette Z06
2.0 guy,
I have done it with the power source from the dim/compass mirror. Had it this way for four months and not a problem. It is a simple task and simple concept. The V1 or any detector draws very little current on that circuit and way below the fuse rating.
OBTW, even if you don't have the mirror option the wiring is still there to use. Thx Subaru.
Old 08-17-2001, 02:12 PM   #12
2.0 guy
Member#: 5670
Brad,
good enough for me! Thanks.
Just wanted to be sure that I wasn't going to have any negative effects by using the power from the mirror...
Originally posted by BradWRX
2.0 guy,
Old 08-17-2001, 08:57 PM   #13
fastwrx
Member#: 7398
2004 2004 WRX-STi
Hi Brad,
Good suggestions. When I have time, I'll go back and tidy things up a bit. Time??? Got a 10 week old. What's TIME???
Mike
Old 08-17-2001, 09:18 PM   #14
BradWRX
Member#: 5500
2004 Corvette Z06
Thanks Mike,
Knowing that you have a 10 wk old I don't know how you had the time. Anyways, great presentation.
Old 08-18-2001, 12:19 AM   #15
2.0 guy
Member#: 5670
drat!
well, while taking the dome light out, I noticed the right side screw didn't come out, so I shook it a bit and it still didn't come out...
ok fine (it was out from the metal, just wouldn't come out from the plastic housing)
I finish the wiring, put the left screw in, and go to put the right one in... guess what, it comes out, falls somewhere on the floor of the car.
Looking for 15 minutes with a telescoping magnet and I couldn't find it...
figures... the light is in place well, but I'd like to make it back to new, so I guess a trip to the dealer.
My right side windshield washer nozzle doesn't spray either, so I might need to drop in and report that...
Old 08-18-2001, 04:02 AM   #16
BradWRX
Member#: 5500
2004 Corvette Z06
2.0 guy,
I can relate buddy. When I first did mine in April the right hand side screw fell perfectly in the crack in the emergency brake area. Boy was I pissed I thought. Do I have to remove all that stuff to get at it? Yes a miracle, the magnet long thingy worked and got it out. Praise the Subaru god.
The point of this is, check the crevice below where the hand brake is. Mine was there, hope yours is as well.
Good luck a fishin
Old 08-18-2001, 02:04 PM   #17
2.0 guy
Member#: 5670
Brad,
that was the first place I checked (based on the sound of the drop). Had no luck with the magnet, and couldn't see with a flashlight eithe.
Of course, things like this can always turn up, so maybe operating the e-brake a few times will make it visible.
thanks!
Mike
Old 10-07-2001, 02:40 PM   #18
Wagon Guy
Member#: 10888
Lightbulb
hey guys,
Here is a great tip, a friend of mine did this to his Jetta and I did it to my WRX.
1. Remove suction cups from the V1 windshield mount.
2. Remove center flip-down sun visor (above rear view mirror),
it is a single phillips head screw.
3. The V1 windshield mount can be mounted in place of the sun
visor with the stock screw. Some minor boring of the V1
windshield mount center screw hole will be required to
fit the visor screw. (note you'll need to angle your cut
to get it to mount in the right angle)
I'll post some pics later
Wagon Guy is offline   Reply With Quote
Old 01-07-2006, 01:51 PM   #19
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
subscribe to old thread. for good info
FS: Valentine One Radar Detector and G-Tech Meter! vtfan Private 'For Sale' Classifieds 6 08-28-2004 02:56 PM
FS. Valentine one radar detector, 2004 Wagon swaybar jawbrkr Private 'For Sale' Classifieds 12 03-24-2004 12:33 AM
FS- Valentine One Radar detector doppelganger New England Impreza Club Forum -- NESIC 7 11-18-2003 12:36 PM
FS: Valentine One Radar Detector AZ-GT Private 'For Sale' Classifieds 15 11-06-2003 04:02 PM
FS: Valentine One Radar Detector FastRS Rocky Mountains Impreza Club Forum -- RMIC 3 10-27-2003 11:03 AM
