Old 03-23-2005, 10:05 PM   #1
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Default Convert your "Blue" Emanage to "Gold"
Well the inevitable has happened. For those of you that use the emanage, you may have heard about a "gold" version that was released in Taiwan + Japan that included WB02 logging ability, volumetric efficiecy calculations, and a NEW MAP!
The new map is a Acceration enrichment map which provides extra fueling when the throttle is moved quickly causing a surge of boost. Typically you see this kind of map in standalone systems but since the emanage has the ability to add pulsewidth to the injectors, it can easily add this function as well.
This new map is awesome!! My RSt goes dangerously lean during shifts due to the stock computer not having suficcient acceleration enrichment to cope with my instantly spooling T3. I suspect it is less of a problem with larger turbos, but with the T3 spool can be very very quick.
In the new map you input "gain" which probobly amounts to some increase in PWM to the injectors. You can map this gain in 3D over a 8x8 table (%throttle Pump / RPM)
US language files have just been released such that you can now convert your blue emanage to a gold emanage, update the emanage to the new firmware, and use the new map and features!!
Someone who did it:
http://www.j-body.org/forums/read.ph...=68524&t=68524
- he claims that it does autotuning - but I think he's wrong.
- The best part about it is the new control map
The files:
http://12.22.230.41/MicroTech/Host/F...e_US_files.zip
Directions on updating your emanage:
http://drizze99.conforums3.com/index...num=1111549216
Have Fun!!!!!!!
Hitokiri is offline   Reply With Quote
Old 03-23-2005, 11:25 PM   #2
ThuotRDX
Member#: 16106
1992 T3/T4 turbo SVX
with a 5 speed
emanage is looking better every day. but i am having a hard time finding one for cheep.
ThuotRDX is offline   Reply With Quote
Old 03-25-2005, 12:48 PM   #3
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
someone said they are having trouble with reflashing it and using the new features, so noboby run off and do it yet..
I am going to let more people test it first.
Todd
Old 04-08-2005, 03:07 PM   #4
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
well guys I have just successfully completed this so it can be done. I havent had a chance to do any road tuning with the new accelleration map as of yet but it should be awesome!!
there are some quick shorts you need to make on the circuit board, but for those of us that installed our own emanage that stuff is small time by now.
more info:
http://drizze99.conforums3.com/index...isplay&start=0
Old 04-09-2005, 11:05 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
Another great find Todd.
convert your car to a plane for $2950 plunk10 Off-Topic 28 05-03-2007 10:34 PM
fact or fiction: if you convert your car to run on propane you are emissions exempt Physics Junkie Southern California Impreza Club Forum -- SCIC 3 11-13-2005 01:03 PM
Convert your uppipe to External WG! Bell mouth downpipes ok! jared nelson Private 'For Sale' Classifieds 24 05-10-2005 09:47 PM
FS: Convert your L to RS, and some other parts sanders South East Region Forum 9 10-06-2004 11:15 PM
Convert your Kph speedo to Mph lenyx New England Impreza Club Forum -- NESIC 1 02-12-2003 10:09 PM
