#1 |
Member#: 33222
South East
Vehicle:2003 WRX Midnight Black Pearl |
I am not sure if this setup is even retailing yet, but it looks like a less expensive way to read and log afr's when used with some third party EM. The LC-1 is not as feature rich as an LM-1 but it seems to be adequate for most tuning needs.
Has anyone seen these yet? Anyone have any opinions on them? http://www.innovatemotorsports.com/x...cat=252&page=1
#2 |
Member#: 54604
Vehicle:2004 FXT Cayenne Red (sold) |
How is it less expensive? You can get an LM-1 for $320.
Frank |
#3 |
Member#: 33222
South East
The LC-1 is just $200 with sensor. The XD-1 does not appear to be needed in order to log afr, and it comprises the difference in the package price.
#4 |
Member#: 54604
Oh. I just looked at your link and the price at the bottom and saw the $399 pricetag. If it's $200 and hooks to the Cobb ST, heck I should have waited and bought it instead of the LM-1.
Frank |
#5 |
Member#: 35944
South East
Vehicle:'03 6MT WRX MBP |
bump
looking for more info on this. Seems the LC-1 would be adequate for my use with Street Tuner..and I wouldnt have to find a place for the big LM-1 display. Nobody has used these yet? |
#6 |
Member#: 33222
South East
Does anyone know anything about this product???
#7 | |
Member#: 8151
South East
Vehicle:2002 WRX Rally Car NASA Rallysport, yo! |
#8 |
Member#: 8775
South East
Vehicle:2010 "Zed" 1000 Orange/White |
Winston, Eli.....
You guys should stop by the shop we have one of these and it works awesome. I think it's the other model however. I plugged it in and ran it in my car the other night only to find out that I'm at 10:1AFR and it even went down to 9.8:1AFR!!!!!! So, I am having to re-tune the car. My only guess is that the gearset took away the load, thus only running 15psi and in doing so I'm running way too rich. Jose |
#9 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
how do you log with it directly? you need to have some kind of A/D input for your logging tool. oem ecu has none. utec has none. tuner pro does, but then why would you need a wideband?
#10 |
Member#: 82730
Vehicle:2002 WRX 4EAT Silver |
1. If anyone finds this unit for the $200 please let me know, the "gauge" itself is $230 I belive.
2. Has anyone tried the device from zeitronix? Thanks! |
#11 | |
Member#: 7453
TXIC
Vehicle:2005 Legacy GT Wagon 2006 LJ Rubicon |
#12 |
Member#: 15350
Vehicle:2002 WRX Sedan Midnight Black |
If I'm not mistaken, the serial protocol for the new unit *should* work with the UTEC->LM1 logger program that I wrote. I think the serial protocol for all of Innovates products are the same. Which means you can still use this version and the UTEC to get Tuner-esque logs...
Here is the link to the software...MPS_UTECLogger_1.2 If anyone gets one of these new units, let me know if the program works with it... -jason |
#13 | |
Member#: 65609
SCIC
#14 |
Member#: 33222
South East
A friend of mine has ordered one that should be arriving today. I will try to check it out and post my findings later.
#15 |
Member#: 69071
Vehicle:2002 Stg2-WRX Wagon WRB & Dust |
It's about time Innovate came out with something like this. Looking at WB for use with ST and this may just be it. Then I won't have to borrow a friends LM-1. Looking forward to some user reviews.
#16 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
It's very cool. It's a logging WB sensor. As long as the data read rate is high enough it will be a great tuning tool and not a bad guage to have. I'd want it to record at least at 10 Hz, 20 Hz would be better with a time stamp.
#17 |
Member#: 57445
I am on the verge of buying the Cobb StreetTUNER which is compatible with LM-1 (349) now I am wondering for 50 bucks more I wouldn't mind having a gauge and a unit that does essentially everything an LM-1 does (i.e. the Innovate “Standalone Gauge Kit” comes complete with the new LC-1 Wideband Controller for 399).
My question is would this work with the StreetTUNER? |
#18 |
Member#: 33222
South East
The answer to that question will be provided shortly. ![]() We just finished some install work tonight on the XD-1, and the O2 bung was welded in last night. So it looks like the package gets wired and tested tomorrow. |
#19 |
Member#: 36901
South East
Vehicle:2007 RX-8 Brilliant Black |
bump for answers...
#20 |
Member#: 64301
Vehicle:2004 STi WRB |
Ever any updates on this?
#21 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
On which part? I had an LC-1 installed in my car for a bit and it is also working with StreetTUNER. It performs almost identically to the LM-1, albeit it comes in a more discrete package.
-Jon |
#22 |
Member#: 64301
The XD-1 and ST.
#23 |
Member#: 67483
Vehicle:2005 WRX STi |
I just finished the install of my LC-1/XD-1 combo last Saturday. I installed the sensor in place of the stock rear O2 sensor. The body of the LC-1 is attached to the side of the transmission mount near the stock O2 sensor plug. I ran the wires up along the stock harness then routed towards the driver side firewall gromet above the pedals. XD-1 is floating in the corner where the door, a-pillar, and dash meet.
I'm using the newest LM-1 DLL with StreetTUNER on my 05 STi. I did a test logging sesion with it. Looks Good. (Terminator)-->(LC-1)-->(XD-1)-->(SIIG USB Serial Adapter)-->(Laptop) The XD-1 is pretty sweet. Very easy to see even in bright light. The auto dimmer keeps the glare down at night. Overall good stuff. |
#24 |
Member#: 64301
Nevermind I wasn't thinking
![]() Last edited by OttawaSTi; 06-14-2005 at 03:40 PM. |
#25 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
lc-1 = lambda cable 1....$199
xd-1 = lambda display 1...$229 all you need to log in ST is the lc-1 the xd-1 is the add on display as far as i can tell the lc-1 has all the featuers of the lm-1 but without the display/ (and off line data logging?) i just purchase the lm-1 for use with my tec2 |
| Thread Tools | |
| Display Modes | |
| FS: Innovate LC-1 wideband, Innovate XD-16 gauge (w/pod) | EdsWRX | MAIC Private Classifieds | 12 | 03-08-2010 10:42 PM |
| FS: Innovate LC-1 wideband, Innovate XD-16 gauge (w/pod) | EdsWRX | Engine/Power/Exhaust | 23 | 11-19-2009 09:38 PM |
| FS: Innovate LC-1 wideband, Innovate XD-16 gauge (w/pod), Defi gauge setup (w/ pod) | phlegmon | MAIC Private Classifieds | 4 | 09-10-2009 11:39 PM |
| FS: Innovate LC-1 wideband, Innovate XD-16 gauge (w/pod), Defi gauge setup (w/ pod) | phlegmon | Engine/Power/Exhaust | 8 | 09-09-2009 10:28 PM |
| FS: Innovate lc-1/xd-16 Wideband | lugee | SCIC Private Classifieds | 2 | 05-25-2009 07:46 PM |
