Old 03-23-2005, 11:47 PM   #1
static_rst
Member#: 50155
Exclamation his engine was on fire!
ok, well it wasn't on fire but still.
friend has an OBS, its a 98. it has an intake and thats it. it just got a new clutch. there is a burnign smell of some sort coming from the area (in the engine bay), by the passenger side strut.
it does not smell like a normal clutch burning, but i think it may not be properly adjusted and is rubbing and burning slowly.
it does not smell like burning oil.
it does smell like a hot engine + something else, but that something else is unknown. any suggestions, any parts that usually burn or smell bad on 98 obs's? could it be my clutch theory?
*sorry about the title
static_rst is offline   Reply With Quote
Old 03-24-2005, 12:05 AM   #2
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
um maybe ur clucth theory but i have no clue
99subi is offline   Reply With Quote
Old 03-24-2005, 08:10 AM   #3
Aphex28
Member#: 11506
2015 WRX
Headgasket? Did you check for that? How does the coolant overflow tank look? Does it look like a milkshake? Does he have overheating problems?
Aphex28 is offline   Reply With Quote
Old 03-24-2005, 09:47 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
pass side strut.
is the cv intact?
leaking?
are there any spilled fluids from the tranny change burning off on the exhaust?
just some things to look for.
Jamie
www.subiegal.com
Old 03-24-2005, 10:43 AM   #5
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
I second the CV boot on the pass side . I have owned 2 subaru's that had the inner CV boot fail as a result of just being to close to the cat .
imprezzakc is offline   Reply With Quote
Old 03-24-2005, 12:04 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya that stuff does smell weird when it's smoking.
Tim Sanderson is offline   Reply With Quote
Old 03-24-2005, 12:37 PM   #7
HaPpilyObsessed#44
Member#: 74744
2004 WRX STi
'52 Chevy S-10
Perhaps the new clutch still needs bleeding? If the clutch engaugement is right next to the floor you might want to check into this. Or like you said could need adjustment. The plates could still be slightly making contact just enough to give you this smell. Though this would most likely also make it harder to slip into first when at a stand still..(IF the clutch engauges right at the top of the pedal it could be not fully engauging either) Just thought id further explain this theory as a possability...
If the clutch was really *just* replaced and it doesnt seem too close to the top of bottom of the pedal maybe wait a day or two before thinking about it too hard.. could be burning off just some old fluids that got messy from the swap
HaPpilyObsessed#44 is offline   Reply With Quote
Old 03-24-2005, 05:21 PM   #8
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Do you use an odd kind of oil? I got a really odd smell I couldn't identify from over there that turned out to be my Castrol synth blend oil leaking a bit past the valve cover gasket onto the cat. It smelled kind of like a belt burning with an oily smell, but not your typical burnt oil smell.
Al_Smokemcrack is offline   Reply With Quote
Old 03-24-2005, 05:58 PM   #9
static_rst
Member#: 50155
the smell has been occuring for as long as he has had the car, couple weeks, but just got his oil changed. so its not the oil. it may be the clutch.
it also might be some vacume line or something rubbing where it shouldn't. the clutch engagement is right at the floor, i drove it and was like *** is wrong. lol.
the differential seal thing could be a possiblity but how would you go about checking that? or is that a mechanic type thing? any info on this would be awesome.
Old 03-25-2005, 09:50 AM   #10
Impreza_RX
Member#: 68015
2006 WRX TR
Steel Gray Metallic
what kind of smell does it have? after i run my car hard, my car smells like sticks being burnt.
Impreza_RX is offline   Reply With Quote
Old 03-25-2005, 09:56 AM   #11
static_rst
Member#: 50155
well it is almost a sweet smell, but not really. i thought it was saduer(sp?) at first but i turned my gun on and realized that it was not that. so as of right now, i have no clue what it is.
Old 03-25-2005, 09:46 PM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
sweet smell?
that's coolant....
for this check up front by the radiator and the coolant reservoir
are there any leaks? any signs of over flow? spills?
back to the cv joint leak:
get under the car and look at the axle.
see if there are any signs of grease visible
either where the axle does into the tranny
or goes into the knuckle/hub
Jamie
www.subiegal.com
So my engine just caught on fire... soundslikeboxer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-20-2008 01:18 AM
So my turbo was on fire last night Su||y Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 09-30-2008 01:48 PM
Ok so my engine caught on fire today shutupnshift04 Built Motor Discussion 24 10-03-2007 08:33 PM
Help!!! Engine caught on fire Gc8sac Service & Maintenance 17 06-15-2007 02:43 AM
My house was on fire last night... Murray Tri-State Area Forum 13 08-23-2003 02:51 AM
