Old 03-24-2005, 01:18 AM   #1
blackrexnj
Member#: 73594
Default can I use Cobb AP with my Vishnu stg Zero?
hello all, I bought a 2002 wrx sedan last year, I found out a month after getting it that it had the stage zero package from vishnu minus the uppipe. Since then Ive installed a txs uppipe, and a full Catless TBE.
the vishnu is the old system with the Dastek piggyback unit and an emi adapter with an underdrive pully.
If I get the cobb ap, can i use it with the vishnu unit, or would I have to remove it?
can someone with info help?
thanks
blackrexnj is offline   Reply With Quote
Old 03-24-2005, 03:25 AM   #2
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Best to remove all the Vishnu EM stuff, then load up the Cobb Stage 2.
drees is offline   Reply With Quote
Old 03-24-2005, 10:57 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup/\/\/\
Old 03-24-2005, 10:35 PM   #4
blackrexnj
Member#: 73594
ok cool, thanks for the info.
Do you know if I will feel a big difference with the cobb stg 2?
Cause right now with the vishnu, my boost in 3rd and 4th hits 3 lines pass the .1 bar, which i think is around 14 psi. But what suks is in first and second the boost goes to the .1 and as the rpms go high the boost goes down 5 lines under .1 bar, and thats at full throttle.
So all I would have to do is detach the emi chip and the piggyback unit and then I can just install the cobb?
want to get a Cobb AP with my set up...??? nycsubaruwrx AccessPort 2 03-14-2008 04:02 PM
Can I use this fuel with my accessPORT? dkane Newbies & FAQs 4 07-10-2007 02:18 AM
should i run my cobb ap with my mbc the real suby dude AccessPort 9 06-06-2007 10:26 PM
????COBB AP with my set up??? vvafivv AccessPort 3 09-12-2006 03:35 PM
just installed Cobb AP, cant take out vishnu stg Zero blackrexnj Engine Management & Tuning 3 03-30-2005 01:54 AM
