#1 |
Member#: 45790
Vehicle:2006 Corvette C6 Z51 SUPERCHARGED |
'99 EJ 25 SOHC block with 78k miles or so; engine ran fine, never gave me any trouble. I have all the bolt ons (CAI, full exhaust, pulley, LW Flywheel, S-AFC, etc) but no boost, no raised redline; nothing particularly bad for the engine...
Slammed on the gas in 1st at 3000RPM. Revs climbed to 5500RPM or so as usual with good acceleration. At 5500RPM it felt like it had hit fuel cut, then engine died without making any usual sounds. I don't see any leakage from headgaskets either. It will turn over and try to start but will stutter (regardless of throttle input) and stall immediatelly afterwards. I am guessing the timing belt broke. I'm also hoping that doesn't mean the valves are bent. Does anyone have any other guesses? Its at a local shop right now and they should have it looked at tomorrow.
#2 |
Member#: 38825
SCIC
sorry
(thought you needed some sort of reply) |
#3 |
Member#: 58504
South East
Vehicle:2004 STi w/o wing Aspen White / Silver |
Actually, that's a good question....
Does the Boxster arrangement have an interference type design where the pistons and valves occupy the same space, but not at the same time? I know the 4G63 on the old DSM's and the EVO is that way....you lose the timing belt, you tend to shoot the valve through the top of the head. I knew one guy who had it happen and it actually dented his hood.....from the INSIDE! Ouch. -Michael |
#4 |
Member#: 55491
Vehicle:Fit, 1968 Jeep m715, 1976 VW Porsche 914 |
If that is what happened, it will be at the least a new head, pistons, all engine top end. Porbably cheaper just to get a new engine.
Hopefully not. Good luck! Zach |
#5 |
Member#: 57149
NESIC
Vehicle:TMHK Thomas B Hanks First 6 |
SOHC are not interferance engines so your valve SHOULD be OK.
Ben |
#6 |
Member#: 67398
South East
Vehicle:2002 Now with 100% RDA of 2.5l Goodness!!! |
If it was the timing belt the motor wouldn't start or even try to start. I know this because I've broken timing belts on Subies. Fuel pump maybe?
#7 |
Member#: 32371
Vehicle:'02 t-rex wagon platinum |
definitely not timing belt, as mentioned, your car would not have started, but i have to say that it would still be able to crank
if you suspect any engine damage, a quick test would be to perform a compression or leak down test. |
#8 | |
Member#: 36545
...you're like the idiot car salesmen at Subaru who are clueless and only heard the word "boxster" because of Porsche, and think that translates to the "H" engine arrangement! |
#9 |
Member#: 75575
Vehicle:2000 Impreza 2.5RS |
little harsh there buddy
#10 |
Member#: 45790
Well, if it was the fuel pump, then it wouldn't have started either, would it?
It cranks and starts pretty much as normal. On starting it will rev up to maybe 1000RPM for a very brief instant, then stutter and stall. One time as it stalled it backfired out of the intake. Pressing the gas makes no difference whatsoever. Any ideas what it could be then? Like I said; the engine was running great, it was fully warmed up, I ran it WOT for 1 second in 1st gear and it just hit fuel cut and died. |
#11 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:2001 2.5 RS/70 Van 02 WRX Rally Stud |
cam sensor? crank sensor? something simple?
no fluids spilling? no BANG when it stopped? got to be something simple.... get it into a shop. good luck jamie www.subiegal.com |
#12 | |
Member#: 61052
NESIC
Vehicle:1999 2.5 RS White |
#13 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
One of the above, or skipped belt (not broken), maybe huge intake leak.
#14 |
Member#: 67398
South East
I broke a timing belt at the redlight in an 85 GL-10. No bent valves. Mechanic(who was a former dealer mechanic) says they are not interference engines. Maybe your buddy floated his valves? Jamie, can you confirm this?
#15 | |
Member#: 15559
#16 | |
Member#: 874
RMIC
Vehicle:2003 Honda S2000 2004 Mazdaspeed MX-5 |
#17 |
Member#: 67398
South East
BoxSter is the name of one of Porsche's convertibles. Boxer is the terminology applied to engines with a horizontal piston layout. Subaru and Porsche both use boxer engines.
#18 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
My vote is with Mulder and skipped timing belt. Same thing happened on my 1995 2.2L. The EJ25 engines are interference engines but generally the motor stops fast enough you'll just bend a couple valves. Unless some foreign material drops into the cylinder usually the head/piston are fine.
Boxster is the name of a Porsche sport coupe. Boxer is an engine design. |
#19 | |
Member#: 67398
South East
I stand corrected! Thanks! |
#20 | ||
Member#: 45790
I'm leaning towards skipped teeth on the belt. Its in the shop, but it will be a couple days before they will look at it ![]() Thanks for all the suggestions so far. I'm still hoping the engine won't have to be taken apart for this, because I simply don't have the funds for that right now. Last edited by powerlabs; 03-24-2005 at 10:56 AM. |
#21 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
I am glad to see all the misinformation got cleared up before I popped in. lol
Anyways, my first thought is fuel. If for some reason your AFC settings are off or your front O2 sensor is bad, then you may have dumped a piss-ton of fuel in there and fouled out your plugs. Have you pulled one of the plugs to see what they look like? This has happened to more than one RS owner over the years... |
#22 |
Member#: 11354
Vehicle:2009 LGT BF3 tag: Snbrd4evr |
Sam, that totally sucks. Do you smell fuel when you turn the key? I would just check to see if you're getting the main components to starting a car like fuel and spark. If you're getting fuel and spark then it has to be something a little more serious. But look on the bright side, if your engine is shot, then you can just do a wrx swap
, then a few bolt ons and you can smoke me . I guess you're not going to Chicago this weekend ![]() |
#23 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Pull the timing cover and check the timing marks. Then check your idlers and water pump. if the belt skipped then pull the plugs and turn it over by hand to see if your hitting any valves. Don't try starting it again till you find out what's wrong, you may F it up more.
#24 |
Member#: 45790
Yeah, this could not possibly have come at a worst time: I need the car to go to school and to Chicago, and I have no money to fix it if it costs more than a couple hundred bucks.
It is definitely getting fuel and spark because it will start; it just chokes and dies immediatelly after starting. I have a new wideband O2 sensor with a wideband / narrowband signal converter installed now which occasionally makes the car idle very rich or very lean, but the S-AFC is tuned mildly (+8% at 2000RPM, -4% at redline) and the engine runs perfectly at 12.5 - 13.0 while at WOT. I would think if the plugs were fouled it wouldn't try to start? I think the shop is going to check the timing belt, then the plugs and compression. Does anyone know how much replacing the timing belt will cost, typically? If the belt broke and the pistons hit the valves then all bets are off; I'll have it put back together and towed into my garage for a long time until I can afford to have it fixed. |
#25 |
Member#: 832
RMIC
If you didn't hear a catastrophic crunch then your timing belt didn't snap. This is an interference engine and you would have heard metal on metal, and most likely broken a cam gear and the cover.
In light of the wideband O2 sensor info, I am going to stand by my original assessment. If the wiring for the sensor somehow messed up, you absolutely could have dumped way too much fuel in there and fouled your plugs. With fouled plugs, the car would still try to start and run, but they will just be too wet and messy to get a clean spark and stay running. Pull the plugs and inspect them. Should take YOU 20 minutes to do it. If you pay someone $60 an hour to inspect your plugs, you are throwing your money away. Don't start spending any money until you have done the basic assessments of the situation yourself. We can talk you through it... |
| Thread Tools | |
| Display Modes | |
| Help..I Just Blew Up My Engine!! | 05stigi | Texas Impreza Club Forum -- TXIC | 8 | 02-15-2008 06:27 PM |
| I think I finally blew up my transmission... | el tekk-O | Texas Impreza Club Forum -- TXIC | 7 | 08-22-2005 03:00 PM |
| Guess Who Almost Just Blew Up His NEW Engine? | huckedup16 | Off-Topic | 24 | 01-28-2004 12:16 PM |
| Blew up my Engine | Revision | Mid West Subaru Owners Club Forum -- MWSOC | 6 | 09-04-2002 09:49 AM |
| WOOT!!!! I just blew up my car!!! | RiftsWRX | Mid West Subaru Owners Club Forum -- MWSOC | 31 | 01-02-2002 03:50 PM |
