#1 |
Member#: 56964
Vehicle:2004 STi Silver |
I am just wondering if anyone here knows what causes flutter. My major mods are the APS cai, sr55, dr725 and 3" tbe w/cat delete, along with all supporting mods (injectors, fuel pump, ECUTek). The fluttering started after the dr725 was installed. At partial throttle in 4th, 5th or 6th, while maintaining a speed, the car flutters very bad and the whole car shakes. I had the WORX bov and had a few people tell me that was the reason. I changed it to an APS bov and it still flutters badly. I plan on taking it back to my tuner (DynoComp) probably next week but I just wanted to know if anyone else was experiencing this. Thanks in advance for any input. This is on an 04 STi.
Moderators, if this doesn't belong here, please move to correct forum.
#2 |
Member#: 37731
Vehicle:'07 TL-S 6MT '07 RDX-T |
hrm. when i got the aps dr500, i had bad flutter with the worx bov. then i switched to the stock bov...and it still fluttered...so then i got the aps bov, and no flutter.
maybe you have to adjust your bov? maybe its set a little too tight. |
#3 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
too tight? you removed washers, or unscrewed the adjuster to fix your flutter?
#4 |
Member#: 37731
yeah, you can adjust the bolt and screw on the front. ive never adjusted it, but i know it can be.
#5 |
Member#: 7194
Wirelessly posted (blackberry: BlackBerry6280/3.7.1)
Ill give it a try. I always figured that the flutter was a result of not enough tension and that increasing it, would prevent the part thottle flutter. |
#6 |
Member#: 7194
#7 |
Member#: 7194
#8 |
Member#: 7194
#9 |
Member#: 69314
I had the flutter, aps 725 ,fp green , pe 850 and at the time a gfb stealth bov, changed out to an aps bov and no more flutter.
#10 |
Member#: 69314
Could be a leak in system
#11 |
Member#: 7194
Woa... I guess the "back" function of WAP.nasioc.com should be avoided. I had no idea it was re-posting.
| Thread Tools | |
| Display Modes | |
| Rear tires going bad? What caused it? What are some good tires? | elitescouter | Newbies & FAQs | 46 | 05-02-2007 11:14 AM |
| Help! What causes the cat. converter to break? | slamck | Normally Aspirated Powertrain | 11 | 01-23-2002 02:55 AM |
| What causes exaust "POP!" | trojan9x | Normally Aspirated Powertrain | 18 | 06-06-2001 05:11 AM |
| ('93-'01) Turbo kit and CE light issues - what causes it and how to prevent it? | Jessie James | Impreza Forum | 4 | 06-05-2001 09:12 AM |
| what causes fire out of the exhaust? | wop | Factory 2.0L Turbo Powertrain | 14 | 05-02-2001 06:11 PM |
