Old 03-05-2005, 01:58 PM   #1
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
Default UTEC + Perrin Rails = massive over fuel ? HELP
Well Guys I have a host of problem on my set up and I wonder if any of you can lend a hand?
Set up
Greddy t-67 kit
Xx tunning header/up pipe
Perrin fuel rails w/mod injectors
TGV deletes
1 step colder the right ones
TXS RFL-ti
FMIC
UTEC
All of these problems started after installation of the perrin rails and home made TGV deletes. Upon start up it takes a couple of cranks to get her fired up when she is going I see some white smoke and fuel coming out of the exhaust and it sounds like its running on 3 cyl, backfiring and popping . I did a compression test recently and all 4 were with 4-5 psi at 118ish. I get miss fire codes. My first thought is that I have a bad coil and this is causing un-burnt fuel to leak out the exhaust or the perrin rails are dumping so much more fuel that I canít burn it all leading to the miss fires and the backfiring.
Any thought on this issue would be greatly appreciated.
Unfortunately I have no wide band access at this time. Should I go ahead and pony up the 370ish for new coil on plug wires (4 of them) or do I have other issues.
Mav
mavrick is offline   Reply With Quote
Old 03-05-2005, 02:27 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Does it do this after its warmed up? Can you rev it at all? Did you check to make sure all the wires are pluged into the coils?
cdvma is offline   Reply With Quote
Old 03-05-2005, 02:45 PM   #3
HonduHunter
Member#: 28408
2002 vf48ed WRX
i ran perrin rails on a cobb 2.5 map. no problems. its gotta be soemthing else. who tuned your car?
HonduHunter is offline   Reply With Quote
Old 03-05-2005, 03:05 PM   #4
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
The car will rev and run it just pops and backfires like it's running on 3 (i am kittyless but this is not that kinda popping). After it warms up the white smoke dissipates but backfire remains. There is still a little splatter and the exhaust smells strongly of fuel. The car has yet to be tuned for the current set up I am just trying to get a drivable tune to head to the closest dyno 3 hrs away.
mav
Old 03-05-2005, 10:53 PM   #5
x99percent
Member#: 27108
2004 STi
2004 A4
Sounds like someone needs to put the U in UTEC.
Do you have access to an OBD2 scanner? Do you have a friend with Deltadash?
Use *something* that gives you the ability to read the ECU's fuel trims, so that you can make adjustments to the UTEC and get your car running properly.
x99percent is offline   Reply With Quote
Old 03-06-2005, 07:49 AM   #6
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
I figured it was a user problem but I just did not think changing fuel rail would make my car un drivable. so lets say I have $500 ready to spend what should it be used for? Wideband? New coil on plug thingy? Or tow it to the dyno?
Mav
Old 03-06-2005, 09:42 AM   #7
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
Well, I'll ask the obvious question first.... you did change your UTEC injector scaling for the larger injectors, right?
Cosmo is offline   Reply With Quote
Old 03-06-2005, 10:54 AM   #8
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
yes I started with the scaling at 800 and went up to 850 with a minor improvement last night (stock set at 440) still runs like crap. i am at a loss should I spend the money for a delta dash or a wideband or both i have about 500 to spend i need to get this car running right so i can tune it.
Mav
Old 03-06-2005, 12:12 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
If you are going to tune it, spend that money on a wideband and an OBD2 reader. Otherwise just spend that (or less than that) on the dyno tune.
Old 03-06-2005, 01:50 PM   #10
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
Well, "tuning" it yourself without a wideband is pretty risky at best. You may be able to get it close, but you'll never get it right.
However, the problem you are describing sounds like a little more than a tuning issue to me. It's hard to say without seeing it, but with your UTEC set like that, it should run. Rich, but it should run. Yours sounds like it's way too rich.
Did you modify the injectors yourself? I have seen people do it and modify them too much and have problems similar to those you are describing.
Old 03-06-2005, 01:52 PM   #11
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
but right now i don't even think i could drive it to a dyno. i would have to rent a trailer and all that mess. i think i will just go with a deltadash and a lm-1 and start from there. now I just need to find that software that allows you to combine the lm-1 and UTEC logs.
Mav
Old 03-06-2005, 01:59 PM   #12
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
I had deadbolt mod them for me. But what gets me is none of these problems started until I installed the rails. I have triple checked all the vacuum lines I used new gaskets. Itís just PIG rich right now and I am pulling out my hair trying to figure out what to do. I plan on pulling the plugs cleaning them and do another comp. test to see were I am at I just wish I knew of a way to test the coil on plugs so I could figure out which one if any are bad.
Mav
Old 03-06-2005, 02:02 PM   #13
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
also on a side note.. my EGT gauge suddenly went to crap, can a massive over fuel kill the sensor? I have pulled it and every thing seems fine but who knows.
Mav
Old 03-06-2005, 02:17 PM   #14
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
Well, running that rich, I imagine your EGT's would be very low. I haven't heard of excess fuel ruining an EGT sensor, but I guess it's possible.
Did you check things like the throttle cable? I assume you took your intake off to install the rails.
Do you have a stock set of injectors laying around you can put in? Obviously you wouldn't want to drive it with them in there, but that would at least eliminate that problem.
Oh, and here's a link to a program that combines LM-1 and UTEC logs. I haven't used it, but supposedly it works. http://mpsav.com/MPSUTECLogger/MPS_U...r_Download.htm
Old 03-06-2005, 03:07 PM   #15
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
I don't have any stocks as there modded now. My car is a drive bye wire but I can check and make sure everything is connected again. also I have heard of people cleaning that sensor on the top of the throttle body to help things out what do you think?
Mav
Old 03-06-2005, 07:32 PM   #16
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Mav
Why you have 440cc stock setting is beyond me. 550cc is usually the correct stock setting.
FWIW
800cc scaling for the injectors and 550cc stock give perfect ST fuel trims at least on my car and TurboXS shop car using the stock MAF tube.
Wombat North is offline   Reply With Quote
Old 03-06-2005, 08:50 PM   #17
antimullet
Member#: 44193
2008 WRX STi
There is some type of volume change with the addition of rails and it has to be tuned for. I think??? I swore I read it somewhere??
Plus you can actually raise egts to an unsafe level on a really over rich setup be careful. Over lean and well over rich will both raise egts to unsfe levels. I was climbing well past 1600 on a way to fat rich tune on top end pulls.
antimullet is offline   Reply With Quote
Old 03-07-2005, 08:19 AM   #18
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
FWIW
Ahh. I didn't even notice he had an STi. The 440 setting is for the regular WRX. That could be part of your problem right there.
Old 03-07-2005, 09:14 AM   #19
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
I'll go give that a shot and see if that helps out any. on the egt question at idle my gauge just pegs around way past 12000c now I hope there is no this is a correct reading but who knows. The MAF tube I am using came with the Greddy kit and if I am not mistaken is 3.25 ID and the car ran fine before the installation of the fuel rails. I am just pulling my hair out trying to figure out whatís going on here.
Mav
Old 03-07-2005, 09:28 AM   #20
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
I wouldn't be too worried about the EGT's right now. I'd worry about the excessively rich situation first. Once you get your AFR right, if your EGT's still aren't right, then worry about it. Doesn't matter what your EGT's are if your car doesn't run.
Old 03-07-2005, 11:03 AM   #21
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
well now I am going to try the 550 and if that doesnít work I am going to pull the plugs clean and inspect them do another comp test and if none of that works back on go the stock rails and well see what that does I wonder if any one can chime in on their injector scaling with perrin rail and an STI to give me a ball park. But I have scored a used delta dash for a good price and now looking for a Lm-1 to use
Old 03-07-2005, 11:18 AM   #22
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
Injector scaling should be pretty straight forward. Your stock injectors are 550cc. So, for stock you put 550. Then, whatever the flow rate of your new injectors is will go in the other value.
Old 03-07-2005, 11:29 AM   #23
x99percent
Member#: 27108
2004 STi
2004 A4
You don't *have* to put 550 for the stock injector value.
The difference between the two numbers dictates the global MAF adjustment used so that the ECU will provide the proper fueling when it is in control.
The aftermarket injector value dictates the fueling used when the UTEC's OLF is in control.
(Example of this kind of thinking: http://forums.nasioc.com/forums/show...77&postcount=3)
If the car is running rich with 440/800, then 550/800 isn't going to be an improvement.
I still say you need to track down an OBD2 scanner or a copy of DeltaDash to see what the fuel trims are. Until you can see what the ECU is doing, you may as well be blindfolded.
Old 03-07-2005, 12:02 PM   #24
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
No, you don't have to put the actual values in it. I just find it easier to work with the actual numbers, then to be guessing a value and hoping it's close.
Old 03-07-2005, 03:46 PM   #25
x99percent
Member#: 27108
2004 STi
2004 A4
It's not about "guessing", it is about using numbers that *work*... numbers that provide nice fuel-trims and get you very close to proper WOT fueling. That way, the UTEC fuel map needs as little work as possible.
See the link in my previous post for an example.
IL: UTEC, Perrin Fuel Rails, PE 800's, Weisco pistons, Cry O2 Intercooler Sprayer BLUETURBOWRX Private 'For Sale' Classifieds 26 03-03-2006 07:59 PM
Sti Utec, Perrin Fuel Rails, Crucial Thermostats, ETC! Kingpin Engine/Power/Exhaust 2 12-05-2005 01:58 PM
STI Utec, Perrin Fuel rails, and lots more! Kingpin Engine/Power/Exhaust 5 12-01-2005 11:12 AM
Perrin rails with stock fuel pump? racerwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-26-2005 01:17 PM
Fuel soak, perrin rails + sti 550s + UTEC on EJ20 racerwrx Engine Management & Tuning 0 01-11-2005 10:56 AM
