Old 03-24-2005, 12:54 PM   #1
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
Default i just noticed my fuelmap is incomplete?
i filled the incomplete columns in red, i have 05 sti and STOCK INJEC SIZE 550, UTEC INJEC SIZE set to 590cc could this be bad?
Code:
Fuel Map
      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]
      [0]    [3.7]    [3.7]    [3.7]      [4]      [3]    [2.5]    [2.5]    [2.5]    [2.5]    [2.5]
      [0]    [4.7]    [4.7]    [4.7]    [4.9]      [4]    [3.5]    [3.5]    [3.5]    [3.5]    [3.5]
      [0]    [4.9]    [4.9]    [4.9]    [4.9]    [4.9]    [3.8]    [3.8]    [3.8]    [3.8]    [3.8]
      [0]    [4.9]    [4.9]    [4.9]    [5.5]      [5]    [4.2]    [4.2]    [4.2]    [4.2]    [4.2]
      [0]    [2.1]    [2.1]      [3]    [3.3]      [3]      [3]    [3.3]      [4]    [3.7]    [3.5]
      [0]    [1.6]    [1.6]    [2.5]    [2.8]    [2.5]    [3.3]    [3.8]    [4.1]    [4.2]    [4.1]
      [0]    [0.6]    [0.6]    [1.5]    [1.8]    [2.5]    [3.3]    [3.8]    [4.1]    [4.2]    [4.2]
      [0]    [0.6]    [0.6]    [1.5]    [1.8]    [2.1]      [3]    [2.9]    [2.9]    [2.9]      [3]
      [0]    [0.6]    [0.6]    [1.3]    [1.6]    [1.9]    [2.8]    [2.7]    [2.7]    [2.7]    [2.8]
      [0]    [0.4]    [0.4]    [1.1]    [1.4]    [1.5]    [2.8]    [2.7]    [2.7]    [2.8]    [2.9]
      [0]   [-0.1]   [-0.1]    [0.6]    [0.9]    [1.6]    [2.2]    [2.2]    [2.2]    [2.7]    [2.7]
      [0]   [-0.1]   [-0.1]    [0.6]    [0.9]    [1.6]    [2.2]    [2.7]    [2.3]    [2.6]    [2.7]
      [0]   [-0.1]   [-0.1]    [0.6]    [0.9]    [1.6]    [1.8]    [2.1]    [1.9]      [2]    [1.9]
      [0]   [-1.9]   [-1.9]   [-0.6]    [0.4]    [0.2]   [-0.4]   [-0.3]   [-0.3]    [0.8]    [0.8]
      [0]   [-1.9]   [-1.9]   [-0.6]    [0.4]   [-0.3]   [-0.3]   [-0.3]   [-0.1]    [0.8]    [0.8]
      [0]     [-1]   [-1.3]   [-0.6]    [0.4]    [0.4]    [0.4]    [0.3]    [0.4]    [0.9]    [1.8]
    [0.2]   [-1.3]   [-1.3]   [-0.6]    [0.4]    [0.4]    [0.4]      [0]   [0.5]    [1.3]    [1.9]
    [0.5]   [-1.3]   [-1.3]   [-0.6]    [0.4]    [0.4]    [0.4]      [0]   [0.5]    [1.3]    [1.5]
    [0.4]     [-1]     [-1]   [-0.3]    [0.4]    [0.4]    [0.2]   [-0.3]    [0.3]    [0.9]    [1.3]
    [0.4]     [-1]     [-1]   [-0.3]    [0.1]    [0.1]   [-0.1]   [-0.6]      [0]    [0.6]    [1.3]
    [0.5]   [-0.9]   [-0.9]   [-0.2]    [0.2]    [0.2]      [0]   [-0.5]    [0.1]    [0.8]    [1.3]
    [0.5]   [-0.9]   [-0.9]   [-0.2]    [0.2]    [0.2]      [0]   [-0.5]    [0.1]    [0.8]      [1]
      [0]   [-0.9]   [-0.9]   [-0.2]    [0.2]    [0.2]      [0] [-0.5]    [0.1]    [0.8]      [1]
      [0]   [-0.6]   [-0.6]    [0.1]    [0.8]    [0.8]    [0.9]    [0.6]    [1.1]    [1.1]    [1.1]
WRXout is offline   Reply With Quote
Old 03-24-2005, 12:55 PM   #2
happasaiyan
Member#: 37731
how do you figure?
happasaiyan is offline   Reply With Quote
Old 03-24-2005, 12:56 PM   #3
WRXout
Member#: 52908
ASPEN WHITE
it doesnt seem right, at high rpms im going back to stock injectors? when im set to 590?
Old 03-24-2005, 01:00 PM   #4
happasaiyan
Member#: 37731
you do realize that a '0' in the map does not mean stock ecu settings.
the utec has its own underlying fuel map. a '0' in a fuel map other than map 0 just mean there is no percentage of fuel correction applied to the underlying fuel map.
Old 03-24-2005, 01:04 PM   #5
WRXout
Member#: 52908
ASPEN WHITE
ohhhh rger, thank you for clearing that up, you always seem to be their for me, thanks bro
Old 03-24-2005, 01:05 PM   #6
happasaiyan
Member#: 37731
no prob.
Old 03-24-2005, 01:26 PM   #7
feiron
Member#: 62327
2005 WRB STI
[S600BY]
happasaiyan = utec guru on patrol
feiron is offline   Reply With Quote
Old 03-24-2005, 01:56 PM   #8
happasaiyan
Member#: 37731
nah, im just a normal guy who learns from the gurus
Old 03-24-2005, 01:57 PM   #9
WRXout
Member#: 52908
ASPEN WHITE
AFFIRMITIVE, lol, i been playing to mcuh counter strike
Old 03-24-2005, 02:20 PM   #10
WRXout
Member#: 52908
ASPEN WHITE
one more question if i take timing out should i add fuel?
Old 03-24-2005, 02:52 PM   #11
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
No. Usually you can do the opposite - less timing advance and less fuel, vs more advance and fuel. With less advance and fuel, though, you run the risk of having high EGTs. With more advance, you are increasing cylinder pressure, which increases power to a certain point (MBT), but also adds stress to internal components.
serendipity is offline   Reply With Quote
Old 03-24-2005, 02:52 PM   #12
happasaiyan
Member#: 37731
heh. depends.
Old 03-24-2005, 03:15 PM   #13
feiron
Member#: 62327
2005 WRB STI
[S600BY]
just out of curiousity... what is the MBT for the STIs? does the 2.5 block holds more timing advance than the 2.0?
Old 03-24-2005, 03:19 PM   #14
serendipity
Member#: 54597
08 'Busa, 08 ML63
Depends on the stuff around the engine. It's fair to say that at any level of tune (stock to huge turbo), it's probably octane limited. It also varies based on RPM and VE, so there's no single number that's "correct", even for a single example of an engine.
Old 03-24-2005, 03:21 PM   #15
feiron
Member#: 62327
2005 WRB STI
[S600BY]
lets assume, stock internals and turbo... with 93
Old 03-24-2005, 03:58 PM   #16
hippy
Member#: 36528
2002 Impreza Wrx
Depending on the air fuel ratio, rpm, and many other things, mbt will vary. I don't think you can fairly compare the sti engine to the wrx one for many reasons.
peace
Old 03-24-2005, 04:48 PM   #17
TheMadScientist
Member#: 23717
2005 Big red
This only applies if you are NOT running Utec Open Loop Fueling.
My understtanding of MBT is it will happen when peak cylinder pressure happens ~12-15* ATDC. Most of the time on a turbo motor you will be knock limited before you get to MBT. Because you are knock limited and every motor has a different limit, for many different reasons. No one can tell you X timing wil make MBT.
Under the same conditions and octane fuel the larger bore will allow a bit more timing on the 2.5.
TMS
TheMadScientist is offline   Reply With Quote
Old 03-24-2005, 04:56 PM   #18
happasaiyan
Member#: 37731
Originally Posted by TheMadScientist
This only applies if you ARE running Utec Open Loop Fueling.
TMS
fixed.
Old 03-24-2005, 05:03 PM   #19
TheMadScientist
Member#: 23717
2005 Big red
fixed.
Doh
Mmmm.....Homebrew
TMS
Old 03-24-2005, 07:14 PM   #20
serendipity
Member#: 54597
08 'Busa, 08 ML63
TMS
Fair (with correction), but still the point remains - 0 doesn't mean anything other than 0. It's perfectly normal to have your fuel map contain a progression from -0.3 to 0 to 0.3, whether you're running OLF or not.
And the UTEC's background map is very close to the factory static map anyway.
Old 03-25-2005, 06:46 PM   #21
nmyeti
Member#: 4980
The lines left blank in that fuel map are areas of the map that you do not have access to from the UTEC's edit maps menu. While Pete is the real guru with this stuff, I believe that they are just place holders.
-Nathan
nmyeti is offline   Reply With Quote
Old 03-25-2005, 07:08 PM   #22
happasaiyan
Member#: 37731
-Nathan
nathan...you gotta read the whole post.
at first, i thought he was asking the question you answered. but then realized he was just wondering why he had '0's in his map (ie. at 5000rpms @ 70 load).
Old 03-26-2005, 11:20 PM   #23
nmyeti
Member#: 4980
Oops! In that case, sometimes it just works out that way. There is nothing weird about it as the injector pulse width is being calculated by the background map that the end user doesn’t have access to or by the stock ECU depending on your main OLF parameter setting. I agree that it looks weird in the map though and I find myself compelled to put a -.1 or +.1 in those cells for aesthetics. Typically I can fight that urge, although it would be helpful to customers to have a "this cell left intentionally blank" sign to go along with the fuel map.
-Nathan
Old 03-27-2005, 02:16 AM   #24
Division By Zero
Member#: 7555
I think the most important idea here is that a "0", or -.2, or +4, or whatever is irrelevant. I see where you're coming from being new to this so I understand why you ask. Wheather you are tuning your fuel map, or you have a tuner doing this for you, or are starting off with a TXS base map, the numbers you are seeing are based on target AFR's, i.e. you want to be at 11:1 at 4800rpms. Your only concern here is to manipulate the cells in the map so that this happens. And, if you end up with a "0" then so be it. You hit your AFR mark. Try not to make more out of it than that and you're straight.
Todd
Division By Zero is offline   Reply With Quote
just noticed my sti doesnt beep near redline nation1979 Newbies & FAQs 14 05-28-2009 10:21 AM
It is now 1:56pm, returning from lunch i notice my fly is down?! doubledribble Off-Topic 7 10-20-2005 02:17 PM
Dealer just called... My STi is here!!! WR^2X Mid West Subaru Owners Club Forum -- MWSOC 3 05-29-2004 01:57 PM
just pulled my plugs, is this normal? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-29-2004 06:41 PM
