Old 03-24-2005, 01:06 PM   #1
phunkdup
Member#: 60719
2004 WRX
Java Black Pearl
Question CEL but no code found?
So I'm running a cobb stage 1 v1.19 (stage 2 any day now) and I got a CEL last night. Hooked up the AP and it says no code found!
Anyone ever seen the CEL come on without a code? Think it's a problem with the reflash, or with the AP itself?
phunkdup is offline   Reply With Quote
Old 03-24-2005, 01:38 PM   #2
feiron
Member#: 62327
2005 WRB STI
[S600BY]
you might be getting knocks... if the CEL lights up all the time, that means it's a "real" cel.... if it blinks thats a warning that your engine is knocking...
feiron is offline   Reply With Quote
Old 03-24-2005, 01:45 PM   #3
phunkdup
Member#: 60719
2004 WRX
Java Black Pearl
It's steady, not flashing. Does the stock (or cobb) ecu flash for knock?
Old 03-24-2005, 02:21 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The AP does not read all codes...you need a OBDII scanner for that.
Old 03-24-2005, 03:25 PM   #5
phunkdup
Member#: 60719
2004 WRX
Java Black Pearl
P2004, got it pulled at autozone.
Old 09-09-2006, 04:04 PM   #6
rayzz
Member#: 95543
2005 WRX Wagon
Crystal Gray Metallic
i just got this same code after putting on an sti up, anyone have suggestions? (P2004 from autozone). It only comes on after a cold start where the car will run at 2k rpm for 10 seconds and then go down to normal, if I clear, it'll stay off until the next cold start.
rayzz is offline   Reply With Quote
Old 09-10-2006, 12:13 AM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Old 09-15-2006, 11:43 PM   #8
805WRX
Member#: 22920
2005 impreza WRX STi
WR blue
i have the same code, all you have to do is blimp the throttle right after you start the car cold. that will prevent the p2004 from coming on.
805WRX is offline   Reply With Quote
CEL Blinking, no codes found MConte05 Factory 2.0L Turbo Powertrain 3 06-21-2009 02:28 PM
Help (I searched!)- 04 sti CEL but no codes found? Blown95ImpalaSS Factory 2.5L Turbo Powertrain 9 04-28-2009 06:45 PM
CEL but no code?! Shadowdane Factory 2.0L Turbo Powertrain 5 10-31-2007 10:06 PM
Check engine light and cruise light, but no codes found in the Cobb Accessport riggs Factory 2.5L Turbo Powertrain 11 12-12-2005 04:25 PM
Stock 2005 Baja Turbo - CEL But No Codes - Any Ideas NJ Baja Baja Forum 7 09-03-2005 11:45 AM
Message Board Statistics All times are GMT -4. The time now is 02:30 PM.
