Old 03-24-2005, 03:17 PM   #1
WrXaWd
Member#: 53627
2009 WRX
BLING BLING
Default a little Utec help
I have an 03 WRX and im running the STG2 base map off of the TXS web site. It says to set the boost at 16.5. The question i have is in what gear should i set the boost to that? Also, can i run less boost if i want to while staying on the stg 2 map. or can i run more boost while on that map.
Thanks in advance
WrXaWd is offline   Reply With Quote
Old 03-24-2005, 03:40 PM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
should be in 4th, you can always run less... You "can" run more but w/ out proper tuning for it you may lean your car out beyond a safe point and potentially cause damage.
MustGoFast is offline   Reply With Quote
Old 03-24-2005, 03:42 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
set the boost in 4th gear. you can run less boost if you want, but don't go higher than 17psi.
Old 03-24-2005, 03:43 PM   #4
WRXsponge
Member#: 79621
Bug Waggy
3.0 PNP
The map online is only a starting point. Pig rich on fuel, conservative timing, and conservative boost. I would search on this and wrxhackers.com on tuning until your eyes bleed or pc ****s on you. You could save your effort and have it dyno tuned locally. I personally wish I would have gone the dyno tune route sooner- $300: as it was painless and fruitful. The learning curve is rather steep with utec and you need the right gauges to tune yourself. Good luck
WRXsponge is offline   Reply With Quote
A little utec help.. kokob North West Impreza Club Forum -- NWIC 2 12-04-2008 07:21 PM
A little UTEC help, please. StiDreams Engine Management & Tuning 7 07-06-2005 12:41 PM
Little UTEC help please StiDreams Engine Management & Tuning 9 03-24-2005 12:21 PM
utec help? wont switch over into utec drifterx Engine Management & Tuning 3 11-27-2003 01:28 AM
OK... my little UTEC contribution. RiftsWRX Engine Management & Tuning 19 10-04-2002 04:49 PM
