Old 03-24-2005, 07:09 PM   #1
EVOBOXR
Member#: 73648
Default LINK Programming
Ok, I know to increase the Master Fuel, you decrease the #. Is the same principle used for the maps for the Fuel and Ignition?
EVOBOXR is offline   Reply With Quote
Old 03-24-2005, 08:34 PM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Actually, you only do that for Crank Enrichment - Master Fuel and Fuel map goes up if you needed more fuel
kgb is offline   Reply With Quote
Old 03-24-2005, 08:58 PM   #3
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
And again, for your eductation,
Crank enrichment is the ONLY one where a lower # means more fuel.
Geek Guy is offline   Reply With Quote
Old 03-25-2005, 03:45 AM   #4
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Apparently only the Link-1 V5 firmware changes it so that it's all consistent (higher number = more fuel)
Link G4 Xtreme PnP Stand Alone ECU 06-07 Sti akeric Engine/Power/Exhaust 6 06-05-2010 06:00 PM
Link Map Compare Program.. I Wish Engine Management & Tuning 1 04-07-2003 05:11 AM
Link programming? HubbieScooby Engine Management & Tuning 4 10-21-2002 06:26 PM
Link programming...not tuning, programming! HamFist Normally Aspirated with bolt-on Forced Induction Powertrain 1 07-23-2002 06:04 PM
New "Plug and Play" Programable Link ECU from Performance Development ImprezaRS dot com Normally Aspirated Powertrain 36 01-17-2001 04:58 AM
