Old 07-22-2001, 02:30 AM   #1
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Default safe?
would anyone suggest putting a turbo in an engine with 100,000 in it? Mine has thatmany... but i still want!!!
MIke
SubaTubaru is offline   Reply With Quote
Old 07-22-2001, 02:42 AM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
why not. as long as you dont drive like an a$$. then boost and drive appropriatly
Brat
bratmantlz is offline   Reply With Quote
Old 07-22-2001, 02:44 AM   #3
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
hmm.. drive like an ass.... hehehe stranger things havew happened lol i might consider it then
Old 07-22-2001, 02:44 AM   #4
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
just rebuild the motor, its not hard and you can lower the compresion so the motor will be even safer to turbo : )
NateDogg is offline   Reply With Quote
Old 07-22-2001, 02:45 AM   #5
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
but rebuilding would cost a lot no? what does rebuilding consist of anyways? what u thik i should do?
Old 07-22-2001, 05:15 AM   #6
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
i dont think i am going to do it due to cost of install
mike
Old 07-22-2001, 07:34 AM   #7
PunksWRX
Member#: 5504
2004 Impreza WRX STi
You can do a compression check and leakdown on your engine to determine what kind of condition the engine is in. Is your oil pressure good? If everything checks out you will probably be OK as long as you are easy on the boost. The engine will eventually need engine work though if you really want to get long term relaible power out of it.
As far a a rebuild it ususally consists of new over-size pistons (a great time to lower compression ratio for a boosted motor), new rings, new crankshaft and rod bearings, and new oil pump. Other parts that might (usually) need replaced due to wear include camshafts, valve springs, lifters, and valves. A new gasket set with seals is required as well as a new timing belt set.
The rebuild will also consist of expert machining services to bore, deck and align hone the block. Machining is also required to rebuild the heads. The proper ring and bearing clearances will have to be checked and adjusted. The connecting rods usually need reconditioning or better yet replaced with a stronger aftermarket unit for a boosted motor. Finally, the entire reciprocating assembly should be properly balanced.
Definitely a job for an experienced mechanic if you decide to do it yourself.
Punk
PunksWRX is offline   Reply With Quote
Old 07-22-2001, 05:46 PM   #8
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
I will bring my car to a mechanic on an off day and get a compression check done and see how my engine checks out.
Mike
Old 07-22-2001, 07:13 PM   #9
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
I would, why not. if you blow up anything then you need a rebuild anyway right. what are you going to do pound some barring, blow a piston, any of that dose a will happen if it`s a new eng. so go for it and if something brakes then at lest you didn`t spend alot of $ on a rebuild aready right. look at it as a dry run once you get it tuned right then rebuild it I`m just looking at it like this your not going to damage the turbo just the eng. if something brakes. that is unless your turbo dosn`t get oil. that wouldn`t be good.
milkman is offline   Reply With Quote
Old 07-22-2001, 09:39 PM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Cool hrm...
do you know mike?
hahah
Aaron
hahahah
m750 is offline   Reply With Quote
Old 07-22-2001, 10:09 PM   #11
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Aaron's got a point there
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Conjunction Junction, what's your function?
Old 07-23-2001, 12:46 AM   #12
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
brian and arron... Yall got to come for a normal drive with me :-) the only one here that really knwos how i drive is joe! lol
and the state troopers of Maine VT NH MA CT NJ and NC
Lol
mike
SOCAL: Snow Performance safe injection fail safe module BiggSean Engine/Power/Exhaust 1 01-12-2007 01:38 PM
Anyone here know about or are from Brooklyn, safe not safe? WoohooRX Tri-State Area Forum 2 09-02-2006 07:40 PM
McComick place parking...safe or not safe for modded cars during show? kenchan Mid West Subaru Owners Club Forum -- MWSOC 15 04-24-2003 01:26 PM
safe or not safe? VOLTIS5 Legacy Forum 11 09-28-2001 11:45 PM
Safe place to get a Safe turbo kit? MichiganRS Normally Aspirated Powertrain 3 04-02-2001 07:29 AM
