Old 03-24-2005, 09:28 PM   #1
dt311
Member#: 80478
02 WRX
Default retune when bored out?
If you have your engine rebuilt and bored out do you need to get it retuned. I have a UTEC and my car is a stage 4 setup. Or doesn't it make that much of a difference.
Thanks
Joe
dt311 is offline   Reply With Quote
Old 03-24-2005, 09:47 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Yes, retune it.
serendipity is offline   Reply With Quote
Old 03-25-2005, 04:49 AM   #3
Bill
Member#: 5081
2010 STI
Dark Grey
I just put a 2.5L block in my car, but kept everything else pretty much stock. We are breaking it in without the the UTEC and stuff first. And we have had no trouble with the car... idles well, no check engine lights, etc. A quick road test with a GPS data logger says 215 to 220 wheel horse power. I'm sure I'm leaving alot of power un-tapped, but the stock ecu seems remarkably flexible.
Bill is offline   Reply With Quote
Old 03-25-2005, 09:38 AM   #4
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I would retune it.
Need4Boost is offline   Reply With Quote
Old 03-25-2005, 10:26 AM   #5
jimmyd
Member#: 38766
2003 WRX Sedan
Depends on how big you went. If you just cleaned up the cylinders (.010 over) I would think that (unless your tuned on the raged edge) you'd be ok. With a 25% increase in displacement (like the post above) I would definetly retune!
Jimmyd
jimmyd is offline   Reply With Quote
Old 03-25-2005, 01:15 PM   #6
Division By Zero
Member#: 7555
Yeah what did you do exactly? You could get away with not touching anything if you; 1.) honed and replaced or 2.) went oversized by say .010. If you went .020 over you would probably want to retune and you would absolutely have to retune for a 2.5L over the 2L.
The above is assuming that you weren't at the edge of safety. Even going with a rebuild and resurfacing the cylinder walls and new rings could change the way your engine behaives, especially if you had a problem on your last engine at the time of tuning.
Todd
Division By Zero is offline   Reply With Quote
Old 03-27-2005, 12:31 AM   #7
antimullet
Member#: 44193
2008 WRX STi
If you are increasing the displacement, with the same ecu you'd be altering the volumetric efficiency that the ECU thinks it would see right? So you should need to tune fuel and timing as a minimum. Need more air to fill the chambers, means ya need more fuel too.
antimullet is offline   Reply With Quote
Old 03-28-2005, 11:59 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's why we have a maf sensor. maf-based systems do NOT require retunes to correct for VE changes.
the real issue is that you're using different load sites... probably ones you have never previously used, and therefore you don't really have any idea how the car is going to react.
folks, the change in charge air mass / rev for a 20 thou overbore is TINY... probably less than taking off the oem axleback.
Old 03-28-2005, 02:28 PM   #9
Division By Zero
Member#: 7555
It's to my understanding that the MAF sensor adds or subtracts timing on the the air flow as well.
Old 03-28-2005, 05:07 PM   #10
dt311
Member#: 80478
02 WRX
thanks for all the input guys. The engine was only bored .010. So I guess from what I hear it shouldn't be that much of a difference.
Thanks
Joe
Old 03-28-2005, 05:56 PM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, on the oem ecu the load cell is calculated from charge air per cylinder. if that changes, then target afr and ignition timing MAY be changed. that's the thing about different load sites.
the utec, however, doesn't change timing on anything but MAP and RPM. so far at least...
You Know when its time for a retune when... Sleepy60 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-06-2009 01:48 AM
Need retune when removing cat? gdubduc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-24-2008 08:29 PM
What do u do when bored @ work??? Drink Off-Topic 15 05-30-2006 02:05 PM
What websites do you go to when BORED at WORK? INFIDEL Off-Topic 22 08-09-2005 08:31 PM
What to do when bored at work at midnight??? (pics) WRXGuyInUSA Off-Topic 32 05-05-2005 12:31 AM
