Old 03-24-2005, 09:33 PM   #1
Soobie22
Member#: 71118
2007 WRX TR 07'
Default WRX engine swap drivetrain question
I am doing a wrx swap into my legacy i am keeping my legacy tranny and going have it bolted up to the wrx engine i was wondering if i have to buy a wrx flywheel and buy the legacy clutch or do i have to buy everything to match the legacy tranny for ex: i have to buy legacy flywheel and legacy cluch and information on this will help me out a lot thanks
Soobie22 is offline   Reply With Quote
Old 03-25-2005, 11:17 AM   #2
Randoramma
Member#: 60649
00RS EJ205 swap
I believe you would want everything to match the legacy tranny. Flywheel and clutch. The question is, "Does the WRX and Legacy have the same clutch mechanism?" This I do not know.
Randy
Randoramma is offline   Reply With Quote
Old 03-25-2005, 11:52 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the clutch/flywheel has to match legacy "push" tranny.. a wrx is a "pull"
get an ACT street clutch (stock won't cut it) use the stock flywheel (you should have it resurfaced) and call it done
Old 03-26-2005, 06:18 PM   #4
Soobie22
Member#: 71118
2007 WRX TR 07'
i wanted it to be a lightweight flywheel
Old 03-26-2005, 08:26 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
jeeze arn't we needy
then get a light weight flywheel for a 99 legacy
Old 03-27-2005, 08:53 PM   #6
Soobie22
Member#: 71118
2007 WRX TR 07'
why a 99
Old 03-27-2005, 09:03 PM   #7
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Hey good luck with your swap… I’m right in the middle of a WRX swap into my 98 BD as well… Good to see some more late model turbo Legacy’s around.
Jaxx is correct the Legacy is a pull as opposed to the WRX push fork. Personally I’m swapping in a WRX 5MT and rear diff to get rid an ailing AT…
Can’t wait to see the finished project
xcntrk75 is offline   Reply With Quote
02 WRX Engine Trans Drivetrain FULL SWAP 114k mi. WRXlerate Engine/Power/Exhaust 5 06-20-2008 04:09 AM
WRX Engine Swap Question rs2.5-3.0 Subaru Conversions 3 02-23-2005 07:10 AM
WRX Engine Swap Question rs2.5-3.0 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2005 11:01 PM
WRX engine swap radiator questions. Homemade WRX Subaru Conversions 10 07-08-2003 05:49 PM
WRX to RS engine swap exhaust questions racer25rs Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-20-2002 02:04 PM
