Old 03-28-2005, 12:49 PM   #1
97subGT
Member#: 41323
Sedona
Default spark plug problem
i have a wrx with a 2.5 sti short block with stock 2.0 heads and stock intake manfold. pretty much everything else is stock except for a perrin up pipe and a injen colder intake.
first the engine will start to sound like it is knocking pretty loud after about 10mins of driving. and then when i remove the suspected plug you are able to freely turn the porcelien (from tip to tip) inside of the metal part. i have driven the car with this setup for about 700 miles and this has happen twice in two different cylenders. The plugs that i am using are denso Iridiums
has anybody else had this problem or know how to fix this problem if so how did you fix? i am think colder plugs.
97subGT is offline   Reply With Quote
Coil pack or spark plug problems? dt311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-31-2005 02:38 PM
Weird spark plug problem jasona Normally Aspirated Powertrain 9 04-29-2005 06:27 PM
Check Engine light + Spark Plug problem elum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-14-2004 03:06 AM
spark plug problem now fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-30-2002 09:00 PM
spark plug problem? knightsnke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-27-2002 09:12 PM
