Old 03-24-2005, 11:29 PM   #1
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Default quick ? bout COBB AP
what base map did you all flash with? I wasnt sure, so I just did the stock map.
Crash477 is offline   Reply With Quote
Old 03-24-2005, 11:39 PM   #2
gjhsu
Member#: 12329
2oo7 R56 mcs
Blue, but not WRB
stage 1 93 octane base map. Set and forget
gjhsu is offline   Reply With Quote
Old 03-24-2005, 11:42 PM   #3
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
thats the real time map im running now. I will change it to the base map tomorrow. thanks
Old 03-25-2005, 12:14 AM   #4
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Running a realtime Stg 1 over a stock basemap has no effect, to my knowledge.
mcowger is offline   Reply With Quote
Old 03-25-2005, 12:26 AM   #5
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
well i am going to change to Stg 1 93 oct base map tomororw..
Old 03-25-2005, 02:33 AM   #6
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Incorrect. You get stage 1 boost, timing and fuel, but not other changes which can only be stored in the base map.
You want to run the base map that corresponds with the real-time map you plan on running the majority of the time for maximum performance and reliability.
drees is offline   Reply With Quote
Old 03-25-2005, 10:50 AM   #7
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
awesome. So do I still need to run the real time map, even when I have the Stg 1 93 Oct base map?
thanks
Old 03-25-2005, 10:55 AM   #8
boxered
Member#: 61884
thanks
You don't have to run a realtime map but realtime mapping contains extra logic parameters that help maximize the performance of the base map.
boxered is offline   Reply With Quote
Old 03-25-2005, 11:02 AM   #9
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
ok good to know.. thanks everyone..
Old 03-25-2005, 11:51 AM   #10
drees
Member#: 25905
2003 Silver Wagon
Sorry, this is incorrect as well.
When you load a base map, it loads the corresponding realtime map as well at the same time. Loading a realtime map over the same basemap doesn't change a thing (as long as you haven't loaded some other realtime map after the basemap flash).
That said, it doesn't hurt to load the same realtime map after a flashing a basemap so go ahead and do it if you are superstitious.
Old 03-25-2005, 12:02 PM   #11
bigwrxguy
Member#: 80550
04 STI
blue/gold wheels
I just got my accessport and I'm running stage 1 93oct what should i run as the real time map?
Also I'm hitting 16psi in 4th.
bigwrxguy is offline   Reply With Quote
Old 03-25-2005, 12:12 PM   #12
drees
Member#: 25905
2003 Silver Wagon
When running the Stage 1 base map, you do not need to load any other realtime map over it! You are now running the Stage 1 real-time map.
If you come across conditions where it might be beneficial to run a different map (IE, bad gas, flash stock realtime map, parking in high theft area, flash security realtime map, valeting the car, flash the valet realtime map, then flash the corresponding real time map. When things are back to normal, flash the real-time map which corresponds to the base map again.
Hope this helps, it's not that hard!
Old 03-25-2005, 04:45 PM   #13
boxered
Member#: 61884
Well, just read through my '04 AP manual and it doesn't say anything about it loading base and realtime, initially. Perhaps that's new for the '05.
Crash477..here's A better explaination of the differences between base and realtime..straight from the horse's mouth..
http://www.wrxforum.com/cgi-bin/ulti...;f=11;t=001121
Old 03-25-2005, 06:15 PM   #14
drees
Member#: 25905
2003 Silver Wagon
Base maps INCLUDE the real-time map which is why loading a real-time map over a base map is redundant if you have not switched real-time maps.
Old 03-25-2005, 06:20 PM   #15
crazymikie
Member#: 56321
2008 Lexus IS-F
If you load the 93 octane stage 2 base map, it has the same effect as loading the 93 octane stage 2 base map and then the 93 octane stage 2 realtime map (except you wasted 2 mins)
Mike
crazymikie is offline   Reply With Quote
Old 03-25-2005, 10:55 PM   #16
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
so here's another question for you.. I dont have any boost, or other type of gauges yet. ANy problems.. I plan on getting the 2 gauge bezzel that goes behind the steering wheel around the instrument pannel. I plan on a boost and EGT..
ANother question now. I heard that since my uppipe and downpipe are both catless that I do not need an EGT now, because the EGT only looks at temps which will then cause the cat to melt.. since I dont have a cat, I dont need one then right?
Old 03-25-2005, 11:44 PM   #17
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
1) Get the gauges - they are critical to monitoring your car.
2) EGTs matter for your engine AND your cat. You need to worry about EGTs even on a fully catless car.
Old 03-26-2005, 12:01 AM   #18
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
OK, then I will stick to the plan of Boost and EGT gauges.. thanks.
Old 04-08-2005, 09:24 PM   #19
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
sorry to bump my old thread but have another question for you all.
When you installed your up/tbe or any power mod, did you reset teh ecu via disconecting the neg battery method, or just using the reset ecu feature on the AP? Which is best. I have a gutted up, and full tbe now, i reset using the AP, do I need to do a "hard" reset?
Thanks,
Steven
Old 04-09-2005, 08:59 AM   #20
wrxaru02
Member#: 60573
2002 WRX Wagon
The AP ECU reset will clear CELs but does not erase any of the learning...When you flash a new base map it erases the learning.
When I installed my DP, I flashed the stg2 base map and enjoyed
wrxaru02 is offline   Reply With Quote
Old 04-09-2005, 12:38 PM   #21
timmah
Member#: 54203
2011 WRX
Please, read the manual people.
timmah is offline   Reply With Quote
FS: cobb AP v2 sub 001 $450 norcalwrx816 Engine/Power/Exhaust 30 06-02-2010 10:08 PM
Cobb AP V1 for 2004 wrx Project Blackhawk Private 'Wanted' Classifieds 1 06-02-2010 06:32 PM
quick help... Cobb AP uses 5VDC transformer correct??? VajraTLR Engine Management & Tuning 1 01-16-2007 11:24 PM
Where can I get a Cobb AP quickly? slikrik05 Engine Management & Tuning 27 08-14-2005 11:48 AM
?2 quick questions about Cobb AP,DP? wrxxed Engine Management & Tuning 5 04-03-2005 01:41 PM
Message Board Statistics All times are GMT -4. The time now is 04:19 AM.
