Old 03-25-2005, 06:54 AM   #1
Seeing StaRS
Member#: 5294
Default Change your PCV valve
I just wanted to post a suggestion to the N/A folks to think about changing your PCV valve if you haven't done so recently. I did mine today and (call me crazy) but the car did seem to run better. A fresh PCV valve is supposed to help improve idle, reduce oil consumption and improve gas mileage a tick or so.
I dunno I just thought it would be worthy of suggesting to everyone since it made my car run a little better.
2000 RS brp coupe 65k miles
joe
For those who need assistance:
http://www.northursalia.com/m...n/pcv/pcv.html
Seeing StaRS is offline   Reply With Quote
Old 03-25-2005, 10:43 AM   #2
Impreza_RX
Member#: 68015
2006 WRX TR
Steel Gray Metallic
What exactly is a PCV Valve?
Last edited by advanrs; 03-25-2005 at 10:44 AM. Reason: Typed Valva instead of Valve
Impreza_RX is offline   Reply With Quote
Old 03-25-2005, 11:31 AM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
How many miles did you have on yours?
RS_to_WRX_swap is offline   Reply With Quote
Old 03-25-2005, 12:11 PM   #4
Lavery
Member#: 77896
98 impreza 2.5rs
2nd this...What does the valve regulate?
Lavery is offline   Reply With Quote
Old 03-25-2005, 03:41 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
P ositive.C rankcase.V entilation.
"This system reduces HC emissions by drawing fuel and oil vapors from the crankcase and sending them into the intake manifold, where they are delivered to and burned in the cylinders. This system prevents the pressurized vapors from escaping the engine and entering the atmosphere."
source:Automotive technology: a systems approach. 3rd edition.
author: Jack Erjavic.
Tim Sanderson is offline   Reply With Quote
Old 03-25-2005, 05:24 PM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I don't believe the newer models (like my 04) have a PCV. I think its just a metered port.
OneOBS is offline   Reply With Quote
Old 03-25-2005, 06:14 PM   #7
Lavery
Member#: 77896
98 impreza 2.5rs
Good info Tim, thanks
Old 03-25-2005, 07:52 PM   #8
Seeing StaRS
Member#: 5294
Unless it had been done under the previous owner of my car, I'm assuming it had never been done. (65k miles)
joe
Old 03-26-2005, 12:13 AM   #9
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
I changed mine on my 2002 RS with 32000 miles. Its part of the 30k service. Its a good thing to do. I noticed the car felt better, better fuel mileage too.
Crash477 is offline   Reply With Quote
Old 03-26-2005, 12:25 AM   #10
cmsrally
Member#: 68308
2000 2.5 RS
is it easy to swap out?
cmsrally is offline   Reply With Quote
Old 03-26-2005, 12:32 AM   #11
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
yeah it was for me because we had the engine out, and the intake manifold off. but it shouldnt be hard.
Old 03-26-2005, 12:41 AM   #12
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Yes. Very. I did it in 5 mins with an open-ended wrench.
bongchild is offline   Reply With Quote
Old 03-26-2005, 05:54 AM   #13
Hola
Member#: 80082
I did the one on my Legacy last week and it seemed to smooth out the idle a little.
Hola is offline   Reply With Quote
Old 03-26-2005, 09:26 PM   #14
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
another plus. the valve's like 2$ and takes that many minutes to change.
t3hWIT is offline   Reply With Quote
Old 03-26-2005, 09:37 PM   #15
keirnna
Member#: 50167
1996 Subaru STI RA
Dang, I should have ordered one from Subaruparts.com when I ordered all of my other tune up parts. I didn't know what it was for so I held off. Hopefully the dealer has one.
keirnna is offline   Reply With Quote
Old 03-27-2005, 03:54 AM   #16
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
This is by far the eaiset thing to do to your car. It only takes like 3 min. Note that it is actually recomended that you change your PCV valve every 15k miles along with your fuel filter.
X4 SRT is offline   Reply With Quote
Old 03-27-2005, 10:58 AM   #17
Jejunum
Member#: 15773
2011 Impreza WRX
i believe u are wrong x4. fuel filter & pcv valve are 30k mile maintenance items...
Jejunum is offline   Reply With Quote
Old 03-27-2005, 12:23 PM   #18
feelthebreak
Member#: 32411
i`m going to change mine at 15,000.
feelthebreak is offline   Reply With Quote
Old 03-27-2005, 05:19 PM   #19
Seeing StaRS
Member#: 5294
well regardless of when you change it, the thing that matters is that it actually gets done right guys?
joe
Old 03-28-2005, 05:15 AM   #20
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Yep. I'm wrong. Recomended interval between fuel filter replacement is 30k miles.
Old 04-04-2005, 10:26 PM   #21
Evan_Ng
Member#: 45548
2004 Impreza
SIlver
Are the 04RS Pcv valves different?
cuz of the intake manifold?
Evan_Ng is offline   Reply With Quote
Old 04-04-2005, 10:59 PM   #22
Siper2
Member#: 1134
2007 BMW 328xi wagon
I believe that Brian at www.subaruwrxparts.com recommends every 15k or so for changing this thing. Which really is ridiculously easy, it's like a 17mm socket and two minutes of your time.
I've only changed mine once, several months ago, but before that honestly I'm not sure how often mine was swapped. I had dealerships do my services back then.
Siper2 is offline   Reply With Quote
Old 04-05-2005, 04:19 PM   #23
Evan_Ng
Member#: 45548
2004 Impreza
SIlver
btw just to let you guys who drive the 04RS with the plastic intake manifold. The pcv valve is NOT located on the intake manifold. It's actually located on the block. If the car is facing towards you, the valve is located on the left side of the block. Happy finding.
Old 04-05-2005, 04:25 PM   #24
skunkfifty
Member#: 73102
1998 legacy outback
white
take note anyone whos motor is using oil. a faulty PCV valve will cause some oil consumption.
replace your old one and your consumption may go down, if thats the case anyway. mine did. ymmv.
skunkfifty is offline   Reply With Quote
Old 04-05-2005, 09:04 PM   #25
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I'm having trouble finding the right PCV valve for my 2003 RS. Autozone gave me the one for previous years. Anyone else have the same problem?
should I change the pcv valve every year ? machinistboy99 Newbies & FAQs 3 06-02-2010 09:24 PM
PCV Valve Changed sanders Normally Aspirated with bolt-on Forced Induction Powertrain 14 09-03-2004 11:48 PM
How do you change the pcv valve? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-27-2004 04:25 PM
PCV valve changing interval Flexy Service & Maintenance 21 04-10-2003 07:22 PM
want to change PCV Valve and fuel filter, how and where are they, and steps? joostin420 General Forum Archive 6 12-13-2000 12:35 PM
