Old 03-25-2005, 12:21 PM   #1
rhd
Member#: 81820
2003 WRX sedan
Sedona
Default Getting my AEM EMS soon
well, i've decided to just go with the proven AEM EMS for my 03 wrx.......i haven't got much feedback from ppl using it...but, that's cool. so, i'll ask again........is there really anyone else running it?
rhd is offline   Reply With Quote
Old 03-25-2005, 12:25 PM   #2
AspWhtRex
Member#: 29393
2015 WRX
wrbp
my friend is running one in his supra. many supra owners use it and they love it!
AspWhtRex is offline   Reply With Quote
Old 03-25-2005, 12:33 PM   #3
rhd
Member#: 81820
2003 WRX sedan
Sedona
yeah, i knowthe supra guys love them....my friend jason tunes them all the time. i'll be his first WRX though
Old 03-25-2005, 01:34 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...good luck.....don't try to go too lean....leaner than 11:1 gets dangerous....and beware too much timing....a wideband, EGT and knocklink would be wise.....many small steps finish the journey faster than a few big steps.......get with STiTuner(Brad) and see if he can help.....
Old 03-25-2005, 01:49 PM   #5
rhd
Member#: 81820
2003 WRX sedan
Sedona
i take it back, jason has done subaru's before...just none in this state. he's going leaner than 11.5:1 and picked up HELLA power.........and driveability, so i'll just leave it in his hand. sure subaru's like runnin rich...but, come on..it's not an RX-7 :P
Old 03-25-2005, 01:50 PM   #6
rhd
Member#: 81820
2003 WRX sedan
Sedona
oh, and i'm getting hte built in wideband...and have a greddy egt gauge. i might see about getting an ems egt..i think they offer one for the subaru...not sure
basically, i just want rid of that damn maf...i HATE those things
Old 03-25-2005, 05:30 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
...depending on where it is lean...like under 9 or 10 or so PSI.....mebbe.....but det kills subie motors QUICK!!!!!!!!! You can NOT det an EJ20 like you can a 4G63 and have it live long.
One good hard knock will kill an EJ20.
I predict a broken ring land on #4.
Old 03-26-2005, 01:51 AM   #8
rhd
Member#: 81820
2003 WRX sedan
Sedona
i'm sure hondas are much worse..........well, my last couple built engines were.... but, no biggie, i'm not worried about even seeing knock. jason's one of hte best tuners in the country, so he knows what he's doing
Old 03-26-2005, 10:28 AM   #9
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
don't go too lean and not too much timing. Great advice!
el~sharko is offline   Reply With Quote
Old 03-26-2005, 11:23 AM   #10
rhd
Member#: 81820
2003 WRX sedan
Sedona
haha, i know...right
Old 03-26-2005, 12:12 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
...well some of these n00bs pop their motors on the first pull 'cuz they tuned it 'jus lyk all dem udder jap karz'......
Old 03-26-2005, 12:30 PM   #12
rhd
Member#: 81820
2003 WRX sedan
Sedona
it's funny you insist subaru's "are so different" but everything wants air/fuel/timing...just finding the right combination isn't THAT hard. an engine is an engine...they're all just big air pumps
Old 03-26-2005, 12:43 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....well.....just read the last sentence of post #7, again....well see how long it takes.
Old 03-26-2005, 12:44 PM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
You really don't need the EGT function with the EMS, I'ld settle for the UEGO, and MAP setup, thats all you're going to need. You get the right mapping and looking at EGT's won't matter.
there is a WRX locally running an EMS, which has put down some pretty good numbers.
Tuning an AEM takes a LONG time for a street car since there are so many different maps in it. Decel and accel, all sorts of correction maps, cold start. It will take about 2 weeks, not a couple of hours to get it perfect.
congrats on the purchase though, once you get it right you'll be amazed with it.
STiTuner is offline   Reply With Quote
Old 03-26-2005, 12:47 PM   #15
rhd
Member#: 81820
2003 WRX sedan
Sedona
i'm getting the built in w/b.....and am swapping over to a map only
that's honestly the biggest reason i want an EMS...i want rid of the damn MAF
Old 03-26-2005, 01:31 PM   #16
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
Ive got am AEM EMS works great. I use the AEM wideband gauge interfaced with the EMS. There are tons and tons of different maps and settings in the EMS. As far as the EGT sensor if you already have a gauge just use that, However the EMS has 4 EGT inputs that can trim fuel for individual cyliders depends on the EGT this could be very useful for the suby since a few cyliders run hotter. This requires 4 AEM EGT sensors they are not the normal type. Here is a little info to get you going with the EMS.
1. Goto http://www.aempower.com and register for the aem electronics forums
2. Download the WRX Timing Error Update Firmware for your EMS.
3. DO NOT RUN THE MAF MAP ITS BAD!!, The EMS comes with a base map that will utilize the WRX Factory Map Sensor. You need to buy an AIT Sensor kit from AEM then you can elminate the MAF. The EMS uses the factory MAF for air temp correction only.
4. Lookup on the AEM forums the GM Boost Control Solenoid part number and the pigtail for it. The factory BCS is not very stable with the EMS and I was hitting 18.4 PSI on the stock turbo NOT GOOD. Follow the instructions for setting up the GM solenoid. GM solenoid is kindy noisy (clicks) but will hold your target boost very good. I am going to purchase the Perrin EBCS later on and test it out.
That should get you going on the basics. Shoot me a PM or post here if you need help. The EMS is a very powerful engine management system, I dont understand why so many people in the subaru community look down upon it when its been proven time and time again elsewhere.
snwman is offline   Reply With Quote
Old 03-26-2005, 01:47 PM   #17
rhd
Member#: 81820
2003 WRX sedan
Sedona
Jdogg is my tuner.....if you're on the EMS board, i'm sure you've run accross him
Old 03-26-2005, 03:32 PM   #18
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
well you should be good to go then if you got a tuner...
AEM EMS coming VERY SOON! Red Rocket Engine Management & Tuning 11 08-02-2010 02:04 AM
Tune my AEM EMS 12.9$500rex Other Engine Management 6 07-27-2009 03:49 AM
getting my 09 back soon CANNIBALOFDOOM General Community 9 03-28-2009 07:38 PM
Why I love my AEM EMS...let me count the reasons.... FreeBMW Engine Management & Tuning 2 05-27-2005 11:34 AM
Getting my '02 WRX Soon... eclipsefire General Forum Archive 8 03-29-2001 12:51 AM
