03-25-2005, 12:24 PM | #1 |
Member#: 43288
NWIC
Vehicle:2005 Legacy GT Ltd. Granite Red Pearl |
Is there a way to put the gauges from an STI in a 03 RS?
Has anyone done this before? Is it possible? I am talking about the speedometer/tackometer gauges.
I really like the look! Jonathan
06-15-2005, 03:15 PM | #2 |
Member#: 76081
SWIC
Vehicle:2005 Impreza 2.5RS Blue Ridge Pearl |
yea
Yea, I would like to do the same thing with my '05. I dont know if they are just plug and play. I know the STI comes with a temp. output. Well, let me know if you find out if it is possible.
07-04-2005, 07:49 PM | #3 |
Member#: 76081
SWIC
hmmmm
I guess no one knows anything
07-04-2005, 07:53 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Yes it can be done, and there are many threads on the subject.
07-05-2005, 03:46 PM | #5 |
Member#: 14771
NWIC
Vehicle:02 RS All Silver! |
Yea, I want to do this too. I just want the "beep beep beep"
I guess I'll search later... Geoff Edit: searched and it looks like there are NO threads on the subject of swapping an STi cluster into a GD RS. A few about swapping JDM clusters into GC8 RSs, but that doesn't help us much. If I'm wrong and their are threads about this, please link us. Thanks Last edited by ej25power; 07-05-2005 at 07:47 PM. |
07-06-2005, 08:22 PM | #6 |
Member#: 14771
NWIC
I called subaruwrxparts.com today (they have the STi cluster in the RS section) and they said it was plug and play for us too. I'm a little skeptical though....I'll see if I can find someone with a WRX or STi who will let me swap their cluster for testing purposes.
07-07-2005, 07:25 PM | #7 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
will a newer STi Cluster go into an older RS? I really like the look of them and wouldn't mind putting them in my 98
07-07-2005, 07:56 PM | #8 |
Member#: 14771
NWIC
From what I read, certain JDM STi clusters are plug and play into different year GCs. I forget which ones plug into which ones though. I think yours would use the v3 cluster...but don't quote me on that.
07-07-2005, 08:21 PM | #9 |
Member#: 29355
NWIC
all you need to know is that
1) all the information you're looking for can be found using the search function. it's always better to search than post. 2) it can be done but it's not plug and play 3) doing so will permenently void ALL of your warrenty, if you're still under warrenty. |
07-07-2005, 10:43 PM | #10 |
Member#: 67247
Vehicle:2003 2.5RS BRP SQC 189 |
handsdown, an oil change not done by SOA voids your warranty!
07-08-2005, 01:27 PM | #11 |
Member#: 85337
NWIC
Vehicle:96 LX Coupe Not sure right now. |
a 2004 sti cluster went smoothly into my buddies 96 impreza L sedan. wasnt plug and play, just some small modifications need to be done. not sure, but if you want more info, get back to me, and i can find out.
08-25-2005, 08:50 PM | #12 |
Member#: 25808
SCIC
Vehicle:2003 Impreza RS STI---->Prodrive |
A 2004 STI CLuster is plug'n play onto my 2003 Impreza RS sedan.
Damn! It looks really really bright. You know u have to cut 1 wire(B28), R.Diff Temp and DCCD lights on, right? And it reads speed a little bit faster(+1or2mph) than your original one. i think it is because STI have 160mph and i have 120 or WRX has 140mph, so looks like STI cluster hard to define what is 77 or 78 mph, you know what i mean?? Don't know who did it. But I am sure this 2004 STI cluster can work on 02-03RS,TS, or outback. I will post pictures if you want. But i would like to know how i can post the picture to NASOC directly from somewhere. |
08-25-2005, 09:30 PM | #13 |
Trust no one
Instructions for posting pictures-
http://www.nasioc.com/forums/showthr...hreadid=110137 |
08-25-2005, 10:02 PM | #14 |
Member#: 25808
SCIC
thanks!
09-28-2005, 06:23 PM | #15 | |
Member#: 33869
Vehicle:2002 wrx rally blue |
09-29-2005, 12:02 PM | #16 |
Member#: 69991
NESIC
Vehicle:Leh Keen Approved '68 Volvo Amazon |
yes, resistors!large resistors. also try ur cruise light. set should work but cruise prob wont
09-29-2005, 01:19 PM | #17 |
Member#: 33869
Which pin you have to put resistors into for the R.diff and DCCD? 2.2k ohm ok?
is there a way to get the side moldings off the 08 sti? | swizz977 | Car Care & Detailing | 0 | 08-13-2009 09:08 PM |
Is there a way to put religion threads on my ignore list? | Layman | Off-Topic | 15 | 04-12-2007 05:00 PM |
IS there a way to get out scratches from the door panels? | zuczek | Interior & Exterior Modification | 0 | 07-15-2005 02:54 AM |
Is there any way to keep headphone cords from tangling up? | Butt Dyno | Off-Topic | 0 | 07-07-2004 03:12 PM |
is there a way to bypass the maf sensor on a 99 2.5 rs | sc00by25rs | Technical Forum Archive | 11 | 07-06-2000 10:32 AM |
