Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-25-2005, 06:00 PM   #1
wrex03
Member#: 29963
04 sti
Default Utec reads boost high?
Ok, I've finally started to play with my utec and I've notice that the my avcr is reporting 1.19 bar, the utec is showing 19lbs and my boost guage is showing around 17lbs or so which would agree with the avcr. Anyone else notice that the utec reads boost high?
wrex03 is offline   Reply With Quote
Old 03-25-2005, 06:10 PM   #2
happasaiyan
Member#: 37731
my utec reads low.
happasaiyan is online now   Reply With Quote
Old 03-25-2005, 06:13 PM   #3
wrex03
Member#: 29963
04 sti
Great..... At higher levels they seemed a lot closer than 2psi away.
Old 03-25-2005, 07:41 PM   #4
Brewmaster
Member#: 16856
"I work until BEER
O clock" Stephen King
My utec also read higher than my boost gauge also. I was running the Defi bf gauge.
Brewmaster is offline   Reply With Quote
Old 03-25-2005, 07:45 PM   #5
happasaiyan
Member#: 37731
im running a defi T'd into the line from my BOV. i was in abs. mode...and it read low.
now i changed it to gauge mode and its accurate.
Old 03-25-2005, 07:54 PM   #6
wrex03
Member#: 29963
04 sti
I have the stock guage. Which would you trust, the avcr, or the utec?
Old 03-25-2005, 09:20 PM   #7
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
My utec showes max 24.7 psi although i see 2 bar ( 28-29psi) on the boost gauge.
How can i correct this ?
WhiteKnight is offline   Reply With Quote
Old 03-25-2005, 11:57 PM   #8
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
You need to set it to read gauge pressure, not absolute pressure.
mcowger is offline   Reply With Quote
Old 03-26-2005, 04:57 AM   #9
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Thanks !
Old 03-26-2005, 07:16 AM   #10
hippy
Member#: 36528
2002 Impreza Wrx
That might fix other peoples problems if the utec is reading higher then the gauges, but for whiteknight the problem is with the map sensor(as far as I know). I don't think the map sensor was made to sense pressures which are so high.
peace
Old 03-26-2005, 07:19 AM   #11
happasaiyan
Member#: 37731
peace
hippy has teh right here.
Omori Digital Boost Gauge reading too high... DinoGuan Electrical & Lighting 10 05-12-2007 12:12 AM
Where does boost gauge read boost? rex n effect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-12-2005 02:39 PM
Does anyone else read about high speed chases and think... rogue Off-Topic 31 08-19-2004 03:56 PM
Hiss like boost leak when boosting high Lit4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-13-2003 03:12 PM
Deceptive Boost Readings at High Altitudes CobraKLR Rocky Mountains Impreza Club Forum -- RMIC 6 11-11-2002 10:52 PM
