Old 03-25-2005, 08:22 PM   #1
jerthehair
Member#: 57133
2004 WRX
Red
Default Streettuner, how do I save maps??yes I RTFM
Ok so got my streettuner set-up and logged some runs and made my changes in the VF34 base map and clicked on save map as realtime.......cannot save file. Ok save as base map........same thing.
I read the manual a million times and this still escapes me.
Any help from anyone would be great.
Thanxs
jerthehair is offline   Reply With Quote
Old 03-25-2005, 11:31 PM   #2
Barge
Member#: 62941
2004 WRX
Rally Blue
When I save a map life you descibed it pops right up with where to put the file and to type in a file name so I don't know what to tell you. Check the log file and call cobb.
Barge is offline   Reply With Quote
Old 03-26-2005, 12:07 AM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Are you trying to save the maps to the ECU or to a file to use with the AccessPort?
WHen you make changes, they should be persistent on the ECU, kind of like a real time map. However, if you disconnect the battery, the ECU will revert back to the base map that you flashed on there. At that point, you'd either have to reload the map via the ST or the AP. Once you make a base map and flash it via the AP, then it's there for good.
Does that answer your question?
Mike
crazymikie is offline   Reply With Quote
Old 03-26-2005, 10:49 AM   #4
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Where are you trying to save it to? It sounds like it's write protected. You're not trying to save to a CD, are you?
Or, if you're trying to save it over the base map you started with, it could be write protected. Choose a different name.
mrbell is offline   Reply With Quote
How do you save youtube or video google vids? skimmilk68 Off-Topic 9 03-09-2006 06:27 PM
How do I save this video metoo Off-Topic 14 07-06-2005 12:55 AM
How do I save Yahoo Games metoo Off-Topic 1 04-29-2005 08:33 PM
How do I save the settings on a PS2? Undepelo Off-Topic 11 12-14-2004 04:29 PM
Mechwarrior-xbox-how do you save the game? jamz Off-Topic 14 01-27-2004 04:47 PM
