Old 03-25-2005, 11:03 PM   #1
komm.zu.mir
Member#: 77770
2001 2.5 RS
Silverthorn Metallic
Default For those of you with TWE headers..
..did you end up going with Super Stock (1.625" tube/ 2.25" coll.) or High Output (1.75" tube/2.5" coll)?
Thanks in advance!
komm.zu.mir is offline   Reply With Quote
Old 03-25-2005, 11:09 PM   #2
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
the only reason to go with high output is if you plan to turbo later on. which isnt a good idea any... unless of course its a swap!.
Crash477 is offline   Reply With Quote
Old 03-26-2005, 05:05 AM   #3
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
or if u are planning on doing internal mods with raised redline, i think u'll lose low end power if u go w/ larger diameter exhaust system.
anonymous_wolf is offline   Reply With Quote
Old 03-26-2005, 11:27 AM   #4
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
even with cams or heads the Super Stock will work very well. Call TWE and talk to them.. they will help you out..
Old 03-26-2005, 12:00 PM   #5
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
I have talked with a few people about this. The Superstock is probably the best choice. The High Output is if you are building an engine that is probably only going to see time at the track for drags or auto-x. If I was rich and had a lot of money it would be a closed forged ej25 block, titaninum pisitons (12.5+:1), titanium rods, cai, pnp heads (stage 3, no daily driver here), either stage 2 or 3 cams, thin head gasket, pnp throttle body, knifed and balanced crank, 04 intake manifold, larger injectors, larger fuel pump, High Output header, catdelete racepipe, a 2.5" catback exhaust, stand alone system (probably link or hydra for better fuel, timing, and raised rev limit to around 8-8,500). This would allow actual use of the header then.
impr25rs is offline   Reply With Quote
Old 03-26-2005, 10:00 PM   #6
komm.zu.mir
Member#: 77770
2001 2.5 RS
Awesome, thanks to all.
I'm totally up in the air about a built engine or a swap later, hence my indecision. I was also thinking that the low end TQ loss would be more significant with the HO, especially since I'm not starting out w/ a high output engine in the first place.
I don't think I'll be seeing that for at *least* 2 years (unless I get absurdly lucky/significantly more wealthy =P), so it's probably best for me financially and efficiency-wise to go SS.
Old 03-26-2005, 10:02 PM   #7
komm.zu.mir
Member#: 77770
2001 2.5 RS
..plus I'm holding out for an STi... Gonna keep teh GC,though.
For those of you with Forge BOV's, need help, what spring are you using? vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-21-2006 11:55 PM
A free pitcher of beer for those of you with gc 8 v7/8 swap in Phoenix... rallyblues South West Impreza Club Forum -- SWIC 21 01-17-2005 05:58 PM
For those of you with the BPM TT... TwinTurbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-21-2001 12:51 AM
('93-'01) For those of you with a 2002 2.5 RS... Asinus Impreza Forum 5 05-13-2001 03:10 AM
For those of you with squeaks and rattle in your RS. tmat3 General Forum Archive 2 02-16-2001 05:30 PM
