Old 03-26-2005, 09:50 PM   #1
davidsti
Member#: 83829
Default New mods... what tuning should I do?
I currently have a K&N short ram intake and I have a utec, bosal cat back and invidia dp on the way.
With the intake and tbe what boost and af should I run. I was thinking about 18 psi and around 11:1 - 11.5:1 af. Does this sound safe?
Also, what kind of gains should I get with this.
Thanks
davidsti is offline   Reply With Quote
Old 03-28-2005, 12:19 AM   #2
wannaberacing
Member#: 33919
2002 2.5l-WBR-GT30R
wbrheads-ECUtech-400whp
depends how you drive. If your hammering it all the time better get into the 10's.
wannaberacing is offline   Reply With Quote
Old 03-28-2005, 12:47 PM   #3
davidsti
Member#: 83829
ok... I will probably do 10.9:1 or 10.8:1 and about 18psi.
How much does the timing have to be changed to run 18 pounds and around that af?
Old 03-28-2005, 02:37 PM   #4
wannaberacing
Member#: 33919
2002 2.5l-WBR-GT30R
A delta dash would tell you exactly where in the map and how much to alter it.
Old 03-28-2005, 04:20 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
What kinda car do you have? What are you using to monitor your a/f ratio? Do you have an egt gauge? How about a boost gauge? What altitude are you driving at most of the time?
Old 03-28-2005, 07:45 PM   #6
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
octane? I'll assume 93-94 so I'd run 10.8 or richer. If you are on the stock turbo, you can run 18lbs, but you're getting outside the efficiency range and the amount of air you are pushing wont change much. A K&N is nice and all...but it doesnt do anything.
stay conservative -- a few horsepower isnt worth it imo. A new turbo / intercooler would really make a huge difference.
Rob
dosage0 is offline   Reply With Quote
Old 03-30-2005, 06:39 PM   #7
davidsti
Member#: 83829
I have an 04 sti. I am at about 3000 feet. I have the factory boost gauge.
Old 03-31-2005, 07:30 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
before you go cranking up the boost, get those cats out of there and uncork the muffler. for street driving, low-11's:1 suits me just fine.
Tune coming soon - What else should I do? A7X Newbies & FAQs 10 07-07-2008 08:28 PM
Doing a rear diff. swap (non LSD to LSD); what else should I do while I'm at it? powerlabs Transmission (AT/MT) & Driveline 8 12-31-2004 12:14 AM
Starting to Mod...But, while i'm in there, what else should I do? 2000vfr800 Mid West Subaru Owners Club Forum -- MWSOC 11 07-16-2002 08:49 PM
What color should I do my interior? ImprezedRS Interior & Exterior Modification 9 08-17-2001 09:39 AM
What performance should i do next?? Otaku64 Normally Aspirated Powertrain 16 11-21-2000 12:18 AM
Message Board Statistics All times are GMT -4. The time now is 06:42 AM.
