Old 03-27-2005, 11:40 AM   #1
SCA260
Member#: 79210
2004 WRX
Default vishnu reflash
i have an 04 wrx and i just got the vishnu stage 1 reflash. i also have all the mods that go with it. it just dosn't seem to be much faster. does it need time to learn the car or something. any info would be great.
thanks,
steve
SCA260 is offline   Reply With Quote
Old 03-27-2005, 11:50 AM   #2
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
did you try the "vishnu" reset?
off-topic: i see that you are in akron. are you on www.LERSOC.com (Lake Erie Regional Subaru Owners Club) or www.Ohiosubaru.com
Quack is offline   Reply With Quote
Old 03-27-2005, 12:10 PM   #3
rich728
Member#: 40328
2004 WRX STi
BSP #728
what are you exact mods?
rich728 is offline   Reply With Quote
Old 03-27-2005, 12:59 PM   #4
cooter
Member#: 23258
2005 STi
Yes, what are your mods and how much boost are you seeing?
cooter is offline   Reply With Quote
Old 03-27-2005, 02:49 PM   #5
SCA260
Member#: 79210
2004 WRX
i have the underdrive pully, tbe, uppipe. vishnu said that in 4th gear i should see 18 psi. i have yet to see anything over 14 psi. plus the car just doesn't pull any harder than it did before.
i haven't been the those web sites but i will now : )
Old 03-27-2005, 05:08 PM   #6
cooter
Member#: 23258
2005 STi
Well, something I've seen with off-the-shelf reflashes is that the boost settings don't always correspond on different cars. You'll need to buy/borrow deltadash and raise your max allowable wastegate duty cycles and your target boost.
On my '02 WRX, I had the opposite problem with making too much oscillating boost, whereas on a friend of mine's car, he was having the problem you're having. Deltadash boost adjustments fixed both cars. Hope this helps
Old 03-27-2005, 06:22 PM   #7
Quack
Member#: 57264
while not the Vishnu, if i don't do the reset trick, it usually takes a while for the ECU to learn. when i just did the last update on my cobb AP, i was only boosting ~15psi, now i'm peaking at ~17psi.
btw, LERSOC is mainly Cleveland & Akron area...see you there.
Old 11-14-2005, 12:24 PM   #8
jpsimon
Member#: 35570
2015 STi
also make sure you aren't in low boost mode! make sure your rear defroster is off, floor it while you are driving and press the rear defroster on and itll switch between low and normal boost mode. (and vice verca)
jpsimon is offline   Reply With Quote
Vishnu reflash problems CastleBravo New England Impreza Club Forum -- NESIC 25 01-09-2004 09:49 PM
Vishnu reflash, how much boost? tucker63 Engine Management & Tuning 11 11-19-2003 05:17 PM
Cobb Or Vishnu Reflashed Ecu sedonawrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-29-2003 05:26 PM
vishnu reflash question 02WRXman Engine Management & Tuning 2 05-21-2003 09:20 AM
Ecutek Vishnu Reflash Review mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 01-15-2003 12:14 AM
