Old 03-27-2005, 12:59 PM   #1
my02wrx
Member#: 15972
2002 wrx
Default Problem with TXS Tuna, Help
Yesterday my TXS tuna starting going crazy.
The car is idling and the AFR is approx 14.5 then it goes out of range.
The im driving and the AFR is out of range there are no numbers on the screen.
It periodly comes back on and off but for the most part it is out of range.
Anyone had this problem or know what it might be, the fuel setting are unchanged and it does not feel as though the car is really leaning out.
Any help would be appreciated.
Thank-you.
my02wrx is offline   Reply With Quote
Old 03-27-2005, 01:12 PM   #2
codean
Member#: 10186
How many miles have you had the O2 sensor in for?
Might be time for a new one.
codean is offline   Reply With Quote
Old 03-27-2005, 01:13 PM   #3
my02wrx
Member#: 15972
2002 wrx
couple of thousand
Old 03-27-2005, 03:01 PM   #4
2phless
Member#: 69343
1998 TransAm cnvrtbl
New O2. Hope you got the VW sensor. I keep a spare in the car in case the dealership has run out.
Anyone know of a good source for VW sensors at a good price? I've just figured out that I can use a company line to get the sensors at a better price (than $60 ish). But that's probably still not a good deal.
And a warning. I have had one be bad out of the box. That made for a confusing troubleshoot. It acted just like the old one.
2phless is offline   Reply With Quote
Old 03-27-2005, 11:21 PM   #5
my02wrx
Member#: 15972
2002 wrx
That sux, pay $600 for the stupid thing and then it goes bad
Do i have to buy the sensor from TurboXS?
Thanks
Old 03-27-2005, 11:32 PM   #6
2phless
Member#: 69343
If you got the VW O2 sensor with it then you can get it from a VW dealer. Thus my earlier reference to "the dealership". Look for the parking lot full of hippies and overpriced german tin cars with flower holders in them. It's a dead giveaway. (no offense Hippy )
The part is an O2 sensor for an '02 Turbo beetle. I think it's the front O2 sensor, but look at your plug. It's a "D' shaped plug and the other '02 turbo beetle O2 sensor (the rear sensor AFAIK) looks significantly different.
If you got the 'nicer' (more expensive but faster reacting) bosch sensor setup, I'm sure you can find an alternative source for the sensor besides TXS, but I don't know where.
Yes they wear out. It's part of the game. You aren't driving a stock car anymore. The 'stupid' Tuner is still fine. You want everything to last forever, get a honda, and don't drive it hard or modify it.
Old 03-27-2005, 11:35 PM   #7
2phless
Member#: 69343
Oh... before buying anything, have you tried a free-air calibration lately? Pull out the manual and check that out.
Old 03-28-2005, 07:09 AM   #8
AaronWRX
Member#: 7194
2011 997.2 Turbo
yeah do that... and if your tuner is accessible, swap the main unit with a buddies you know is working and see if it does the same thing.
AaronWRX is offline   Reply With Quote
Old 03-28-2005, 07:38 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you have a stick shift you can free air calibrate it without having to pull it out of the exhaust. i started a thread on doing just that on this board.
Flow problems with TXS TBE????? krystek Newbies & FAQs 11 08-28-2006 06:19 PM
Problem with txs up-pipe hlrex02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-09-2005 12:45 AM
suspension problem with coilover kit, HELP!! cvcsmkr Brakes, Steering & Suspension 1 02-28-2002 01:17 PM
problems with purchase..need help oppie590 Brakes, Steering & Suspension 6 05-12-2001 10:45 PM
problems with paint. please help bruno Tri-State Area Forum 0 04-18-2001 02:02 AM
