Old 03-27-2005, 05:30 PM   #1
ejh25
Member#: 65267
Default Water/Methanol Injection or Race Fuel or Both
Unfortunately I cannot upgrade to a bigger turbo at this time but I'm looking to get a little bit more power with my stock turbo and injectors. I have a UTEC and have a some experience tuning it w/ a WBO2. The question is should I try tuning w/ 2 gallons of toulene in a full tank or try a WI setup and tune w/ 93 octane? Is Toulene the right thing to be playing around with?
Here are my mods:
TXS Turboback (catless)
TXS intake
TXS FMIC
UTEC ~17psi (tuned a little rich but close to 100% IDCs (I know NOT Good)
Perrin Inlet Pipe
Samco Intake Pipe
ejh25 is offline   Reply With Quote
Old 03-27-2005, 05:55 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Between WI and toulene i'd choose WI, but that also depends on what setup you plan on using. The setup costs for WI are obviously alot more as i'm sure you know, but pretty cheap once setup, lol. I think toulene's great as a once in a while, in a bind kind of thing, but for a true day to day octane enhancer i think you're better off with the WI, or even another additive such as torco. Good luck.
Soon2Bgreat is offline   Reply With Quote
Old 03-27-2005, 06:09 PM   #3
jabbott
Member#: 73054
2002 WRX 2.5, 4eat
I would sugest alky injection. Since alky is a fuel you can get away with smaller injectors.
At 17 psi I was also around 100% dc, now i'm in the low 70's and still too rich.
jabbott is offline   Reply With Quote
Old 03-27-2005, 09:37 PM   #4
ejh25
Member#: 65267
You think toulene isn't a good daily driven thing because of reliability reasons? What are the advantages of torco?
Old 03-27-2005, 09:38 PM   #5
ejh25
Member#: 65267
Which alky kit did you go with?
Old 03-28-2005, 12:02 PM   #6
jabbott
Member#: 73054
2002 WRX 2.5, 4eat
SMC http://www.smcenterprises.com
Easy install and works great. I've had it on my subie for over 5 months with no problems and I've had it on my Grand National for over five years with no problems except traction!
Old 03-28-2005, 05:46 PM   #7
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Sorry for the slow reply. Not sure how you plan on mixing the toulene but it is a PITA. Torco is very easy, simple pour. I used to fill up every once in a while with toulene and it's just too much of a hassle imo. (yes i'm lazy i suppose)
I also think you get more consistant (if not higher) octane with the torco, and it's easier to measure/pour as stated. My choice would be WI though. Good luck.
Old 03-28-2005, 06:35 PM   #8
ejh25
Member#: 65267
I am also thinking about upgrading to bigger injectors to squeaze a little more out of my stock turbo. WI and fuel additives should allow me to lean fuel mixtures out quite a bit. What happens when they are used in conjunction? Can you run even leaner and/or run more timing and boost? My limiting factors beyond the injectors and turbo are my tranny and clutch which I am trying to put off for as long as possible. I am just tyring to figure out a way to get a slightly bigger smile on my face when I hit the gas.
Thanks for the replies!
Water/Methanol Injection FAQ DonkeyPunch Water/Methanol Injection, Nitrous & Intercooler Cooling 262 05-16-2016 12:03 AM
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 08:01 PM
Water injection and race fuel? macaws Water/Methanol Injection, Nitrous & Intercooler Cooling 17 10-21-2005 05:46 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
