Old 03-27-2005, 08:44 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Heat wrapping exhaust...
I am going to heat wrap downpipe shortly and wonder if it is a good idea to also heatwrap downpipe, and catback section (excluding catted section).
I hear that most people just wrap turbo and downpipe, but haven't heard of people wrapping midpipe and catback sections.
Old 03-27-2005, 08:51 PM   #2
Killian Maynard
Member#: 73734
2005 WRX I caught
you a delicious bass
My reccomendation would be to have them ceramic coated instead. With heat wrapping you run into 2 problems. 1) The heat is not retained in the piping it is retained at the surface where the heat wrap meets the outer edge of the piping. That actually will cause more heat on the surface than you want. 2) Heat wrapping will lead to premature breakdown of the pipe surface. Once the heat wrap gets wet the moisture is trapped there untill it evaporates over time or with heat. That layer of moisture on the surface will cause oxidation/wear/etc.
So ceramic coat your pipes instead, it works a whole hell of alot better and will help the pipes last alot longer.
Killian Maynard is offline   Reply With Quote
Old 03-27-2005, 09:57 PM   #3
shiftnmadkwik
Member#: 83870
2005 WRX
yeah. with stainless its not as bad as with mild or aluminized steel, but killian makes a good point. jethot is suprisingly resonable.
shiftnmadkwik is offline   Reply With Quote
Old 03-28-2005, 07:36 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ceramic coating does NOT work better than a good exhaust wrap folks.
i dare you to put your hand on your coated exhaust manifold after a run. i can do it with my wrapped one.
Old 03-28-2005, 09:20 AM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Just watch out for oil getting on the wrapped pipes. I believe someone on this board had an engine fire due to that.
wcbjr is offline   Reply With Quote
Old 03-28-2005, 09:32 AM   #6
Rickyh
Member#: 40453
go for da wrap. It makes a huge difference in temps.
Rickyh is offline   Reply With Quote
Old 03-28-2005, 09:56 AM   #7
JIM THEO
Member#: 29715
2004 WRX
WR blue
Agree, I did wrap the full exhaust turbo to backbox + up-pipe and soon I am going to heat wrap with thermo-tec my turbo.
Huge difference in engine bay-I/C temps and helps slightly in faster spool-up.
JIM
JIM THEO is offline   Reply With Quote
Old 03-28-2005, 11:47 AM   #8
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Been there. Still do that. Remember that all coatings are not created equal. With a good coating inside and out, you can hold onto it right after a run. However, you will not be able to after a long drive. Big difference.
As to the wrap, it will cause additional corrosion. On SS pipes as well. (Google for crevice corrosion) Doing both will help a bunch, as the ceramic will help protect against corrosion.
bofh is offline   Reply With Quote
To Heat Wrap Or Not To Heat Wrap? pr4mnc Newbies & FAQs 37 06-08-2011 03:10 PM
P&P stock exhaust manifold, heat wrap roninsoldier83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-20-2005 09:01 PM
exhaust heat wrap kedrin Texas Impreza Club Forum -- TXIC 14 10-01-2004 01:23 AM
to heat-wrap or not to heat-wrap downpipe iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-29-2003 12:58 PM
Heat wrapping/insulation for turbo and exhaust? lo0pback Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-05-2001 08:41 AM
