Old 03-27-2005, 09:35 PM   #1
Subystud
Member#: 57943
WRX Stage 1+
Back to the basics
Default Utec Problems!!!!
My car is ****ING up. I think it's knocking. Started when I got the UTEC on. Standard stg. 2 map, road tuned by a Subaru Pro. Won't rev past 3.5k rpm. Stalls out all the time. Won't drive up into my garage!!!!!!! Can I just take the UTEC off?????? I switched over to my stock map. HELP!!! Need the car to run!!! Can't I go back to the good old days?????!!!
HELP!!!!!
Subystud is offline   Reply With Quote
Old 03-27-2005, 10:13 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Why don't you give us some more information. Mods, etc.
If I had to make a totally uneducated stab in the dark from the little bit you've posted, could it be misfires from fouled plugs or a blown coil pack? That could make it stutter at higher boost or RPM.
If you've put the UTEC on MAP 0, the UTEC won't do anything and so you shouldn't have a problem caused by it. Double check your installation and ensure all the harnesses are securely connected.
serendipity is offline   Reply With Quote
Old 03-27-2005, 10:15 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Takes about 5 minutes to unplug the utec and plug your stock ECU back in. Start there. It's impossible for people to diagnose your problem with so little information.
Old 03-27-2005, 10:23 PM   #4
Subystud
Member#: 57943
WRX Stage 1+
Back to the basics
Sorry for the lack of info. I'm pissed, ranting, slightly scared, you know (or maybe you don't).
Mods:
3" TBE
Uppipe
APS CAI
Perrin Turbo inlet
UTEC, with stg.2 map road tuned
Mods on after UTEC: APS CAI, 255lph fuel pump.
Problems: After UTEC was put on, when I ran the gears slightly it would stutter, stall, shut-off, idle funny, felt like fuel was getting cut off. How I solved the problem? I just sat in a parking lot for a few, let the car chill, pray alittle, drive softly.
Old 03-27-2005, 10:29 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Ya gotta take the intake off....and put back the stock one.
Old 03-27-2005, 10:43 PM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Have you tried the TXS sourced Stage 2 map? Might try that to see if your tuner did a poor job.
mcowger is offline   Reply With Quote
Old 03-28-2005, 12:27 AM   #7
nmyeti
Member#: 4980
Step 1: Unplug the UTEC and plug the factory ECU back into the factory harness.
If that cures your problem proceed to step 2.
Step 2: Re-flash the UTEC with the latest software that is available on our website.
http://www.turboxs.com/utecwrxupdate.shtml
Step 3: Load the stage 2 map into map position #1
http://www.turboxs.com/_images/UTEC/.../stg2up04a.TXT (right click and “save target as”)
Step 4: Load the stage 1-3 parameters
http://www.turboxs.com/_images/Updat...%2042cver2.TXT (right click and “save target as”)
Step 5: Set the UTEC’s map switch to position #1.
Step 6: Verify switch position by looking at the dashboard screen in HyperTerminal
Step 7: Reinstall the UTEC
If after all of this you are still having problems with the UTEC and the problem doesn’t exist on the stock ECU then you should contact your TurboXS dealer for a replacement UTEC (assuming you purchased it from a TurboXS dealer).
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 03-28-2005, 12:29 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
If the problem isn't with the utec being broken, it would probably be a good idea to call the place that tuned your car and ask them what they think. They should fix the problem if it has something to do with the tune they did.
peace
Hypterterm/utec problem Shamr0ck Engine Management & Tuning 1 01-02-2004 11:18 AM
Major Utec Problems, Please Help! rexmobbin' Engine Management & Tuning 9 12-16-2003 10:39 PM
Utec problem- car won't start V REX Engine Management & Tuning 0 09-06-2003 09:44 PM
Attn: Phil @ TXS major Utec problems/knocking someone please help Jay04WRX Engine Management & Tuning 66 08-02-2003 02:22 PM
UTEC Problem Veck Engine Management & Tuning 14 10-14-2002 09:50 PM
