Old 03-28-2005, 12:28 AM   #1
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Default wrx swap along with manual transmission swap?
what things would i need to convert an auto tranny to a manual tranny (besides the tranmission)? i'm looking into buying a 94L wagon and swapping a wrx motor into it however the L is an automatic.....just curious if it's a super pain to do or not. thanks.
hail2theTheif is offline   Reply With Quote
Old 03-28-2005, 08:18 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I’m doing this same swap right now…
If you’re going to do it, it would be much easier to swap from an AT to MT while performing the engine swap. This way you can run all the new wiring associated with the MT, and mechanical components while you have the engine and dash removed.
As for parts, you really need to research as you’ll need a lot more than just the transmission:
{off the top of my head}
Rear – diff
Pedal-box
Activation cylinder
Master cylinder
Hard-lines
Rear-axles (possibly)
{wiring from WRX harness}
VSS
Neutral safety switch
Starter interlock relay (MT)
Clutch switch
Good luck…
xcntrk75 is offline   Reply With Quote
Old 03-28-2005, 12:27 PM   #3
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
thanks a bunch. glad to hear other people have done this as well. hopefully all will go well. it'll be odd for awhile not having my rs but when the L wagon has a rex motor in it i'm sure i won't be complaining
Old 03-28-2005, 02:43 PM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
You also need an MT driveshaft. I have one that I can sell to you or maybe even trade. PM me if you're interested. Thanks.
garface is offline   Reply With Quote
Complete 03 WRX 5 speed manual transmission swap Fierysun SCIC Private Classifieds 66 03-19-2011 04:34 PM
ej22 auto to manual transmission swap wrxracer25 Normally Aspirated Powertrain 5 06-30-2008 05:19 PM
auto to manual transmission swap soob102 Transmission (AT/MT) & Driveline 9 05-06-2004 11:59 PM
Engine swap along with a hoodscoop addition mofong Subaru Conversions 17 08-06-2003 12:29 AM
Manual transmission swap into an SVX? Rownan SVX Forum Archive 5 02-23-2001 03:11 PM
