Old 03-28-2005, 11:42 AM   #1
2phless
Member#: 69343
1998 TransAm cnvrtbl
Default STi UTEC MAP. Feedback requested.
For an 04 STi with these performance mods.
Deadbolt VF22 turbo
Cobb Accessport (to remove some CELs and Top Speed limiter)
TurboXS Front Mount Intercooler
TurboXS UTEC
TurboXS Short Ram intake
TurboXS Tuner-pro
TurboXS Recirc. Valve
TurboXS ABC
Increased diameter FBC bleedoff hoses (to 1/4" I.D.)
Perrin Modified Injectors (816 cc)
Perrin Fuel Rails
Perrin Catch Can
Walbro 255 lph Fuel pump.
Denso 1 step colder plugs
GPmoto headers
GPmoto Turbo inlet hose
3" Bellmouth DP to Borla Hush catback
CF Radiator air deflector
"Ram Air" through righthand JDM foglight cover.
(Plus for what it is worth, a lightened flywheel.)
all mods listed here
The map is for running 20 psi on this setup and keeping the AFRs in the 10s under heavy loads to redline. Since posting this map I've advanced the timing some in the 60-90 range from 5500 up just a tad and it's still safe. With the help of the guru's at wrxhackers I've tried to keep the whole thing as safe as possible, and am now looking for areas to improve performance, but the chances of finding STis with similar setups is slimmer than finding similarly moddified WRXs. So I've come here to spread it out.
Any feedback is appreciated. The timing mostly needs help. It's safe in the trouble areas, but could use some gentle nudging to get more power out of it in the other areas.
2phless is offline   Reply With Quote
Old 03-28-2005, 01:55 PM   #2
wrex03
Member#: 29963
04 sti
I run lower timing in the spool up range, but a little less than you in the top of the rmp. Turbo is a sbr Gt-10.
wrex03 is offline   Reply With Quote
CA: STi Utec + Map Selector dashiet Private 'For Sale' Classifieds 3 09-08-2004 01:55 PM
Need STi Utec Map wrxyboy Engine Management & Tuning 4 07-03-2004 08:44 AM
Rich STI UTEC map #1 cpturbo Engine Management & Tuning 15 05-23-2004 09:51 PM
Sti Utec Map wrxyboy Engine Management & Tuning 12 05-18-2004 04:27 PM
STI UTEC Maps??? Abe Froman Engine Management & Tuning 0 04-22-2004 09:10 AM
