Old 03-28-2005, 07:31 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default URGENT: did I modify my injectors correctly?
So on the first one, I cut at the microweld, which may have been too much, because I see another space, like another disc from cutting about 2-3mm after the cap. Will post pics later if necessary, but I wanted to get a feel if anyone has comments
Also, everyone says replace O-rings, but these seem fine...?
Thanks,
Ambert
verc is offline   Reply With Quote
Old 03-28-2005, 08:07 PM   #2
jimmyd
Member#: 38766
2003 WRX Sedan
Why are you tearing you injectors apart?
Jimmyd
jimmyd is offline   Reply With Quote
Old 03-28-2005, 10:01 PM   #3
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Jimmyd
because Kingpin and Clark told us we could
Old 03-29-2005, 02:24 AM   #4
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Old 03-29-2005, 08:55 AM   #5
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Ouch. Hard to tell from the pic, but they look pretty effed up to me. You just cut at the microweld? Looks like the dremel slipped out of your hand and went wild. Might be able to salvage with some smoothing. SHould flow fine, just might leak?
rjrutzky is offline   Reply With Quote
Old 03-29-2005, 10:41 AM   #6
Performance Driven
Vendor
Member#: 75855
04 Dynapack
second photo shows that you totally botched the job.
all you had to do was cut through the very thin cap.
oh well, you just lost one injector...
Performance Driven is offline   Reply With Quote
Old 03-29-2005, 12:19 PM   #7
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Umm...yeah...those are F'd. Takes a steady hand to modify correctly, looks like the dremel got alittle wild.
darkstarmoto is offline   Reply With Quote
Old 03-29-2005, 12:20 PM   #8
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Obviously the 409 wheel is thicker than the weld itself, I misunderstood cutting at the microweld to mean at the actual weld.
Old 03-29-2005, 01:52 PM   #9
rewt
Member#: 60794
2007 Solstice GXP
sorry man, but from the pics at least one injector is wasted. the whole phrase "cut the caps off" is kinda misleading, though, because you don't really need to cut into anything...
really all you need to do is use the dremel to sand around the outside edge of the cap, and you don't need to use much force. the cap will just pop right off.
rewt is offline   Reply With Quote
Anybody local that can modify my injectors?? kris84 Mid Atlantic Impreza Club -- MAIC 11 02-19-2008 07:34 AM
Where can I modify my injectors 06WRXMIKE Southern California Impreza Club Forum -- SCIC 11 11-07-2007 08:02 PM
Did I Adjust My Suspension Correctly? slowscooby Brakes, Steering & Suspension 14 09-24-2005 09:11 PM
Did I install my Fog Covers Correctly?? Oo DaRk StAr oO Interior & Exterior Modification 8 04-03-2003 11:03 AM
Did I Install My K&N Correctly? jzinckgra Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-21-2002 11:28 PM
