Old 03-28-2005, 07:58 PM   #1
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Have a Nice Day? Accessport had me thinking my clutch was slipping...
Well last night I went for a drive and I noticed a weird hesitation in 2nd gear at WOT that felt like my clutch was slipping. I only have 20,000 km and I almost always rev match so I was quite surprised when it seemed like the clutch was going. I also have an Accessport at stage 1 which was running fine for a few weeks until last night. I did a bunch of driving and noticed that in 1st gear there was no issue but in 2nd gear above 4500 rpm it felt like the car was going and then pulling back, going and then pulling back... 3rd gear had a similar problem but not as noticeable. Well, I've never had this problem before so I started shopping around for a new clutch. Then today I decided that I would unmarry the Accessport just to see if it made a difference. Well after that everything is back to normal again and I have none of this weird hesitation. Driving is super smooth albeit with less oomph that was there before when all was good with the Accessport... However my question is this... is it possible that unmarrying the Accessport reduced the amount of torque output such that the clutch is no longer slipping... OR is it that I never did have a clutch issue and the ECU was acting all crazy and causing this hesitation?
scooby9 is offline   Reply With Quote
Old 03-28-2005, 08:33 PM   #2
Phil Jr.
Member#: 62221
try reflashing the ECU and then resetting it by disconnecting the battery pumping the brake pedal etc etc. Let the ECU relearn for a few hundred miles and see what happens.
Phil Jr. is offline   Reply With Quote
Old 03-28-2005, 09:34 PM   #3
seattle944t
Member#: 18308
2005 WRX STi
Depending on what stage map you are running, you could have anywhere from 30-60ft/pounds extra at the wheels, so yes that could be it if the clutch was going.
But what your describing doesn't really sound like a slipping clutch to me. A slipping clutch will be more noticable in the higher gears -it gets worse with each higher gear, you'll see your RPM's going up w/o a matching increase in speed. What you were seeing sounds more like a fueling glitch. Reflash it again and see what happens.
seattle944t is offline   Reply With Quote
Old 03-28-2005, 11:49 PM   #4
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
do you need to reset teh ecu via disconnecting battery after flashing new base map?
Crash477 is offline   Reply With Quote
Old 03-28-2005, 11:57 PM   #5
Phil Jr.
Member#: 62221
If you flash in a base map and then reset the ECU the base map will still exist. But all of the learning the ECU did will get erased and it will relearn everything.
If you have a stg1 base map flashed in but are using the stg2 realtime map and then reset the ecu you will be back to the stg1 base map.
Dont know if that answered your question, I wasnt really sure what you were asking.
Old 03-29-2005, 01:10 AM   #6
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Even after I unmarried the Accessport, my car felt like it was bogging big time in 2nd. I didn't know if it was the clutch or if the ECU wasn't running optimally yet. I just got back from driving about 100 kms and it feels really responsive now with just the stock ECU so my clutch worries are over. Thanks for the info about the slipping clutch. I'll know what to look for in the future!
Old 03-29-2005, 01:12 AM   #7
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Actually I was running the STX stage 2 base map with stage 1 realtime map as this was the recommendation to resolve the "stalling issue" with the new 2004 maps from Cobb. Well after all the problems I've had with the Accessport and all the "workarounds", I've decided to get the ECUTek reflash instead. It was fun for a while with the Accessport but I think it's time to get some real tuning done.
Old 03-29-2005, 08:06 AM   #8
not a sho
Member#: 82637
2004 wrx wagon
i thought those stx base map fixes for stalling where to be used on stage 2 equiped cars only
that could be your problem
check it out
not a sho is offline   Reply With Quote
Old 03-29-2005, 09:31 AM   #9
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
check it out
Well according to Cobb the STX map did not have the OL/CL change so I was to use that as the base and then use the stage 1 real time map over it so in effect I would have a stage 1 setup.
Old 03-29-2005, 03:41 PM   #10
Phil Jr.
Member#: 62221
How is an ECUtek reflash going to be "real tuning"? It will be the same as COBB unless you take it to a dyno and have someone sit there and mess around with your stock car wasting time/money. IMO, the only use customs tunes have is for people with their own mix of mods that no premade flash can accomodate. There I said it.
Old 03-29-2005, 07:21 PM   #11
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Well although the Accessport is great when it's working, it's still an off the shelf type of tune. I'd like to get my car dyno tuned with all of my mods on. I think that's still got to be the best possible way to go. I've got all the parts for stage 2 (waiting for a warm day to put it all in) including an STI intercooler... and I know... (eyes roll) an intake. I'll be adding a high flow cat mid pipe too. I think in the long run and just for driveability's sake and engine longevity, it's worth the extra loot. Accessport going on EBay pretty soon!
Old 03-30-2005, 11:19 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you think the only purpose for a customized map is for cars with unique combinations of mods, then you are sadly mistaken.
Old 03-31-2005, 03:06 PM   #13
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
Agreed.
Just because a car has the exact same mods doesnt mean A) It will get the same power B) It can handle the same timing/fuel/boost levels.
dosage0 is offline   Reply With Quote
Old 03-31-2005, 10:52 PM   #14
AdmiralWRX
Member#: 80204
2005 WRX++
I don't think you're supposed to run the STX map on a stock WRX. It looks as if it has the same requirements as stg 2, which is a TBE (see the Cobb map list).
I did see the recommendation for running the STX map, but it sounds like it was only for the stg 2 folks to try. I personally haven't had any stalling issues in the 2 months i've been running stg 1.
Don't malign the AP without good reason.....sounds like there was some operator error involved in your problems.
AdmiralWRX is offline   Reply With Quote
Old 03-31-2005, 11:20 PM   #15
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Well I've tried the new map that was just released and I still have the stalling issues. I agree that for most peeps it works great. But the AP is just not working for me so it's time to try something new... Also, the recommendation from Cobb was to run the STX map for stage 2 and then the real time map for stage 1. This would in effect be a stage 1 setup without the OL/CL changes.
Old 04-03-2005, 09:39 AM   #16
AdmiralWRX
Member#: 80204
2005 WRX++
Did Cobb recommend that to you directly (via direct email or phone), or is that something you read on the stalling threads that are going around this forum and Cobb's? If it's the latter, then you took advice that Cobb threw out there without checking all the facts. Look at the map management page on Cobb's website and check the requirements to run STX stage 2. It's the same requirements to run stage 2, and unless you've got a TBE, you shouldn't be running either map.
If you were one of the people experiencing the stalling issue, then certainly you have a good reason to give up on the AP.
Old 04-03-2005, 11:17 AM   #17
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
Well if it was the clutch(whichs sounds like you already ruled out) then you would feel a see the rpms spike up during these moments of hesitations.
What you describe is what I felt with my stock 03 when new. This is what I feel was a ECU tunning issue with the timing being pulled. Over time with me learning the car and the ECU learning me things started to smooth out.
I went to AP stage 1, still all stock otherwise at 36k miles and things smoothed out alot. I went with the AP because I feel its the best and cheapest for what I want in the long run. ST is out now finally and PT is around the corner. I will be getting a custom tune for MY car in MY region with the fuel we have.
I kinda think of the AP vs ECUtek as MAC vs PC. Cobb kept things inhouse so things are so with tunning research. ECUtek they the venders do the tunning which gives alot more options and information for development. So if you need it right now go with the ECUtek custom tune.
I'm just glad Cobb has finally gotten their tunning stuff out and it and shouldn't turn out to be a Beta vs VHS type a thing.
GDR is offline   Reply With Quote
Old 04-03-2005, 11:29 AM   #18
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Yes the whole STX/real time map setup was based on discussions in Cobb's forum. It was to test the stalling issue. For 2 tanks of gas it ran great... then I ran into this issue... I then switched to the newest base map that Cobb just released and the stalling issue came back again.
Old 04-03-2005, 11:32 AM   #19
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
I think it might have just been a bad tank of gas too that got my car acting all strange and detonating.
Old 04-12-2005, 09:04 PM   #20
X-VWGLX
Member#: 16739
2002 WRX, 2005 STI
Unhappy slipping clutch
ok, i got the Cobb Accessport Stage 1 about 2 weeks ago. I noticed a few days after that it felt like the engine was revving, but the car wasnt pulling. Tonight i could floor the gas, the tach would spin up 1000-2000 rpm, but i wasnt accelerating very much. the rpms would go up quickly as boost builds. worse in 3rd and 4th gears. 40K miles. got some track miles on this car, probably should have heel-toed more often.
sounds like a clutch to me. cant handle the extra power?
i havent heard of anyone with stage 1 or 2 needing to upgrade a clutch for the additional power - so is mine just used-up?
i also read on scoobymods that a slipping clutch is worse in the rain or when cold. tonight its raining.
X-VWGLX is offline   Reply With Quote
Old 04-14-2005, 08:22 PM   #21
X-VWGLX
Member#: 16739
2002 WRX, 2005 STI
Talking yep
it is slipping. the worn cluch cant hold the extra torque. all hail cobbtuning
So, i think my clutch is slipping... miller91 Transmission (AT/MT) & Driveline 5 01-16-2009 08:50 AM
I thought my clutch was slipping, but I guess it's something else SparkysJDMSpeedWagon Transmission (AT/MT) & Driveline 25 03-15-2007 01:29 PM
Well I though my clutch was slipping LJG33 Transmission (AT/MT) & Driveline 10 03-01-2005 05:48 PM
I think my clutch is slipping Dorkfish Transmission (AT/MT) & Driveline 8 05-28-2004 11:53 AM
Think my clutch is slipping. DirtDevil Normally Aspirated Powertrain 0 03-26-2001 06:58 PM
Message Board Statistics All times are GMT -4. The time now is 05:38 AM.
