Old 03-28-2005, 11:31 PM   #1
shyguyk27
Member#: 39308
SPR
Default Utec Parameters and other trouble...
I'm having some trouble with my utec. It bought it used and installed it about a week ago. I used the stage 2 map (despite having an uppipe and IC hoses, cause I can't find the Nathan tuned 2.5 map) and took off. The boost was hitting around 17psi in 2nd and 3rd. Car ran fine pulled hard and was steady no CEL. I would sometimes see 18 psi so I adjusted the abc some which lead to other problems...
A week later I'm having some problems with it. To the untrained person (me!) it seems to be pulling timing early in the rpms and sometimes putting it back later on (a noticeable increase when driving). It doesn't seem to be knocking, but wouldn't now for sure what it sounds like, but my friend didn't hear any either. When we loaded it it was on old software. We upgraded it to the 4.2c software, but a friend who was installing it told me we didn't need the new parameters. (He knows more about it than I do so I said ok.) Do I need to download the new parameters even though I am using the new stage 2 map.?
I'm pulling a p0420 and an egt cel. I don't remember the number on it. The car is noticably missing some of the power it had before... it seems slower than before I put the utec on. The ABC is giving me trouble, the boost is now below 16.5 in 2nd and 3rd but hits like 18-19 in fourth?? The spring seems messed up... like it wasnt lined up properly. It got stuck and would not adjust (up or down). My laptop doesn't seem to connect with the utec so I can't post or even pull logs. Any ideas?
shyguyk27 is offline   Reply With Quote
Old 03-28-2005, 11:34 PM   #2
Mach V Dan
Member#: 12029
Okay, you've got a lot of questions here, but...
- If your laptop can't connect to the UTEC, nothing else matters until you get it connected. Did it ever connect since you upgraded the firmware?
- Why are you dinking with the ABC?
- Assuming you DO get the laptop talking to the UTEC, you DO have to reload the parameters just like you had to reload your map.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 03-28-2005, 11:41 PM   #3
shyguyk27
Member#: 39308
SPR
I didn't reload the map I installed it directly from the TXS page. Not an old map, but their newer one.
We used his laptop... its some problem with the modem on my laptop that it wont use hyperterminal. It never connected, his did. I'm looking into buying a new laptop this week anyways.
I was told I had to adjust the abc that was supplied with it.
Old 03-28-2005, 11:49 PM   #4
Mach V Dan
Member#: 12029
Okay, but if you changed firmware, the parameters are NOT maintained, they're cleared. It sounds like you may have reloaded the MAP, but not the PARAMETERS, which are a separate data area.
Get your buddy's laptop and load those params.
--Dan
Mach V
FastWRX.com
Old 03-28-2005, 11:56 PM   #5
shyguyk27
Member#: 39308
SPR
--Dan
Mach V
FastWRX.com
Thanks for the help man!
Still makes me wonder why the car ran fine at first though.
Old 03-29-2005, 12:12 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The p0420 is the rear o2 sensor...cat ineffiency...easy 'mechanical fix'......and the EGT one is the 2.2k ohm 1/2 watt resistor in the harness plug on the passengers side shock tower...again..easy fix....
Old 03-29-2005, 12:29 AM   #7
shyguyk27
Member#: 39308
SPR
Will the 2.2k mess up the readings on my EGT gauge?
Old 03-29-2005, 10:00 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
no it spoofs the OEM EGT reading, not your aftermarket.
Old 03-29-2005, 10:48 AM   #9
Mach V Dan
Member#: 12029
That EGT CEL code will put your car in "limp" mode. That will certainly impact how the car drives!
--Dan
Mach V
FastWRX.com
Old 03-29-2005, 12:45 PM   #10
shyguyk27
Member#: 39308
SPR
--Dan
Mach V
FastWRX.com
Yea I've had that happen to me before. We got the probe tightened, but I suppose it's only a matter of time before it works itself out again. If I want to take the probe out what can I do to fill the bung?
Thanks for the help everyone!
Old 03-30-2005, 10:00 PM   #11
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
Hopefully, I'm not threadjacking (didn't want to start a new thread about similar problems) but:
I recently installed UTEC 6b and updated to the latest firmware 4.2c. I then downloaded the regular Stage 2 map off the TXS site and unknowingly did NOT download the parameters. The car actually ran okay and hit the appropriate boost levels. It would knock ocassionally and pull timing (CA gas) so I decided I needed to download the low octane Stage 2 map AND do it right by updating the parameters (for Stage 1-3).
After updating the parameters though, it seemed like the car would no longer hit target boost. It's currently *only* seeing 11-12 psi.
What do you guys think? Should I mess around with the ABC? Thanks.
kennyvb is offline   Reply With Quote
Old 03-31-2005, 06:59 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
check your boost control settings. default is open loop, most maps take advantage of closed loop boost control. the values in the maps are completely different.
ken
Old 03-31-2005, 09:09 AM   #13
AaronWRX
Member#: 7194
2011 997.2 Turbo
^^^ CLB is the default for all 4.x utec firmware releases. Only 11-12psi? Are you deep into the 400's with your CLB values? If so, you will need the ABC.
AaronWRX is offline   Reply With Quote
Old 03-31-2005, 12:53 PM   #14
kennyvb
Member#: 70234
MY86 BMW E30 325
Actually max boost i'm seeing is +12.9 psi (was at 3013 rpm). Max clb values are 300.0.
Which data log should i capture (I did 1)? Sorry, for the newbie questions...I just switched from AccessPort!
Thanks.
Old 03-31-2005, 01:18 PM   #15
AaronWRX
Member#: 7194
2011 997.2 Turbo
Thanks.
begin sarcasm:
I don't know why you are having so many problems, after all, the utec manual states that you must load the parameter files and the utec manual tells you how to edit you CLB to reach target boost.
/end sarcasm
honestly, Most of your problems should have been addressed by proper product documentation and some of your problems are a direct result of turboxs not upgrading the documentation with new firmware releases.
And the systemic cause for them not improving their documentation is all the free support nasioc and other boards give out.
"but no one ever reads the manual"
Old 04-02-2005, 02:39 AM   #16
kennyvb
Member#: 70234
MY86 BMW E30 325
I calibrated Min TPS as 33/51 and rounded down to 0.6. The Max TPS was 204/51 = 4. These constants were changed from the default TXS Stage 1-3 of 0.7 and 4, respectively. I will probably change it back because min TPS % looks to be 1 and max at 99 with my rounded calibration.
I know I should have resolved my issue with the Stage 2 map, but I got anxious and just installed a USDM STI TMIC and am now running the default Stage 3 map...
So mod list goes:
TXS catted standard turboback
GTSpec Gen II Headers/Uppipe
just installed USDM STI TMIC
Here's a log from tonight with the above:
Code:
    	     	    	   	Load	Knock	    	      	      	 Mod	  Mod	      	 Mod
 RPM	  MAP	 MAF	TPS	Site	Count	 AFR	 Ign#1	 Inj#1	 Ign	  Fuel	Boost	 MAF
    	  psia	 V 	 % 	    	     	    	  deg 	 duty 	 deg	   %  	(CL) 	  V
715	-9.8	1.3	1	0	0	14.1	14.4	1.6	ECU. 	0	ECU.  	1.3
744	-9.6	1.3	1	0	0	13.9	14.7	1.5	ECU. 	0	ECU.  	1.3
842	-9.4	1.3	1	0	0	14.1	5.5	1.5	ECU. 	0	ECU.  	1.3
1147	-9.1	1.3	1	0	0	14.1	-0.2	2.4	ECU. 	0	ECU.  	1.3
1808	-9.4	1.4	3	0	0	14	16.7	3.2	ECU. 	0	ECU.  	1.4
2939	-10.2	1.5	4	0	0	15.3	36.5	5.3	ECU. 	0	ECU.  	1.6
3390	-11.2	1.7	4	0	0	15.2	41.4	6.3	ECU. 	0	ECU.  	1.7
3483	-11.8	1.8	6	0	0	14.1	41.4	6	ECU. 	0	ECU.  	1.9
3527	-11.4	2.4	17	0	0	12	39.1	10.6	ECU. 	0	ECU.  	2.4
3457	-10.2	2.5	18	0	0	16.7	35.1	14.9	ECU. 	0	ECU.  	2.5
3486	-8.3	2.4	16	0	0	14.2	35.3	13.9	ECU. 	0	ECU.  	2.5
3512	-6.5	2.5	17	0	0	14.6	34.8	15.3	ECU. 	0	ECU.  	2.6
3523	-5.3	2.6	18	0	0	15.1	32.9	16.5	ECU. 	0	ECU.  	2.6
3519	-4.5	2.6	18	0	0	14.5	32.6	16.3	ECU. 	0	ECU.  	2.6
3512	-4.5	2.4	13	0	0	13.5	35	13.5	ECU. 	0	ECU.  	2.3
3497	-5.1	2.2	12	0	0	14.7	39.3	9	ECU. 	0	ECU.  	1.9
3468	-6.7	1.5	1	0	0	14.2	34.4	5.3	ECU. 	0	ECU.  	1.5
3519	-8.9	1.6	4	0	0	13.1	28.9	33.8	ECU. 	0	ECU.  	1.9
3457	-10.4	2.2	12	0	0	12.9	40.2	9.4	ECU. 	0	ECU.  	2.3
3490	-10.2	2.4	14	0	0	16.4	36.6	12.3	ECU. 	0	ECU.  	2.4
3494	-9.1	2.3	13	0	0	14	36.4	11.8	ECU. 	0	ECU.  	2.3
3483	-8.1	2.3	13	0	0	14.4	39.1	11	ECU. 	0	ECU.  	2.3
3475	-7.7	2	8	0	0	14.6	40.2	7.7	ECU. 	0	ECU.  	2
3465	-8.3	2	8	0	0	14	40.7	7.6	ECU. 	0	ECU.  	2
3465	-9.4	2	8	0	0	15.5	40.6	7.3	ECU. 	0	ECU.  	2
3443	-10	2	8	0	0	15.1	40.6	7.5	ECU. 	0	ECU.  	2
3443	-10.4	2	9	0	0	14.6	40.6	10	ECU. 	0	ECU.  	2
3436	-10.6	2	8	0	0	14.4	39.7	7.4	ECU. 	0	ECU.  	2
3436	-10.6	2	8	0	0	14.5	39.7	7.9	ECU. 	0	ECU.  	2
3408	-10.4	2	8	0	0	14.7	40.3	7.9	ECU. 	0	ECU.  	2
3422	-10.2	2	9	0	0	14.7	39.7	7.3	ECU. 	0	ECU.  	2
3429	-10.2	2	10	0	0	14.7	39.7	9.8	ECU. 	0	ECU.  	2.1
3439	-10	2.1	10	0	0	14.9	39.7	9	ECU. 	0	ECU.  	2.1
3404	-9.8	2.1	10	0	0	14.5	39.5	8.7	ECU. 	0	ECU.  	2.1
3418	-9.6	2.1	10	0	0	14.6	39.4	8.7	ECU. 	0	ECU.  	2.1
3429	-9.4	2.1	10	0	0	14.6	39.5	9.2	ECU. 	0	ECU.  	2.1
3384	-9.4	2.1	9	0	0	14.8	39.4	9.1	ECU. 	0	ECU.  	2.1
3384	-9.1	2.1	10	0	0	14.6	39.5	8.7	ECU. 	0	ECU.  	2.1
3418	-9.1	2.1	10	0	0	14.8	39.4	9	ECU. 	0	ECU.  	2.1
3377	-9.1	2.1	9	0	0	14.8	39.4	9	ECU. 	0	ECU.  	2.1
3401	-8.9	2.1	10	0	0	14.5	39.3	9.3	ECU. 	0	ECU.  	2.1
3370	-9.1	2.1	10	0	0	14.8	39.4	10.9	ECU. 	0	ECU.  	2.2
3390	-8.9	2.2	12	0	0	14.9	39	8.8	ECU. 	0	ECU.  	2.2
3377	-8.9	2.2	12	0	0	14.8	39	11	ECU. 	0	ECU.  	2.2
3384	-8.5	2.3	13	0	0	14.8	38.6	12.4	ECU. 	0	ECU.  	2.3
3377	-8.1	2.3	13	0	0	14.6	38.8	12.4	ECU. 	0	ECU.  	2.3
3408	-7.9	2.3	13	0	0	14.6	36.2	9.7	ECU. 	0	ECU.  	2.3
3363	-7.5	2.3	13	0	0	14.7	36.2	9.6	ECU. 	0	ECU.  	2.3
3373	-7.3	2.3	13	0	0	14.7	36	11.3	ECU. 	0	ECU.  	2.3
3340	-7.5	1.6	1	0	0	13.8	37	5.7	ECU. 	0	ECU.  	1.6
3290	-8.7	1.5	1	0	0	  rich	25.8	4.4	ECU. 	0	ECU.  	1.5
3030	-10.2	1.4	1	0	0	12.4	15.3	4.4	ECU. 	0	ECU.  	1.4
2784	-11.6	1.3	1	0	0	16.5	11.9	4.4	ECU. 	0	ECU.  	1.3
2511	-12.6	1.4	1	0	0	24	12	4.4	ECU. 	0	ECU.  	1.4
2442	-12.6	1.5	2	0	0	24.2	11.8	4.4	ECU. 	0	ECU.  	1.5
2997	-12.6	1.6	4	0	0	  lean	32.6	5.6	ECU. 	0	ECU.  	1.6
4161	-12.6	1.6	4	0	0	22.4	41	6.1	ECU. 	0	ECU.  	1.7
4462	-12.4	1.8	4	0	0	14.8	41.6	9	ECU. 	0	ECU.  	1.9
4522	-12.4	2.1	12	0	0	14.6	41.7	9.8	ECU. 	0	ECU.  	2.5
4528	-11.2	2.9	26	10	0	17.6	35.8	28.3	21	-0.1	ECU.  	3
4553	-8.5	3.2	34	10	0	  rich	29	43.9	21.3	-0.1	300	3.3
4662	-4.9	3.6	43	10	0	  rich	17.8	60.5	21.6	-0.1	300	3.7
4741	0.4	3.9	48	30	0	  rich	15.7	80.9	21.9	-1	300	3.9
4789	5.3	4	64	60	0	  rich	13.2	87.2	19.4	1.1	300	4
4916	9.6	4	81	70	0	  rich	13.9	84.9	20.5	0.4	300	4
4982	12.1	3.9	98	70	0	  rich	17.2	86.2	21.7	-0.6	300	4
5089	13.1	4	98	70	0	  rich	13.4	88.6	22	-0.5	300	4
5151	13.1	4	98	70	0	  rich	13.3	87.3	22	-0.5	300	4
5128	12.9	4.1	98	70	0	  rich	13.8	92.2	22	-0.7	300	4
5341	12.9	4.1	98	70	0	  rich	14.6	94.6	22	-0.7	300	4
5428	12.5	4.1	98	70	0	  rich	15.1	93.2	22	-0.7	300	4.1
5473	12.1	4.1	98	60	0	  rich	15.4	95	23	-0.4	300	4.1
5621	11.9	4.1	98	60	0	  rich	15.7	97.3	23	-0.4	300	4.1
5678	11.9	4.1	98	70	0	  rich	17.5	97.8	22	-0.6	300	4.1
5777	11.7	4.1	98	70	0	  rich	17.3	 ---.-	22	-0.6	300	4.1
5941	12.1	4.1	98	70	0	  rich	17.7	99.7	22.1	-0.5	300	4.1
5931	11.7	4.1	98	60	0	  rich	17.7	 ---.-	23.8	-0.3	300	4.2
6049	11.5	4.2	98	60	0	  rich	17.7	 ---.-	24	-0.1	300	4.1
6116	11	4.2	98	60	0	  rich	18	 ---.-	24	-0.1	300	4.1
6161	11	4.2	98	60	0	  rich	18.6	 ---.-	24	-0.1	300	4.2
6207	10.8	4.2	98	60	0	  rich	18.9	 ---.-	24	-0.1	300	4.2
6230	10.8	4.2	98	60	0	  rich	21.3	 ---.-	24	-0.1	300	4.2
6361	10.6	4.2	98	60	0	  rich	21.9	 ---.-	24	-0.1	300	4.1
6497	10.6	4.2	98	60	0	  rich	21.9	 ---.-	24	-0.1	300	4.2
6497	11	4.2	98	60	0	  rich	22.5	 ---.-	24	-0.1	300	4.2
6640	10.4	4.2	99	60	0	  rich	22.6	 ---.-	24	-0.1	300	4.2
6600	11	4.2	98	60	0	  rich	23	 ---.-	24	-0.1	300	4.2
6788	11	4.2	98	60	0	  rich	22.8	 ---.-	24	-0.1	300	4.2
6666	10.6	4.2	98	60	0	  rich	22.8	 ---.-	24	-0.1	300	4.2
6788	11	4.2	89	60	0	  rich	22.6	 ---.-	24	0	300	4.2
6535	8.6	2.1	1	0	0	  rich	10.9	7.7	ECU. 	0.4	ECU.  	1.9
6373	3.5	2.1	1	0	0	  rich	11.2	13.1	ECU. 	0.4	ECU.  	2.2
5995	-1.8	2.2	1	0	0	  rich	10.9	12.9	ECU. 	0.4	ECU.  	2.1
5777	-7.5	2.2	5	0	0	  rich	15.6	16	ECU. 	0.4	ECU.  	2.5
5200	-10	3	23	0	0	  rich	28.5	39.5	ECU. 	0	ECU.  	3.1
4823	-8.3	3	18	0	0	  rich	31.4	29	ECU. 	0	ECU.  	3
4782	-6.9	2.7	14	0	0	  rich	37.6	17.9	ECU. 	0	ECU.  	2.6
4734	-6.3	2.1	1	0	0	  rich	11	12.9	ECU. 	0	ECU.  	2.1
4708	-7.3	2	1	0	0	  rich	11.2	10.5	ECU. 	0	ECU.  	2
4357	-9.6	2	1	0	0	19.2	11.6	10.5	ECU. 	0	ECU.  	1.9
4016	-11	1.8	1	0	0	24.2	11.4	10.5	ECU. 	0	ECU.  	1.8
3711	-11.6	1.7	1	0	0	  lean	11.6	10.5	ECU. 	0	ECU.  	1.6
3411	-12	1.6	1	0	0	  lean	11.6	10.5	ECU. 	0	ECU.  	1.6
3287	-12	1.8	6	0	0	  lean	28.5	7.7	ECU. 	0	ECU.  	1.9
3479	-12	1.9	7	0	0	13.9	41.8	7.8	ECU. 	0	ECU.  	1.9
3523	-11.6	2	8	0	0	13.3	41.2	7.9	ECU. 	0	ECU.  	1.9
3501	-11.2	2	8	0	0	13.5	41	5.8	ECU. 	0	ECU.  	2
3531	-11	1.9	8	0	0	14.1	40.6	7.9	ECU. 	0	ECU.  	2
I've read the TXS User manual and Mick's guide each a couple of times, and I'm trying to put everything together. I know the maxiumum load points don't look right and am a little concerned with the injector duty. I will recalibrate the TPS...but should I switch back to the Stage 2 Map and try to get target boost levels by adjusting ABC?
Old 04-02-2005, 07:24 AM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the load points are based on MAP.
the MAP is determined by boost matrix and ABC.
the max MAP you're developing is low @ 13psi or so. bring that up to the st3 boost level, which is ~16 psi iirc.
you will find that your load points will increase when that happens.
as far as you injectors, yes, they are static. are you lean? not likely! before you start pulling fuel though you really ought to have a wideband o2 sensor. otherwise you're shooting in the dark and putting your engine at risk.
hth
ken
Old 04-02-2005, 11:12 AM   #18
kennyvb
Member#: 70234
MY86 BMW E30 325
Thanks for the input. So basically, ABC & boost matrix determines MAP which determines MLP. I'll leave it in CL (at least for now) and follow Mick's guide with 3 full turns of the ABC, boost gain at 48, and work on the matrix. Is my understanding that the matrix values are arbitrary correct?
I will most likely invest in the basic TXS tuner. Will I be okay with my ancient P75 laptop with one serial port? (I know for most other WBO2, i'll need two).
Thanks.
Old 04-02-2005, 02:31 PM   #19
Gethin
Member#: 2998
Your TPS should read 100 or slightly above or you won't reach the 100 column in the map. Mine reads 101.
Your log is showing a TPS value of 98 at WOT.
Gethin.
Gethin is offline   Reply With Quote
Old 04-02-2005, 03:30 PM   #20
kennyvb
Member#: 70234
MY86 BMW E30 325
I recalibrated it and adjusted the ABC. Just need an excuse to get away from studying and go driving.
06 STI AP V1, utec EM and other stuff!TX MRX WRX Engine/Power/Exhaust 7 09-13-2008 05:46 PM
UTEC Parameters after reflash in SD mode? plus plus plus UTEC 1 05-27-2007 02:48 PM
05 STI wheels and tires, WRX UTEC and Other pieces Templar Private 'For Sale' Classifieds 3 01-21-2005 10:49 AM
can someone give me the stock utec parameters? datdudedennis Engine Management & Tuning 1 03-25-2003 03:46 AM
UTEC, 19 DynaPak Runs, Maps, Data, and other tidbit's DiMensionX Engine Management & Tuning 50 10-05-2002 12:36 PM
