Old 03-29-2005, 12:29 AM   #1
davidra
Member#: 84048
Default Help: Diagnosis for loud noise from old subaru flat-4
Hi
I'm posting on behalf of a friend who owns an early 80's Subaru wagon - 2.0l, flat-4 engine... the engine is painfully loud to listen to with the bonnet (hood) open. Noise volume and frequency of occurrence varies in direct relation to engine speed. Noise is a loud clattering, slapping/tapping mechanical sound. Noise appears to be coming from the head on the near-side.. could it be a problem with hydraulic lifters? (do these cars have them?) - or perhaps piston slap... but I would've expected this to be a duller sound, more central... My other thought was a bearing for the timing belt/chain (can't remember, did look)?
Prior to me dismantling to explore can anyone indicate a likely cause (e.g. known problem with these engines)? Or is the engine done for...
Many thanks
dave rawlinson
davidrawlinson org uk
davidra is offline   Reply With Quote
Old 03-29-2005, 01:16 AM   #2
static_rst
Member#: 50155
turn it off and keep it off as long as possible until somebody more knowledgable replies
static_rst is offline   Reply With Quote
Old 03-29-2005, 09:10 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
most of the 80's owners with knowledge and experience
hang out here: http://www.ultimatesubaru.net/forum/
try posting there and i am sure you'll be flooded w/replies
jamie
www.subiegal.com
Old 03-29-2005, 11:34 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
It is most likely the Hydraulic Lash Adjusters. They wear out and stop holding oil and make for a lot of clattering in the heads. It is a pretty easy fix but can be quite expensive...
Old 03-30-2005, 01:59 AM   #5
davidra
Member#: 84048
thanks guys, will examine the lash adj. and then post on the other site!
cheers
dave
Old 03-30-2005, 03:19 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
I couldn't think of the link and forgot to come back to this with it. You'll be amazed at the level of support from the USMB.
Someday, the little kiddies will sell their subies for the next "in" car and NASIOC will evolve into the newer generation of USMB. That is my dream at least...... (he he he)
Jay Storm
loud noise from front passenger wheel area pizdets Transmission (AT/MT) & Driveline 1 07-28-2009 12:32 PM
Loud noise from pulley's! *WRX* PlatnumSlvrREX2004 Tri-State Area Forum 6 02-27-2009 11:43 AM
Loud Noise from Rear Japican Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 02-01-2009 07:45 PM
Loud noise from turbo area under full boost chris124816 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-19-2008 06:37 AM
Group think remote diagnosis for wheel noise blaster88 Brakes, Steering & Suspension 3 10-13-2001 02:22 PM
