Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 03-29-2005, 01:33 AM   #1
blackrexnj
Member#: 73594
Default vishnu stg Zero
delete
blackrexnj is offline   Reply With Quote
Old 03-29-2005, 03:28 AM   #2
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
You flash, remove, and enjoy
darksands is offline   Reply With Quote
Old 03-29-2005, 11:15 AM   #3
LowUFO
Member#: 36495
2004 WRX
Black Pearl
You can do what I did, and remove the Dastek, then, put the original 8 wires back together with spade connectors. But you have to make sure they are all crimped properly and that you wrap all those connections afterwards. If even one connection is less than solid, it prolly won't start.
If you removed the unichip and didn't cap off the harness, the car doesn't start because the wires are still there without being looped off.
But it only takes 20 minutes to pull all the Vishnu wiring and install spade connectors to return the ecu to stock setup.
I also reverted to stock beforehand. Then reflashed to stage 2.5 after.
LowUFO is offline   Reply With Quote
Old 03-30-2005, 02:54 AM   #4
blackrexnj
Member#: 73594
thanks for the info Lowufo.
just installed Cobb AP help boostedsti06 AccessPort 1 09-15-2007 08:21 AM
just installed Cobb AP help boostedsti06 AccessPort 1 09-14-2007 11:24 PM
just installed Cobb AP help boostedsti06 AccessPort 0 09-14-2007 07:25 PM
Just installed Cobb AP, wow. soundspeed Vancouver Impreza Club Forum -- VIC 15 08-14-2005 05:16 PM
can I use Cobb AP with my Vishnu stg Zero? blackrexnj Engine Management & Tuning 3 03-24-2005 11:35 PM
