Old 03-29-2005, 04:24 AM   #1
bugeyes
Member#: 64494
2001 V7 sti
Default differences in o2 sensors
My standalone ecu states it requires a "bosch wide band sensor" and goes on to stipulate bosch part number. Problem is these sensors are dam expansive. The ecu doesnt need the o2 sensor but its an option which allows datalogging and indication of mixture.
The standard subaru sensor is a narrow band I think.
For the purposes of datalogging and adjusting my mixture (a rough guide for mixture). I have connected a multimeter to the signal and it does seem to switch between 0 to 1V.
I admit it may not be as accurate as the wide band but why cant I use it for a rough guide.
What are the differences between sensors apart from some having heaters to get them working quicker on cold starts.
Of course the oem 02 sensor if free as its sitting there now just plugging the hole in the exhaust doing nothing.
bugeyes is offline   Reply With Quote
Old 03-29-2005, 10:17 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
It'd be helpful to know which ECU you're using and the Bosch part number it wants.
Jon [in CT] is offline   Reply With Quote
Old 03-29-2005, 06:46 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Clicky.... I dunno if your ems can use the less expensive sensor, but you can get a wbo2 sensor for $30. I wouldn't use the stock sensor to try to tune from. It might read downto 12 to 1 a/f ratio(maybe even a little richer), but from what i've heard it was only really ment to be accurate when close to 14.7 to 1.
peace
Old 03-29-2005, 07:59 PM   #4
bugeyes
Member#: 64494
2001 V7 sti
I'm running an EMS 8860 ecu. It stipulates it requires bosch wide band sensor part number- 0 258 104 002.
Old 03-29-2005, 09:43 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
That's a Bosch LSM 11 and you're right, they are expensive and hard to find. They are a very highly calibrated switching 0-1V O2 sensor. I think you should get decent results by using the stock rear 02 sensor on your 2001 WRX, although I haven't read about anyone who's tried that with your EMS 8860 ECU.
The front sensor on a 2001 bugeye WRX is typically mounted in the RH exhaust manifold/collector. It's a widerange A/F sensor that isn't compatible with an LSM 11. It should be removed because it will be ruined if left unpowered in the exhaust stream. If you have an STi and its O2 sensor is mounted just downstream from the turbo in the downpipe, then use that one with your ECU.
Old 03-29-2005, 09:53 PM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
sorry for the thread jack...
this looks like a bosch wb02 sensor for 60 bux:
http://store.summitracing.com/defaul...=KeywordSearch
It it really is a Bosch LSU 4.2 I think ill pick up a couple spares.
AaronWRX is offline   Reply With Quote
Old 03-29-2005, 09:53 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
P.S. You should confirm your results with a wideband A/F meter.
FS : Full 02-07 N/A Exhaust, Borla/Stromung/O2 Sensor Ext. Donutz Engine/Power/Exhaust 7 06-12-2010 08:39 PM
A/F Sensor in O2 Sensor? valetudospang Newbies & FAQs 23 06-08-2008 11:27 PM
Difference between 4 & 5 wire O2 sensor Petersubaru Normally Aspirated Powertrain 9 12-14-2006 06:42 PM
Is there a difference between front/rear o2 sensors? jonnysubby Normally Aspirated Powertrain 1 03-04-2005 07:13 AM
why do 02 and 03 wrx's have different rear O2 sensor part numbers? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-13-2004 08:53 PM
