Old 03-29-2005, 05:57 PM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default Who has used an MBC to hit target boost on cobbs stage 2.5?
I tried using my buddies spare TurboXs MBC on my stage 2.5 set up which hasnt really been able to hit target boost very well sense ive added a larger TMIC and header. When i barrowed the mbc and set it to 17 psi it worked perfect, i didnt have any PTFB problems or spikes, it hit target boost quicker and held it like a rock all the way to redline. i really liked the way it felt but i took it off the same day just be on the safe side while i do more research. Has anyone else done this? I talked to Cobb and they said that it is Ok to try because some of their buddies have mbc's too with no problems. I just wish i had a wideband 02 to throw on their to really make sure it would be safe. If anyone has any info on this subject, please share
blackie is offline   Reply With Quote
Old 04-01-2005, 12:54 PM   #2
Ace009
Member#: 70353
2004 WRX
I'd like to know about this too. I recently upgraded to 2.5 and had to install a MBC because my factory boost selenoid was fried and I was boosting really low. I will be replacing my TMIC with a V7 and I'm looking into getting headers too.
Blackie - What kind (and brand) of headers do you have right now?
Ace009 is offline   Reply With Quote
Old 04-01-2005, 02:28 PM   #3
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
know anyone with a tuna or a wb? It will most likely work alright.. but taking it off until you can make sure is probably a good idea. I know it works fine with the UTEC, and if the map on the accessport is set to reach a certian PSI and you are just using a MBC to get to that psi -- everything should be close enough.
Does an accessport show knock via check engine flash or do you just have to feel it when it pulls timing?
Either way, if you arent going overboard with the MBC and keeping it at sane levels, I dont see why it would be a problem.
Rob
dosage0 is offline   Reply With Quote
Not hitting target boost 2004 wrx stage 2 wrxmuch? Engine Management & Tuning 11 02-28-2013 02:56 AM
Not hitting target boost on Gabedude's stage 1 map NJ2.5RS Open Source Reflashes 19 08-12-2010 01:05 AM
Just hitting 14 psi on cobb stage 2 map instead of 16psi wrxgeneration Newbies & FAQs 19 04-13-2008 06:30 PM
Adding a mbc to hit target boost??? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 01-23-2005 02:47 AM
frount mount on cobb stage 2.5 ScottC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-28-2004 11:12 AM
