Old 03-29-2005, 08:46 PM   #1
tibby56
Member#: 80334
2004 Subaru STi
Java black
Default K & N typhoon intake
So, I just got done installing my K & N short air intake on my STi. I double checked everything and then when I turned the car on, The check engine light came on and the cruise control light is flashing. The car sounds incredible but I need to get these lights to turn off. Does anyone know what I might have done wrong and what I can do to fix it?
tibby56 is offline   Reply With Quote
Old 03-29-2005, 08:50 PM   #2
tallicaguitar88
Member#: 55635
2009 GTR
Whenever your cruise control is flashing it means youare pulling an active code. You need to get it checked out. did you try resetting your ecu?
tallicaguitar88 is offline   Reply With Quote
Old 03-29-2005, 09:00 PM   #3
23b_Rex
Member#: 79394
02 gda
wrb
try disconnecting the negative battery terminal and pressing the brake peddal for a few secs - this will reset your ecu
23b_Rex is offline   Reply With Quote
Old 03-29-2005, 10:12 PM   #4
tibby56
Member#: 80334
2004 Subaru STi
Java black
ok thanks ill try that but will this also help w/ the check engine light?
Old 03-29-2005, 10:46 PM   #5
Davenow
Member#: 23676
check to make sure your MAF plug is seated all the way.
Check all the plugs around it. You left something disconnected/knocked something loose 99% chance. No biggie though usually
FS CO: WRX/STI Perrin 2.4"inlet Pipe and 05 LGT K & N Typhoon Intake tommypenguin Engine/Power/Exhaust 2 09-08-2008 11:19 AM
FS: K & N typhoon intake IneedONE Engine/Power/Exhaust 4 10-24-2007 03:13 AM
WTB: K & N Typhoon Intake (CCA) mlovro32 Private 'Wanted' Classifieds 2 08-15-2006 02:40 PM
WTB: K & N Typhoon Intake (CCA) mlovro32 Private 'Wanted' Classifieds 1 08-12-2006 12:51 PM
K & N typhoon Intake sound clip dudical26 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-27-2005 01:48 AM
