Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 03-30-2005, 01:57 AM   #1
banta80
Member#: 62083
Default throttle delay?
I have a 2003 wrx with the stage 2 ap. Is it normal to have the car's ecu still feed gas even though i've completely set my foot off the gas pedal for a quick 1/5th or so of a second? I'll let off the gas completely and it seems that the ecu is still feeding gas to the engine. Yes this makes the car run "smoother" without the jerkiness, but it also makes my bov flutter. Thanks
banta80 is offline   Reply With Quote
Old 03-30-2005, 02:34 AM   #2
IntraWRX
Member#: 20773
Midnight Black Pearl
i notice it sometimes, when you let off the gas, the car is still revving. happens during shifts, too. i've read about other people having the same issue.
im on cobb stg 2 as well
IntraWRX is offline   Reply With Quote
Old 03-30-2005, 02:40 AM   #3
banta80
Member#: 62083
yes, that's exactly what i'm experiencing. Is there a fix to this?
Old 03-30-2005, 03:28 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
It's called "fuel cut" and it makes for a smoother, albeit fuel eating experience. There should be a way to shut it off, there is in the Hydra EMS.
There is also "dynamic enleanment" that occurs when the throttle is suddenly shut. If you don't have any enleanment (read a slight fuel flow delay) you car will buck like a mofo when off throttle and low RPM. This caused by a feedback between the transmission and the engine, which are of course coupled together when in gear. you want some "dynamic enleanment". Too little it bucks, too much it backfires.
Good luck finding out how with the AP, I can't help you there.
Throttle closure delay robert5995 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 116 04-08-2014 04:41 PM
Throttle delay, why? Jerry Xu Normally Aspirated Powertrain 70 07-18-2013 06:48 PM
Electronic throttle delay shemoves Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 08-04-2008 09:32 PM
Poss to 'tune out' throttle delay with ST? shemoves AccessPort 0 06-26-2007 05:47 PM
Throttle response delay and Ghost sparks in TEC II??? Cusco Engine Management & Tuning 9 03-15-2003 11:11 AM
