Old 03-30-2005, 11:33 AM   #1
Mr. Mercado
Member#: 36559
2003 Impreza WRX
Default Ecutek Map Switch Question (ECU "Learning")
Question for Ecutek users.....
When I switch between maps all the time, am I basically "reseting" the ecu and the ecu has to "learn" the maps all over again everytime I switch maps?
For Example, If I use the less aggressive map 75% of the time, and then switch over to the more aggressive map, will the ECU need time to learn the new map? Meaning, I won't have optimal HP until the ecu has learned the map?
If you could help out that would be great.
Mr. Mercado is offline   Reply With Quote
Old 03-31-2005, 09:09 AM   #2
Mr. Mercado
Member#: 36559
2003 Impreza WRX
Bump, anyone?
Old 03-31-2005, 10:39 AM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
As I understand it, you are not clearing/resetting the stored information in the dynamic maps with an ECU map switch.
However, as always, the ECU is adapting in areas. If you are using a less aggressive map and the ECU has learned within those constraints, switching to a more aggressive map will require time/miles before the ECU's learning is taking full advantage of the new parameters in effect.
jblaine is offline   Reply With Quote
Ecutek Map Switching Question Mr. Mercado Engine Management & Tuning 1 03-21-2008 05:57 AM
Ecutek map-switching p_ilis Engine Management & Tuning 2 10-17-2006 02:36 PM
Map switching question? codpiece AccessPort 4 10-16-2006 05:04 PM
ecutek map switching wrxtremeWGN Commercial ECU Reflashes 1 03-07-2006 06:13 PM
Cobb AP Map switching question akira02rex Engine Management & Tuning 14 04-19-2005 07:42 PM
