Mid Atlantic Impreza Club
Old 03-30-2005, 12:59 PM   #1
thorondor
Member#: 67304
2005 STI
CGM
Question Cobb stage 1 & 2 on an STI...
Does anyone in Mid-A have the Cobb Tuning Stage 1 or 2 (Accessport + Cobb turboback) on an STI?
If so what are your impressions? If you went with Stage 1 first what was that like?
Thanks!
thorondor is offline   Reply With Quote
Old 03-30-2005, 01:40 PM   #2
Let It Ride
Member#: 32465
2005 WRX STI
I have Stage 1 right now and love it. It really is a noticable difference through all the gears. I purchased the Cobb downpipe the same time as the Accessport and will move on to Stage 2 whenever I get it installed. Stage 2 must be a beast because for me the car is ridicously fast now. Hope this helps.
Let It Ride is offline   Reply With Quote
Old 03-30-2005, 02:09 PM   #3
thorondor
Member#: 67304
2005 STI
CGM
Default Sweet!
How was the install on the Stage 1? Exhaust is no problem for me b/c I have access to a lift...
Old 03-30-2005, 02:44 PM   #4
Let It Ride
Member#: 32465
2005 WRX STI
Install was cake. I just followed the included instructions. No issues.
Old 03-30-2005, 02:53 PM   #5
thorondor
Member#: 67304
2005 STI
CGM
Which map did you use?
Old 03-30-2005, 03:08 PM   #6
Let It Ride
Member#: 32465
2005 WRX STI
Stage 1 93 oct. It was already on the Accessport. Drop me a PM if you want to take it for a ride.
Old 03-30-2005, 03:36 PM   #7
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Stage 2, 93oct with APS 3" catted exhaust and a modified intake with no silencer, 3" velocity stack, STI air filter, and Samco MAF hose. Love it.
t
WolfPlayer is offline   Reply With Quote
Old 03-30-2005, 03:41 PM   #8
thorondor
Member#: 67304
2005 STI
CGM
Default Velocity Stack...
Excuse my ignorance, but what exactly is a velocity stack?
Old 03-30-2005, 03:43 PM   #9
WolfPlayer
Member#: 65054
2005 STI (CGM)
Something used to open up the airway on the stock airbox to a true 3" and smooth the entry of the air a little. It also keeps the rubber ring intact so that you can later reinstall your silencer if you need to. I learned about it on Scooby mods.
ScoobyMods:
http://www.scoobymods.com/forums/sho...=&threadid=113
My pics:
http://www.bescaredracing.com/sti/in...ncer/velocity/
t
Old 03-30-2005, 03:54 PM   #10
Gonz
Member#: 18642
2005 Impreza WRX STi
usually, you see them on carburetted race cars, like this:
it's a tuned chamber which stills the air and helps fill the cylinders with as much air as possible. what they'd be doing on a turbocharged, fuel injected car is
as far as Stage II. I think WRXJim has a stage II and he runs something ridculous, like 11.90s a t 75-80 quarter mile track. Pretty impressive !
G
Gonz is offline   Reply With Quote
Old 03-30-2005, 04:05 PM   #11
Supaboom
Member#: 38755
2004 WRX
i also use a velocity stack, i did a snokel removal and it helps ensure you pull air from the fender instead of the engine bay. It is cobb approved thats why people opt to run with that.
Supaboom is offline   Reply With Quote
Old 03-30-2005, 05:21 PM   #12
Gonz
Member#: 18642
^^^ so did it work? better throttle response or anything ?
G
Old 03-30-2005, 07:53 PM   #13
005sti
Member#: 78293
DP stockcatbckpro-
tune301wtq 289.7whp 93oct
I have stage 1 in my sti. I feel significant difference in tq, even before dyno testing. Dyno'd at mach V open house. apprx 235awhp and 260 awtq. is running real rich (10:1 a/f ratio from 3600 rpm to redline). another sti last year with stage 1 had better a/f and put down approx 255 and 280, respectively on the same dynojet dyno. money well spent, especially since the ap has several maps, and rich is better than lean. only downfall is no custom tuning with only accessport. with custom tuning, would have put down way better #s. plan on stg 2 with dp whenever i get mo' chedda'
005sti is offline   Reply With Quote
Old 03-30-2005, 09:46 PM   #14
Anonymouse20910
Member#: 29019
2012 Impreza WRX STi
I had stage I for about 2 months. It definately enhanced the performance over stock. Nothing drastic, but definately noticable. Power delivery just seemed smoother. After that, I went to Stage II with the 93 Octane Low Wastegate Map (I was overboosting) and oh man...sheesh, night and day difference. The boost just hits like crazy. My stage 2 set up uses the Turbo XS downpipe, high flow cat, and midpipe. I am using a prodrive round muffler to finish things off. I am also using a K&N typhoon filter, but I doubt there is any performance gain. Just noise gain . I should be satisfied with this setup, I don't race on the track or on the street, but I just like tinkering with my car. After 8 months with this setup I'm getting too used to it I wonder if Stage III will ever come out
Anonymouse20910 is offline   Reply With Quote
Driveline Motoring /// Perrin Vehicle Performance Upgrades Stage 1 & 2 *ON SALE* DriveLineSales Engine/Power/Exhaust 12 05-21-2009 02:21 PM
EGT gauge with cobb stage 1 & 2? jmc9809 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-10-2006 12:06 AM
Difference Between Cobb Stage 1 & Stage 2 rudy_t2004 Engine Management & Tuning 14 02-17-2005 10:57 PM
Question On Vushnu Stage 1 & 2 price... RDJ8o Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-14-2002 02:54 PM
APS-COBB Tuning Stage 1 & 2 Engine Packages and Warranties Curtis Warranty Issues & SOA Problems 12 01-01-2002 12:24 PM
