Old 03-30-2005, 01:49 PM   #1
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Default Access Tuner log. your comments
Hi, just wanted to post my tuner log that I took recently and see if you guys have any comment. I really dont know too much about tuning and want to learn a bit more. Although I know that the A/F is not accurate, I was curious on how to read it in the log. This log was taken on a random ride to TacoBell so it is probobly not the best log to tune from but I was just curious on how I would read it.
another question is that I may be running lean so if I changed the fuel map and decreased each A/F value by 2%, would that work or would that just make me detonate? I prefer to run a little more rich than lean.
Thanks for all the Helpful respnses.
AccessTuner LOG
darksands is offline   Reply With Quote
Old 03-30-2005, 02:26 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
I wonder why each sample is repeated in the log? For example 1st and 2nd are identical, 3rd and 4th are identical, etc..
Jon [in CT] is offline   Reply With Quote
Old 03-30-2005, 02:29 PM   #3
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Because the log rates are too fast.. turn em down and you will get a linear log.
buzz313th is offline   Reply With Quote
Old 03-30-2005, 02:56 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
Oh oh. I sense there's a really smelly alogrithm under the covers here.
Old 03-30-2005, 03:43 PM   #5
terry61oz5
Member#: 66809
04 FXT StreetTuner
Default re
Do you have an active EGT probe? I'm guessing that its the base ignition map I see without knock correction or is it total?
terry61oz5 is offline   Reply With Quote
Old 03-30-2005, 04:10 PM   #6
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
In response to the initial question, the AFR values you see in the log are in Lambda. During your WOT run at .77 Lambda you are right around 11.3:1 AFR. Not too trust worthy though on the stock O2. I see you never get richer than .77 at that showed up at times when you never broke .5 bar and 60% TPS. Looks like the stock 02 sensor or the ECU will only read down to 11.3:1. Time for a WB02. But from a quick overview and a pretty useless log, looks like you're plenty rich.
phantomsr is offline   Reply With Quote
Old 03-30-2005, 08:22 PM   #7
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
yes, it is a useles log.
I will turn down the log rates. Have any suggestions to how fast I should log?
I do have an EGT but I am questioning its reliability. It is telling me that I am running very lean. My temps go up to 1500F. I will test the EGT probe in some boiling water. So far no knock and no problems and the log says im running rich. Even at partial throtle, the EGT's are high. I do not have a WB02 but it is time for one.
This log was just a test to see if the ST worked or not. I am also trying to learn how to tune but Im not touching real time tuning. Not till i learn alot more. I appreciate all your input, thanks.
Old 03-30-2005, 10:39 PM   #8
criz
Member#: 56497
2008 WRX STi
niiiice... here' s my first log I just made tonight... I recorded almost every parameter
http://criztoph.zapto.org/misc2/log_3_all_temp47.csv
criz is offline   Reply With Quote
Old 03-30-2005, 10:46 PM   #9
criz
Member#: 56497
2008 WRX STi
if the fuel pump duty is 1.00, is it maxing out?
Old 03-31-2005, 12:33 AM   #10
R4ND0M_AX3
Member#: 67483
2005 WRX STi
Yes. Fuel pump is slowed down when not uder heavy load to reduce fuel temps and extend pump life.
R4ND0M_AX3 is offline   Reply With Quote
Old 03-31-2005, 02:02 AM   #11
criz
Member#: 56497
2008 WRX STi
does this mean I need an upgraded pump?
thanks
Old 03-31-2005, 11:24 AM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
try a log in 4th gear 1500 rpms to red line
i see your maf voltage very close to max
Old 03-31-2005, 11:43 AM   #13
criz
Member#: 56497
2008 WRX STi
how do you open up the maf voltage to get more room?
Old 03-31-2005, 12:43 PM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
If I remember correctly, the fuel pump duty is altered through the fuel pump controller. This is to conserve the life of the fuel pump. Under low load it runs reduced power (duty) and under high load it runs full power. This really has nothing to do with fuel pump size. Running out of fuel pump can be seen when your injector duty cycle is 100% and/or you can't get any richer under high loads.
-Jon
Old 03-31-2005, 03:01 PM   #15
criz
Member#: 56497
2008 WRX STi
oh, i thought if the injector duty was 100%, that just meant the injectors were maxing out... hmmmm thanks stimpy
Old 03-31-2005, 03:10 PM   #16
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Injectors maxing out means that the ECU is trying to hit an A/F target and it can't open the injectors up any more. Only way to increase your fueling at 100% is to increase your fuel pressure.
This and the fuel pump duty are two entirely different things.
-Jon
FS: V1 Accessport + access tuner + access tuner advanced software davidm_sh Engine/Power/Exhaust 4 03-11-2009 11:32 PM
Can Access Tuner Race data log 'locked' maps? Airboy AccessPort 2 11-20-2008 03:50 PM
access tuner 949 Engine Management & Tuning 14 02-27-2005 12:24 AM
Any nasioc user end up being beta testers for the Access Tuner? tejz Engine Management & Tuning 15 12-14-2004 11:52 AM
Will buying Cobb Access Tuner make Delta Dash obsolete? Corn-Picker Engine Management & Tuning 13 03-12-2004 01:35 PM
