Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 03-30-2005, 04:23 PM   #1
RicouGT
Member#: 55800
Default trouble with BC sbcid3 and td05/06-20G
hi !
i'm frensh and i've a classic impreza 2.0turbo with many mods including a td05/06-20G and a boost controller blitz sbcid3 (and 550 injectors, remap....).
this turbo can make a flow very important (as a td06-20g approximately) and i think i've some trouble with the BC...i can't up to 1.25b without the BC don't work fine (i've boost cut very important in fact)...i've setting a set of 69 for 1.25b (15 for gain). I ask me if the flow isn't to high for the BC, and if i should put a restrictor into the turbo-soleno inlet, to make down the set at, for example, 50 or 55...what do you think about that ?
excuse me for my very bad english...but there's not many people in france who have this BC.....
RicouGT is offline   Reply With Quote
Old 03-30-2005, 08:04 PM   #2
pux888
Member#: 8356
02 STi swap
12 WRX limited
i have the sbc id 3 and a a tdoh6-20 and had to go w/ an external wastegate to really control boost. mine didnt want to run anything less than 18-22lbs of boost, even w/ the controler off.
pux888 is offline   Reply With Quote
Old 03-31-2005, 01:40 PM   #3
RicouGT
Member#: 55800
in fact, the boost cutting wasn't made by the boost controller (i've a trouble with my maf....)
but the blitz doesn't want to work great when i want to up the boost pressure (1.35b for example) : the boost "pump" very hardly between 1.1b and 1.35...so i thunk the air flow was too high when the BC drive the waste gate (0.6b....)
i test with a restrictor into the inlet turbo-solenoid (1mm)..it's good ! i don't have any "pumping", the pressure is constant..after driving a lot, at start, it wasn't constant...so i've many question about the sbcid3 : i feel even in manual mode, the BC must learn ? is it right ? is someone already have to put a restrictor with a very big turbo and a blitz bc ?
i've less boost in 1/2/3 than 4/5 (1.1/1.12/1.15.1.17/1.20), is it normal ? (with 58 set and 10 gain)
thank to help me..i don't know what i've to think about this boost controller...
i would like to have a constant boost between al gear by al wheather...and i don't know if i make the good choice in fact (with an avcr, is it would be better ?)
Old 03-31-2005, 01:44 PM   #4
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
are you sure the injectors can hold that turbo? i awlays thought peopel got 720cc
WRXout is offline   Reply With Quote
Old 03-31-2005, 02:10 PM   #5
RicouGT
Member#: 55800
at 1.25b, idc= 82% (afr=10.8)
Old 03-31-2005, 04:05 PM   #6
RicouGT
Member#: 55800
can someone confirm me the turbo hose is connect to "in" entry of solenoid and the "out" to the waste gate (internal)
i've seen different things on the site, and i would like be sure about that....thanks !!
trouble with my RS and clutch Enphenate Transmission (AT/MT) & Driveline 18 11-10-2008 08:11 PM
Dyno Results with 03wrx and TD05-20g 03WRX83 Proven Power Bragging 67 05-17-2005 07:23 PM
Barely Used Speedlines with Hakka 2's, and rebuilt TD05-20G hotsam Private 'For Sale' Classifieds 8 10-27-2004 11:41 AM
TD05-16G and TD05-20G Marnix Normally Aspirated with bolt-on Forced Induction Powertrain 8 06-10-2004 10:45 PM
TD05/06-20G 1,4bar denmark1 Proven Power Bragging 18 03-04-2004 07:09 AM
