03-30-2005, 04:00 PM | #1 |
Member#: 43198
Vehicle:02 WRX |
Anyone have a good fuel economy map?
I've got a stage 3 wrx (up, down, top, utec), but I'm guessing none of that really matters all that much for a good fuel economy map. If no one has one, maybe I should just make my own? Low boost and timing with lean mixture, I would think. Problem is I have no WB O2, so I don't know how I'd tune for fuel.
03-30-2005, 04:25 PM | #2 |
Member#: 77483
Vehicle:2009 Audi A3 2.0T q Lava Grey |
You'll want a WB to do it. I've been working out how to do it as well for my Stage 1 (soon to be stage 2).
I going to go for low boost, medium timing and a lean mixture. I doubt I'll be able to do much better than stock, though. |
03-30-2005, 04:30 PM | #3 |
Member#: 16876
Vehicle:2002 Impreza WRX WR Blue |
If you are after fuel economy, then you want to boost as little as possible. I'm guessing if you turned down the boost and leaned things out a bit, you might be able to improve a couple fractions of a mile per gallon, but no more than that.
In any case, engine management isn't the way to improve fuel econony, a right foot weight reduction program is. |
03-30-2005, 05:13 PM | #4 | |
Member#: 5477
Vehicle:2007 R171.473 2009 SWP Spec B |
03-30-2005, 05:19 PM | #5 | |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
I'm averaging 130-160 miles per tank street tuning the GT30 heh. Jorge (RiftsWRX) www.ProjectWRX.com |
03-30-2005, 05:32 PM | #6 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
I just made one for you:
Code:
Map Name:-[FUEL ECONOMY MAP] Map Comments:-[0psi peak 14.7:1 afr] Boost Map [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] |
03-30-2005, 06:15 PM | #7 | |
Member#: 43198
Vehicle:02 WRX |
Similar Threads | ||||
I have stage 2, can I use the fuel economy map? | down_for_the_scooby | AccessPort | 9 | 08-20-2009 08:41 PM |
Does the AP fuel economy map actually make a difference? | chargerbry | North West Impreza Club Forum -- NWIC | 4 | 07-13-2008 10:48 PM |
Anyone got a good stage 2 map for 05 wrx.. | Nessen | Commercial ECU Reflashes | 1 | 06-14-2008 06:02 AM |
does anyone have any good stage 2 maps | jemar2169 | UTEC | 3 | 02-08-2007 11:12 AM |
anyone have a decent Stage 3 Map that isn't as conservative as base map? | wrxpeed | UTEC | 14 | 05-05-2006 05:41 PM |
