Old 03-30-2005, 04:22 PM   #1
SILVERHKSWRX
Member#: 81682
2002 wrx
platinum silver
Default hks intake with what e.m?
i know i did the dreaded...
i replaced my stock airbox with an hks unit. it works grrreat! it even uses the same filter spt uses on thier kits so if its backed by the factory performance team, it has to be good. my only concern is that i am looking for engine managment system and i sold my stock airbox. what ems should i consider?
i am thinking of a fully programmable one but if so ill get the ecutec and have mastro subaru dyno tune it for me but i was shown accessport from a friend and i likes. any help would be greatly appreciated.
SILVERHKSWRX is offline   Reply With Quote
Old 03-30-2005, 06:05 PM   #2
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
if it doesnt effect the MAF sensor, it shouldnt be a problem. However, many do, and the major benefit of an intake on most cars is that it leans out your fuel mixture and makes more power. With engine management, you can lean the mixture out yourself... so .... you dont really need it. I have heard of gains with high HP cars, so keep it if you like it I guess.
You can try to tune around it / with it... hopefully it wont screw with the readings and cause the car to lean or richen
Rob
dosage0 is offline   Reply With Quote
Old 03-31-2005, 08:29 AM   #3
SILVERHKSWRX
Member#: 81682
2002 wrx
platinum silver
Rob
i spoke to the people at cobb, and they said they do not have a map for any aftermarket intake except injen. so i would have to get thier street tuner or go get ecutec.
Old 03-31-2005, 10:26 AM   #4
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Measure the inside diameter of the MAF pipe on the HKS unit. If it's the same as the stock inner diameter you can run any EM you want.
mbiker97 is offline   Reply With Quote
Hks Intake Sti Or Wrx With Maff. Sensor MARKSTIV8 Engine/Power/Exhaust 5 05-25-2009 02:11 PM
WTS HKS Mega Flow Intake with MAF Housing RiceandBeans NWIC Private Classifieds 0 05-16-2007 01:35 AM
Injen Cold air intake with HKS filter???? Rallly2000 Newbies & FAQs 8 09-18-2006 08:42 AM
Has anyone have Psi drop with the HKS intake kit? underground-mpyre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-28-2005 02:46 PM
HKS intake with Zerosports intake pipe solberg wantabee Private 'For Sale' Classifieds 0 09-18-2003 06:25 PM
