Old 03-30-2005, 05:37 PM   #1
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Exclamation TXS tuner problem
Hi all,
What do you think will cause this ??
While on the boost my afrs suddenly starts to read as >25:1.
Also , i have done the free air calibration.
Is my wb sensor dead ?
4182 +18.0 4.1 100 80 00 W/B +20.6 55.8 +19.0 +0.5 340.00 3.9 11.80
4301 +19.0 4.2 100 80 00 W/B +18.7 58.8 +19.0 +0.5 340.00 4.0 11.81
4334 +20.6 4.2 100 90 02 W/B +16.2 65.2 +14.0 +0.7 340.00 4.0 15.02
4444 +21.7 4.3 100 90 00 W/B +16.3 67.2 +14.0 +0.4 340.00 4.1 >25:1
4535 +22.9 4.3 100 100 00 W/B +17.3 71.0 +14.0 +0.9 340.00 4.1 >25:1
4585 +23.7 4.3 100 100 00 W/B +18.3 71.5 +18.0 +0.7 340.00 4.1 >25:1
4623 +23.9 4.4 100 100 00 W/B +19.4 70.8 +18.0 +0.6 340.00 4.1 >25:1
4721 +24.1 4.3 100 100 00 W/B +19.6 70.8 +18.0 +0.1 340.00 4.1 >25:1
4810 +24.1 4.4 100 100 00 W/B +21.3 76.0 +18.0 -0.1 340.00 4.1 >25:1
4859 +23.7 4.6 100 90 00 W/B +26.6 71.8 +19.0 -1.8 340.00 4.1 >25:1
WhiteKnight is offline   Reply With Quote
Old 03-30-2005, 05:52 PM   #2
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
lol.. well I hope its dead and not reading that correctly
dosage0 is offline   Reply With Quote
Old 03-30-2005, 06:08 PM   #3
2phless
Member#: 69343
1998 TransAm cnvrtbl
That's why you need a regular autometer gauge reading the rear stock sensor as a back-up/ error check for the Wideband.
At any rate, I saw this with a bad VW WB sensor in both the LM-1 and the Tuner. Time to take a trip to the VW dealership for a new one.
First check that the calibration is ok, and check to see that the WB sensor hasn't vibrated slightly loose.
2phless is offline   Reply With Quote
Old 03-31-2005, 07:28 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how many miles on the sensor? leaded gas at all?
Old 03-31-2005, 08:57 AM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
find a local who will swap sensors with you. then you can isolate your problem.
AaronWRX is offline   Reply With Quote
Old 03-31-2005, 05:58 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
I'd say fuel cut, course I could be wrong. Make sure the fuel cut defender switch is flipped.
peace
Old 04-01-2005, 01:06 PM   #7
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Unleaded gas and about 5000 miles with them.
and FCD is on.
Old 04-02-2005, 08:43 AM   #8
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
where is the sensor?? The sensor could be to hot.
Russ
WRX1 is offline   Reply With Quote
Old 04-02-2005, 06:53 PM   #9
WhiteKnight
Member#: 56133
2004 Euro spec Sti
The sensor was very near to the oem o2 sensor place on the downpipe.
Old 04-02-2005, 08:14 PM   #10
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sti utec's fuel is set at 22 psi in the states.
and looking at your log..low boost at 21.7
and the rest of the boost was past 22psi..
unless you had already raised the fcd.
but you car was still revving..
check the wb..like the others said
try swapping wb..
Old 04-06-2005, 04:52 AM   #11
WhiteKnight
Member#: 56133
2004 Euro spec Sti
I think there is a problem with gas flow,
because afr works at low boost and when i hit full boost, it goes off after 2 seconds.
Old 04-06-2005, 08:46 AM   #12
2phless
Member#: 69343
Mine did the exact same thing. It was so consistant that it felt like it had to be a mechanical issue of some sort, but it was just the WB sensor. I knew it was in the WB setup though because the autometer AFR gauge reading off the rear, stock O2 sensor was staying all the way rich.
If the car were really going all the way lean like that, at WOT, you'd feel the power loss. The sensor is only $60 at VW. If that doesn't fix it then you'll just have a new spare one, because eventually it will go bad if it hasn't already.
Old 04-06-2005, 03:17 PM   #13
WhiteKnight
Member#: 56133
2004 Euro spec Sti
My sensor was BOSCH,
would you recommend the vw ?
Is there any significant quality difference ?
Old 04-06-2005, 06:31 PM   #14
hippy
Member#: 36528
2002 Impreza Wrx
The bosch and vw are both bosch lsu4 sensors. People say the more expensive one responds quicker, but I haven't really seen a difference since switching to the vw one.
peace
Old 04-06-2005, 06:42 PM   #15
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Thanks alot..
What are the prices of these sensors ? anyone ?
Old 04-06-2005, 07:09 PM   #16
hippy
Member#: 36528
2002 Impreza Wrx
From what I've seen, around $30-150+ depending on the sensor and where ya get it. You can get a vw one here for a little less then $40+shipping(part number 021906262B). Save your old one if you're gonna get the vw sensor though, cause you'll have to use the old connector with it.
peace
Txs Tuner Pro wiring problems NavyBlueSubaru Engine Management & Tuning 2 02-17-2007 06:02 PM
FS: TXS Tuner Bosch, TXS Knock Lite (both new) AspenGC8 Engine/Power/Exhaust 15 01-19-2007 12:09 PM
TXS TBE, 17" wheels, TXS Tuner, WRX Intake Mani rjrutzky Private 'For Sale' Classifieds 25 12-19-2005 05:21 PM
FS: TXS UTEC, TXS Tuner w/ pocket mount, Tein EDFC, DS2 + H1 HID bulbs TROLL Private 'For Sale' Classifieds 11 09-24-2005 03:51 PM
FS: TXS Remote Map Switch (new), Profec 2 EBC, TXS Tuner wgknestrick Tri-State Area Forum 12 12-21-2004 05:55 PM
