Old 03-30-2005, 10:02 PM   #1
cusco4life
Member#: 83050
2005 STI
BLACK
Default Volk ce28n 17x8.5 on 05 sti
whats up i have a 05 sti and i am looking to get the volk ce28n bronze in 17x8.5 and it has a 50 offset
any news on rubbing issues or is a 50mm a good offset also looking to get rid of my 05 gold sti rims and tires..
cusco4life is offline   Reply With Quote
Old 03-30-2005, 10:29 PM   #2
flyinpig
Member#: 43640
02 impreza
Rays lists 17x8.0 +44; 235/45-17 as the recommended size in 17's, with a footnoted warning of possible rubbing on front fender.
But on another page 17x8.5 +50 is listed as compatible with GDB Brembos.
Edit: I meant 17x8.5 not 17x7.5 on the second size, sorry
flyinpig is offline   Reply With Quote
Old 03-31-2005, 02:31 AM   #3
cusco4life
Member#: 83050
2005 STI
BLACK
yah i saw that page but i dont think it is updated because the 17x8.5 5x114.3 50mm offset just recently came out?? on the rim it says made in 2004-12...
can i use the bridgestone 225 45 17 (stock 05 sti) on bridgstones site it said the stock tire can fits on a 7-8.5in rim. or should i go with a wider size like maybe 235 or 245 but then i am also worried about rubbing issues i also dont want to go lower than a 45 series
Old 03-31-2005, 09:58 AM   #4
flyinpig
Member#: 43640
02 impreza
Oops I made a typo in my previous post. The list shows 17x8.5; +50 5x114.3 to be compatible with GDB Brembos (not 7.5") Sorry about that.
You can fit the stock tires on the 8.5's as 225/45-17's. Like you said they normally fit 7.0-8.5" wide rims. I dont think you will rub with 235s..not sure of 245s though. I know you said no lower than 45 profile, but have you considered 235/40-17 (8-9.5" width)? Lower gearing, a bit skinner sidewall..
Old 03-31-2005, 11:46 AM   #5
jsalicru
Member#: 58031
if you have a 05, I would tell you to try the +44 better... you have the fender's to cover them up and the +44 wont look sunk in like the 50 would. for a 8.5" wheel, I think +50 is a bit much and you will sacrifice the tire size because the wheel will be REALLY close to the strut. Also, 235s looked wrapped and a little stretched on 8.5s... I have that setup currently. So take that into consideration. I plan to go at least 255s soon, but will try 265s with rolled fenders.
jsalicru is offline   Reply With Quote
Project Kics R40 or R26 lugnuts for volk ce28n 17x8,5 +44mm? Best? subierider Tire & Wheel 7 02-19-2009 09:05 PM
Volk CE28N 17x8.5 5X100 +44, BNIB benton0311 MAIC Private Classifieds 10 10-17-2007 12:05 AM
Volk CE28N 17x8.5 52mm rayman481 Tire & Wheel 11 11-07-2004 06:32 AM
volk ce28n 17x8.5, will it fit? TYPE wRx Tire & Wheel 5 07-15-2003 06:23 AM
Message Board Statistics All times are GMT -4. The time now is 06:56 PM.
