#1 |
Member#: 81770
Vehicle:2005 Legacy GT Ltd Obsidian Black |
Hi,
Today I drove out to lunch, stopped to get some gas and my CEL came on. I checked it at Autozone and it is a P0171 code. I don't have a CAI, just the stock airbox. Do you think the error could be attributed to my dyno-tune/reflash last Friday? It is much warmer today and the Santa Anas are blowing. So I don't know if the outside temp or the wind conditions have anything to do with it. I disconnected and reconnected my MAF sensor. I also checked for loose vaccum lines but didn't find any. So could this be a problem with the Tune and the temperature ? Thanks, ~Will
#2 |
Member#: 28408
TXIC
Vehicle:2002 BugEye WRX PSM |
it should be because the fuel cant run the AFR you want it to run. the injectors are only able to make a correction of about +-5%. so when they try to tun your AFR and cant do it for whatever reason (leak etc...) then the CEL comes on.
oh and search for a thread about that CEL. lots of good info there. |
| Thread Tools | |
| Display Modes | |
| Utec able to remove cel due to tgv deletes?? | wrxdragger | UTEC | 2 | 03-11-2013 03:43 PM |
| First CEL due to 3/16 Mod | sonicwrx03 | Factory 2.0L Turbo Powertrain | 13 | 01-31-2005 08:21 PM |
| CEL due to running lean due to cat back or removed silencer?? | wrx_snobordr | Factory 2.0L Turbo Powertrain | 14 | 12-03-2004 11:22 PM |
| CEL due to system? | NateDogg | Car Audio, Video & Security | 0 | 09-08-2002 04:26 AM |
| CEL due to engine sensor falling off = very hot turbo | Snowphun | Factory 2.0L Turbo Powertrain | 5 | 06-21-2002 05:57 PM |
